| slowside |
 slowside Nova Slayer
| NJD |
 NJD World Chat Champion
| steve the grease |
 Posted: 23:18 - 31 May 2020 Post subject: |
Very often there is a bit of white aluminium oxide in the groove where the rubber goes, this causes the rubber to be a bit proud in places, this squeezes the piston tighter than usual , making the piston not go back quite so easily / as far. Strip and clean again, with particular attention to the grooves.
A local wheel refurbishers would probably bead blast the bore in a minute of two for a fiver or a tenner. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| Robby |
 Robby Dirty Old Man
| stevo123 |
 stevo123 Nitrous Nuisance
| slowside |
| steve the grease |
 Posted: 16:13 - 02 Jun 2020 Post subject: |
| slowside wrote: | Thanks all, yes must admit that at the point I posted this thread I've not done anything beyond parking it up in the garage - but thought I canvas some collective wisdom before I start on the basics of checking it over this weekend.
The rear caliper itself is still visually clean and during the rebuild I replaced absolutely everything bar the caliper block itself, so in addition to pistons and seals it has new slid pin, rubber boots, bleed nipples etc.
That said I'll pull it off and give it another clean up on Sat and give the brake fluid another flush through.
Hopefully I can avoid having to take apart the caliper again. Was a messy ball-ache of a job. |
It's likely that the problem lies within the caliper. Yes it's visbly clean , but it only needs a tiny bit of white corosion behind the square section rubber to sieze it all up. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
| NJD |
 Posted: 21:49 - 02 Jun 2020 Post subject: |
| slowside wrote: | Thanks all, yes must admit that at the point I posted this thread I've not done anything beyond parking it up in the garage - but thought I canvas some collective wisdom before I start on the basics of checking it over this weekend. |
I would stress not to expect a rebuild to mean that the caliper wouldn't need attention until the next rebuild. I'd view a rebuild as a more in depth way of cleaning the caliper that occurs maybe once a year at most.
In my experience the cause of calipers needing cleaning is slider pins stop causing binding or ineffective breaking. As I say worse in adverse weather like rain, and road salt being the worst, and regular cleaning allows you to prevent that job occurring and inspect the various parts for issues in the mean time.
Copper grease, red rubber grease, brake cleaner a toothbrush and the jobs a gooden (minus a couple of other additions depending on design of your caliper).
Remember to have a look at the rear brake pedal pivot point as if that's not lubricated then it could cause drag in the pedal causing a slight drag on the rear. I've not worked on a bike where this wasn't a pain to get to, and involves removing a few springs (be very careful with your rear brake light switch). Multi purpose grease works fine, but again is something I do every so often to keep things running smoothly. May be worth checking rear brake pedal height is within adjustment if you've not done it before, too.
Also remember it is very hot at the moment.
But yeah on the whole, and even in nice weather, brakes get dirty and just need a little bit of T.L.C to get running smoothly again.
Remember we're just recommending unbolting the caliper from the bike (with the brake line attached) and cleaning things up. Make sure you don't get any copper grease on the face of the pads, on the pistons (as it will attack seals) or on the brake disc. Pump the pistons out a tiny bit to clean up and then push back in so pads can be installed.
I'll stop rambling now. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| slowside |
| Robby |
 Robby Dirty Old Man
 Posted: 11:04 - 03 Jun 2020 Post subject: |
My favourite tools for cleaning calipers are a drill and a pick.
The drill is for sliding pins. Clamp them like a drill bit, spin, and hold some emery paper over the pin. Gets them clean and keeps them round. A bit like a really cheap lathe.
Ideally they should be replaced - they are wear items. The problem is they cost a lot for what they are and invariably only get sold from places that do really slow postage.
The pick is for remove the seals in the caliper, and then cleaning out the white crud from behind them. You don't need to be too gentle here - the white crud is very soft, the caliper body is fairly hard, and if you press to hard you'll bend/break the pick before hurting the caliper.
Get these bits right and the rest is less important. It's very easy to get anal about using just the right amount of grease, when it makes very little difference in reality. Too much and you'll make more of a mess when the dirt sticks to it. Too little and things may corrode a bit faster - but it all corrodes worryingly fast anyway. I also wouldn't worry about having the exact right kind of grease, for instance I have never used red rubber grease. Getting things clean and smooth is more important.
Finally, it is important to note that bike brakes, particularly rear brakes, tend to be a fairly shit design. The brake lines run almost horizontal, which means bleeding them is very difficult and best done with the caliper off the bike, either sitting on the floor or elevated so the air can go somewhere (either up to the master cylinder, or up to the bleed nipple). They get dirty and corroded, but don't have rubber boots over important bits. They also get used so little that rear pads tend to last years, which means a good chunk of the piston is sitting there exposed to the elements and gently rusting for years at a time. Then to make it more fun, you have to dismantle half the back end to remove/replace them. Shit job.
Because of this, it's worth doing all of the jobs at once. Pad change, strip and clean, fluid change, bleed. |
| slowside |
 Posted: 11:35 - 30 Jun 2020 Post subject: |
Quick update:
I pushed out the pistons a bit and gave everything a clean (they were pretty clean anyway) and replaced the pad retainer pins with new ones, additionally I took a few ml out of the reservoir as it was on the full line.
Visually I can see the pistons slack off when pressure is released from the brake pedal.
Disc only feels warm to the touch after a ride now, so if that heat isn't from normal use any drag is pretty minimal.
Cheers all for the advice.  ____________________ Triumph Sprint RS 955i - Sold
Triumph Street Triple R 675 |
| MCN |
 MCN Super Spammer
 Posted: 14:49 - 30 Jun 2020 Post subject: |
| slowside wrote: | Quick update:
Cheers all for the advice.  |
On a bike and other road vehicle wheel brake callipers there is no return spring to pull the piston back into the calliper when the brake lever is released. So the pad will rest on the disc after braking. This serves an important purpose of providing minimal lag in brake application.
The piston seals are designed to flex with the piston as it moves from brake off position to brake on position hardly even a millimetre. Pad wear is taken up by the piston squeezing through the flexed seal too.
When brake pressure is released the piston seal returns (springs back) to its brake off (resting) position. That pulls the piston back in and the pads should then only 'dust' the disc.
Did you use OEM seals or competitive parts?
Was the seal kit fairly 'fresh' or a bit mature?
Are also affects rubber spring ability.
Jist another area to worry about and lose.more sleep over. 😂 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| slowside |
The last post was made 6 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
