Forks
kramdra
PostPosted: 23:49 - 06 Jun 2020    Post subject: Forks Reply with quote
Stripping forks, Ive got both legs spinning the drain bolt/damper rods. I tried compressing the fork upside down without any luck. How to remove?
Bhud
PostPosted: 00:05 - 07 Jun 2020    Post subject: Reply with quote
Broomstick
PostPosted: 00:11 - 07 Jun 2020    Post subject: Reply with quote
Burp gun is easiest. Most garages will have one that'll have them out in half a second but they may not have a long allen key to go on the end of it.
Kawasaki Jimbo
PostPosted: 01:17 - 07 Jun 2020    Post subject: Reply with quote
If there's any tension left, i.e. it's not spinning completely free, you can simulate the wind gun by snatching at the Allen key rather than applying pressure like normal, if you see what I mean. A long Allen socket is best.
kgm
PostPosted: 07:08 - 07 Jun 2020    Post subject: Reply with quote
I had one that I struggled with for a couple of hours. Took it to my local garage and had them try the buzz gun (I took the long Allen socket with me). Off in second and they didn't charge anything.
kramdra
PostPosted: 10:48 - 07 Jun 2020    Post subject: Reply with quote
It is spinning very freely, so Im not convinced, but I will try it. May need the broom handle aswell. I do have an air impact, never needed to use it. I have a set of Cr-V allen keys with the angle chopped off.
PostPosted: 10:51 - 07 Jun 2020    Post subject: Reply with quote
Today is when it pays for itself. Set it to do lots of rattles rather than big knocks. I ca\n't recall it ever taking me more than 2 seconds to get a fork bolt out though.
Confusion
PostPosted: 12:25 - 07 Jun 2020    Post subject: Re: Forks Reply with quote
That's what they do. The first time I did mine, I had to bring them
to the local tyre shop to borrow their impact wrench. Next time
should be easier with a little help from my new electric impact
wrench from Lidl.
How to remove?
If you check the service manual, you will find the correct way is
to use the special tool for holding the damper. As an alternative
you can make your own:
https://www.youtube.com/watch?v=VsNFwv2AxWE
As mentioned above, a broom handle may provide enough
friction to hold the damper in place. You may also be able
to make a suitable tool from standard plumbing parts.
ie: A brass nut brazed on the end of a copper pipe.
Use a good quality Allen socket. The bolts can be very
tight (over 60Nm on my ZZR). Using an ordinary Allen key
will probably leave you with a mangled bolt/key/knuckles
and a much bigger problem than you have now.
Bandit 650SA, ZZ-R1100
PostPosted: 13:39 - 07 Jun 2020    Post subject: Re: Forks Reply with quote
Well, not a huge problem. They are easy to drill the head off because the allen head centres the drill and the remaining stub always unscrews from the end of the damper/cartridge really easily because there's no corrosion. The main problem is waiting for replacement bolts to arrive.
kramdra
PostPosted: 19:57 - 07 Jun 2020    Post subject: Reply with quote
https://i.postimg.cc/yNWF1RSB/IMG-20200607-195022.jpg
Not a chance, just spins very fast. The rebound adjuster rod prevents me putting anything down the middle. So I will try putting it back together and pressing it with the air gun.
I remember last time the bolt rounded off and the only ones I had/ordered were stainless. Now I have all the tools for drilling stainless if needed, if only I could get the bolt to stay put!
Edit - nope, compressing the fork does not change how fast it spins.
Any ideas? I think I may have to properly degrease the bolt, and temporarily epoxy it in place, such that it can be drilled out.
PostPosted: 23:38 - 07 Jun 2020    Post subject: Reply with quote
I'm amazed the burp gun isn't shifting it with the fork assembled. Maybe try clamping it back in the yoke and compressing the fork with a ratchet strap between the calliper mount and bottom yoke.
kramdra
PostPosted: 21:09 - 08 Jun 2020    Post subject: Reply with quote
Im not convinced that would be any different. I wedged some 0.7mm copper strip around the bolt and superglued in place, drilled upto 9mm. Cant go any bigger without it spinning. I will rethink this, stronger glue or a better wedge could be a pain to remove once the damper is out.
sickpup
Old Timer
PostPosted: 22:39 - 08 Jun 2020    Post subject: Reply with quote
The knob on the bottom of the grip of the windy gun needs turning in, at the moment it looks like its on its lowest setting. Your air hose also has a small diameter so won't give full power, what is your compressor rated at?
You do have the direction on the windy gun set right?
Your bike is a 2002 model iirc which has preload and compression adjusters in the fork tops which I can't see in your picture. So just checking when you are trying to windy gun the damper bolt you do have the forks fully assembled with the fork tops in place and the forks compressed against the ground yes?
sickpup
Old Timer
PostPosted: 23:23 - 08 Jun 2020    Post subject: Reply with quote
This shouldn't be possible if the forks are assembled and compressed.
kramdra
PostPosted: 00:13 - 09 Jun 2020    Post subject: Reply with quote
You think you can see the knob position? The numbers are on the knob face, anyway I had it on highest. You are right about the hose. On the low position it just stalls easily.
I had regulator set at 6 bar, the rating of the gun. In use the regulator was dropping to about 2-3 bar with the trigger pulled. It is an SGS 2.5hp, 9.3cfm 20L compressor.
Yes they have adjusters, were fully assembled, and pressed against the ground.
I think I will make a press fit tube to knock onto the bolt head and drill through. I should have started with that instead of copper shim.
sickpup
Old Timer
PostPosted: 01:27 - 09 Jun 2020    Post subject: Reply with quote
I can see it looks quite far out.
Then it isn't getting enough air. Look at 1/2" hose for full power. I only use those curly cables for pumping up tyres.
That is likely too low when your hose is so restrictive. Needs to be measured at hose end.
So again we get to the bit I don't understand. If the bolts turn easily how did they with the copper washer provide an oil tight seal at the bottom of the fork?
<edit> Just found the closest compressor to your specs on SGS and it specifically says not suitable for impact ratchets due to the low air capacity.If you are using the original fittings they are only 1/4 so absolutely tiny and restrictive.</edit>
PostPosted: 08:16 - 09 Jun 2020    Post subject: Reply with quote
I made a tool for my TT600 out of an old lawnmower handle. It was made of box section and I cut it down so it was castellated, and then I shoved it in the top of the fork leg and used a windy gun on the allen bolt at the bottom. Worked a charm.
kramdra
PostPosted: 10:38 - 09 Jun 2020    Post subject: Reply with quote
The bolt was tight. I cracked it off with an allen key with it compressed and then it spun.
Yes compressor not ideal, replacing the fittings is a common upgrade.. I need a longer hose anyway.
sickpup
Old Timer
PostPosted: 11:24 - 09 Jun 2020    Post subject: Reply with quote
I'm not trying to be difficult here but I'm still not understanding this. If the bolt is loose enough to turn easily it is undone. If you have cracked it then its undone so where is the difficulty here in getting it out?
I really am genuinely not understanding what is happening here. Its either undone or it isn't unless someone did something stupid like jam it up with thread lock or crossed the threads when fitting it. Even then compressing the forks would lock the damper in place.
As these are a cartridge fork and not a basic damper rod with holes in it fork I'm not sure you can't jam a broom stick down it to lock the damper rod.
<edit>I just noticed you said the below. Fork damper bolts are in my experience fine threaded metric which is pretty unusual. Did you jam a standard metric bolt into the damper?</edit>
And how did you round off the bolt head anyway?
Irezumi
PostPosted: 11:38 - 09 Jun 2020    Post subject: Reply with quote
Just get an aluminium tube then cut a couple of notches out to hold the rod in place, allen key will be all that is needed then. Why have you not taken the stanchions out already, will make life a lot easier?
kramdra
PostPosted: 12:00 - 09 Jun 2020    Post subject: Reply with quote
I followed the manual and used threadlock. I have not mixed fine and coarse threads but I dont remember what it was, will find out soon enough.
The original bolt was soft and took no effort to round, as is common for low grade cap head bolts.
Now, I have no idea what the bolt is. 8mm key should be M10, but then the head would be 16mm and wont fit the 15.8mm bore in the forks. I dont remember grinding down the bolt head OD. Now I made up a tool expecting the head atleast 15mm, and it is not. Plenty of length I will try again 14mm and enlarge until I get a good fit, then turn the end off and go 0.1 tighter.
https://i.postimg.cc/RZBsdWcQ/IMG-20200609-142834.jpg
Edit - bolt head was 14.75mm OD
Tdibs
PostPosted: 16:53 - 09 Jun 2020    Post subject: Reply with quote
I dont get it, if the bolt is already cracked, then you just need some pressure on the cartridge/damper to stop it spinning in place?
It cant be spinning if the cartridge is static? unless the thread is gone.
kramdra
PostPosted: 20:48 - 09 Jun 2020    Post subject: Reply with quote
Tool is done. Great success.
https://i.postimg.cc/X7387C7y/IMG-20200609-202434.jpg
But what the shitting fuck is this? At first I thought I had drilled too far but it appears to be a banjo bolt!
https://i.postimg.cc/PxYWdtg4/IMG-20200609-204133.jpg
I have zero memory of this. I have zero memory of ever seeing or owning a cap head banjo bolt, possibly it is original and was not rounded or replaced last time.
It may have been one of my other bikes I replaced with an off the shelf, stainless.
Edit - And it still fucking spins. Note that the spring assemply presses on the body of the damper tube, excerts zero pressure on the bolt, hence compressing had no effect. The damper rod itself does press on the "bolt assembly" but would probably bend if you tried it.
Small circlip removes the bolt assembly. The valve? end looks complicated. This is no problem the er40 chuck will hold the body tight to remove the bolt.
https://i.postimg.cc/nhVf7rTX/IMG-20200609-205529.jpg
https://i.postimg.cc/grFR51S7/IMG-20200609-211125.jpg
The thread is M10 x 1.25mm.
Robby
Dirty Old Man
PostPosted: 21:55 - 09 Jun 2020    Post subject: Reply with quote
I'm slightly concerned about you being allowed near a lathe.
sickpup
Old Timer
PostPosted: 10:32 - 10 Jun 2020    Post subject: Reply with quote
Just checked the Honda fiche and that is the correct type bolt for your fork leg. Its so oil can pass from within the damper rod into the main body of the fork leg.
Well it wouldn't spin if the fork was assembled and compressed and the damper rod wouldn't bend. The fork compresses without it bending in use so it wouldn't bend while windy gunning the bolt.
So the one question you haven't answered here is if the bolt was the correct thread pitch and as we can't see any threadlock so it wasn't coated in it why is it seized in the damper assembly?
As an aside have you ever considered that your tools are absolute crap and that maybe you should invest in some decent ones? If you are going to continue working on bikes maybe buy decent spanners instead of ones from Lidl.
The last post was made 6 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 134.74 Kb
