Sprint RS rear caliper binding
slowside
PostPosted: 21:45 - 31 May 2020    Post subject: Sprint RS rear caliper binding Reply with quote
So I rebuilt front and rear calipers with new seals and pistons about 200 miles ago.
I’ve noticed an audible drag on the rear brake when wheeling the bike around and on stopping after a ride the rear disc is hot. Not molten metal, melts ice creams in a 5 mile radius hot, but don’t keep your hand on it too long.
I plan to give it another bleed in case there is an air bubble preventing pressure releasing into the master cylinder.
Any other culprits I should be on the lookout for?
I should add that whilst the front calipers cleaned up nicely, the rear took hours of work to remove the grime from the piston and seal seats and I never got it spotlessly clean.
NJD
PostPosted: 22:54 - 31 May 2020    Post subject: Reply with quote
Give them a clean. Out of all the work I do myself cleaning the calipers is the job I do the most, and more when it rains or during winter.
If you can replace pistons and seals and flush the system without issue then I'd be surprised if you said you haven't pumped the pistons out (partly, and not all the way), sprayed them with brake cleaner and then regreased all the sliding parts and back of pads before making this post?
Looking at the face of the pads will tell you if they've been rubbing heavily for a long time, but that's just one of a few signs.
The rear is probably always going to suffer more just because that's where all the road crud is kicked up.
steve the grease
PostPosted: 23:18 - 31 May 2020    Post subject: Reply with quote
Very often there is a bit of white aluminium oxide in the groove where the rubber goes, this causes the rubber to be a bit proud in places, this squeezes the piston tighter than usual , making the piston not go back quite so easily / as far. Strip and clean again, with particular attention to the grooves.
A local wheel refurbishers would probably bead blast the bore in a minute of two for a fiver or a tenner.
Robby
Dirty Old Man
PostPosted: 23:30 - 31 May 2020    Post subject: Reply with quote
Either corrosion behind the seal in the caliper, or something blocking the return hole in the master cylinder.
Also make sure your pads can move freely, and the pad pins aren't bent, notched or rusty.
stevo123
PostPosted: 14:29 - 01 Jun 2020    Post subject: Reply with quote
Also don;t overlook the basics - is the brake pedal allowing some clearance to the master cylinder when not pressed with your foot? Must be a small bit of "slack" between the resting position of the lever and the master cylinder else pressure can build leading to binding.
Not as likely as corrosion or dirty piston/slider though but keep it in mind mate.
slowside
PostPosted: 14:17 - 02 Jun 2020    Post subject: Reply with quote
Thanks all, yes must admit that at the point I posted this thread I've not done anything beyond parking it up in the garage - but thought I canvas some collective wisdom before I start on the basics of checking it over this weekend.
The rear caliper itself is still visually clean and during the rebuild I replaced absolutely everything bar the caliper block itself, so in addition to pistons and seals it has new slid pin, rubber boots, bleed nipples etc.
That said I'll pull it off and give it another clean up on Sat and give the brake fluid another flush through.
Hopefully I can avoid having to take apart the caliper again. Was a messy ball-ache of a job.
steve the grease
PostPosted: 16:13 - 02 Jun 2020    Post subject: Reply with quote
It's likely that the problem lies within the caliper. Yes it's visbly clean , but it only needs a tiny bit of white corosion behind the square section rubber to sieze it all up.
NJD
PostPosted: 21:49 - 02 Jun 2020    Post subject: Reply with quote
I would stress not to expect a rebuild to mean that the caliper wouldn't need attention until the next rebuild. I'd view a rebuild as a more in depth way of cleaning the caliper that occurs maybe once a year at most.
In my experience the cause of calipers needing cleaning is slider pins stop causing binding or ineffective breaking. As I say worse in adverse weather like rain, and road salt being the worst, and regular cleaning allows you to prevent that job occurring and inspect the various parts for issues in the mean time.
Copper grease, red rubber grease, brake cleaner a toothbrush and the jobs a gooden (minus a couple of other additions depending on design of your caliper).
Remember to have a look at the rear brake pedal pivot point as if that's not lubricated then it could cause drag in the pedal causing a slight drag on the rear. I've not worked on a bike where this wasn't a pain to get to, and involves removing a few springs (be very careful with your rear brake light switch). Multi purpose grease works fine, but again is something I do every so often to keep things running smoothly. May be worth checking rear brake pedal height is within adjustment if you've not done it before, too.
Also remember it is very hot at the moment.
But yeah on the whole, and even in nice weather, brakes get dirty and just need a little bit of T.L.C to get running smoothly again.
Remember we're just recommending unbolting the caliper from the bike (with the brake line attached) and cleaning things up. Make sure you don't get any copper grease on the face of the pads, on the pistons (as it will attack seals) or on the brake disc. Pump the pistons out a tiny bit to clean up and then push back in so pads can be installed.
I'll stop rambling now.
slowside
PostPosted: 07:39 - 03 Jun 2020    Post subject: Reply with quote
Much appreciated, just the kind of info I was after.
When I acquired this bike it was in quite a neglected state, I've done all the work on it myself to get it roadworthy, but most of these jobs are a first for me (caliper rebuild included) so I appreciate the insight from those who have been there and got the t-shirt.
My old YBR was a doddle in comparison, was barely any different to fixing a bicycle.
Robby
Dirty Old Man
PostPosted: 11:04 - 03 Jun 2020    Post subject: Reply with quote
My favourite tools for cleaning calipers are a drill and a pick.
The drill is for sliding pins. Clamp them like a drill bit, spin, and hold some emery paper over the pin. Gets them clean and keeps them round. A bit like a really cheap lathe.
Ideally they should be replaced - they are wear items. The problem is they cost a lot for what they are and invariably only get sold from places that do really slow postage.
The pick is for remove the seals in the caliper, and then cleaning out the white crud from behind them. You don't need to be too gentle here - the white crud is very soft, the caliper body is fairly hard, and if you press to hard you'll bend/break the pick before hurting the caliper.
Get these bits right and the rest is less important. It's very easy to get anal about using just the right amount of grease, when it makes very little difference in reality. Too much and you'll make more of a mess when the dirt sticks to it. Too little and things may corrode a bit faster - but it all corrodes worryingly fast anyway. I also wouldn't worry about having the exact right kind of grease, for instance I have never used red rubber grease. Getting things clean and smooth is more important.
Finally, it is important to note that bike brakes, particularly rear brakes, tend to be a fairly shit design. The brake lines run almost horizontal, which means bleeding them is very difficult and best done with the caliper off the bike, either sitting on the floor or elevated so the air can go somewhere (either up to the master cylinder, or up to the bleed nipple). They get dirty and corroded, but don't have rubber boots over important bits. They also get used so little that rear pads tend to last years, which means a good chunk of the piston is sitting there exposed to the elements and gently rusting for years at a time. Then to make it more fun, you have to dismantle half the back end to remove/replace them. Shit job.
Because of this, it's worth doing all of the jobs at once. Pad change, strip and clean, fluid change, bleed.
PostPosted: 11:42 - 06 Jun 2020    Post subject: Reply with quote
In addition to the above, make sure you haven’t over filled the fluid reservoir.
A a few bikes have seals that are tapered and only go in one way. Not common, but can screw things up if the wrong way round
Katy
slowside
PostPosted: 11:35 - 30 Jun 2020    Post subject: Reply with quote
Quick update:
I pushed out the pistons a bit and gave everything a clean (they were pretty clean anyway) and replaced the pad retainer pins with new ones, additionally I took a few ml out of the reservoir as it was on the full line.
Visually I can see the pistons slack off when pressure is released from the brake pedal.
Disc only feels warm to the touch after a ride now, so if that heat isn't from normal use any drag is pretty minimal.
Cheers all for the advice. Thumbs Up
Triumph Sprint RS 955i - Sold
Triumph Street Triple R 675
MCN
PostPosted: 14:49 - 30 Jun 2020    Post subject: Reply with quote
slowside wrote:
Quick update:
On a bike and other road vehicle wheel brake callipers there is no return spring to pull the piston back into the calliper when the brake lever is released. So the pad will rest on the disc after braking. This serves an important purpose of providing minimal lag in brake application.
The piston seals are designed to flex with the piston as it moves from brake off position to brake on position hardly even a millimetre. Pad wear is taken up by the piston squeezing through the flexed seal too.
When brake pressure is released the piston seal returns (springs back) to its brake off (resting) position. That pulls the piston back in and the pads should then only 'dust' the disc.
Did you use OEM seals or competitive parts?
Was the seal kit fairly 'fresh' or a bit mature?
Are also affects rubber spring ability.
Jist another area to worry about and lose.more sleep over. 😂
slowside
PostPosted: 15:28 - 30 Jun 2020    Post subject: Reply with quote
Seal and piston kit was made by TRK, brand new parts from Wemoto.
As I say, I'm satisfied with the performance now after the last round of attention.
One thing Katy / Kickstart alluded to is the directional nature of some seals which I didn't consciously check at the time (as I was ignorant of that fact) but certainly didn't notice whilst looking at them.
I'm not going to pull them apart again to find out, but if they do necessitate a rebuild again in the future I'll make a note to check.
The last post was made 6 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 89.88 Kb
