| kramdra |
 kramdra World Chat Champion
| Bhud |
 Bhud World Chat Champion
| Kawasaki Jimbo |
| kgm |
 kgm World Chat Champion
| kramdra |
| Confusion |
 Confusion Scooby Slapper
| kramdra |
 Posted: 19:57 - 07 Jun 2020 Post subject: |
https://i.postimg.cc/yNWF1RSB/IMG-20200607-195022.jpg
Not a chance, just spins very fast. The rebound adjuster rod prevents me putting anything down the middle. So I will try putting it back together and pressing it with the air gun.
I remember last time the bolt rounded off and the only ones I had/ordered were stainless. Now I have all the tools for drilling stainless if needed, if only I could get the bolt to stay put!
Edit - nope, compressing the fork does not change how fast it spins.
Any ideas? I think I may have to properly degrease the bolt, and temporarily epoxy it in place, such that it can be drilled out. |
 Posted: 23:38 - 07 Jun 2020 Post subject: |
I'm amazed the burp gun isn't shifting it with the fork assembled. Maybe try clamping it back in the yoke and compressing the fork with a ratchet strap between the calliper mount and bottom yoke. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kramdra |
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
| kramdra |
| sickpup |
 sickpup Old Timer
 Posted: 01:27 - 09 Jun 2020 Post subject: |
| kramdra wrote: | You think you can see the knob position? |
I can see it looks quite far out.
| kramdra wrote: | The numbers are on the knob face, anyway I had it on highest. You are right about the hose. On the low position it just stalls easily. |
Then it isn't getting enough air. Look at 1/2" hose for full power. I only use those curly cables for pumping up tyres.
| kramdra wrote: | I had regulator set at 6 bar, the rating of the gun. In use the regulator was dropping to about 2-3 bar with the trigger pulled. It is an SGS 2.5hp, 9.3cfm 20L compressor. |
That is likely too low when your hose is so restrictive. Needs to be measured at hose end.
| kramdra wrote: | Yes they have adjusters, were fully assembled, and pressed against the ground. |
So again we get to the bit I don't understand. If the bolts turn easily how did they with the copper washer provide an oil tight seal at the bottom of the fork?
<edit> Just found the closest compressor to your specs on SGS and it specifically says not suitable for impact ratchets due to the low air capacity.If you are using the original fittings they are only 1/4 so absolutely tiny and restrictive.</edit> |
| MarJay |
 MarJay But it's British!
| kramdra |
| sickpup |
 sickpup Old Timer
| Irezumi |
 Irezumi Nitrous Nuisance
| kramdra |
 Posted: 12:00 - 09 Jun 2020 Post subject: |
I followed the manual and used threadlock. I have not mixed fine and coarse threads but I dont remember what it was, will find out soon enough.
The original bolt was soft and took no effort to round, as is common for low grade cap head bolts.
Now, I have no idea what the bolt is. 8mm key should be M10, but then the head would be 16mm and wont fit the 15.8mm bore in the forks. I dont remember grinding down the bolt head OD. Now I made up a tool expecting the head atleast 15mm, and it is not. Plenty of length I will try again 14mm and enlarge until I get a good fit, then turn the end off and go 0.1 tighter.
https://i.postimg.cc/RZBsdWcQ/IMG-20200609-142834.jpg
Edit - bolt head was 14.75mm OD |
| Tdibs |
 Tdibs Traffic Copper
| kramdra |
 Posted: 20:48 - 09 Jun 2020 Post subject: |
Tool is done. Great success.
https://i.postimg.cc/X7387C7y/IMG-20200609-202434.jpg
But what the shitting fuck is this? At first I thought I had drilled too far but it appears to be a banjo bolt!
https://i.postimg.cc/PxYWdtg4/IMG-20200609-204133.jpg
I have zero memory of this. I have zero memory of ever seeing or owning a cap head banjo bolt, possibly it is original and was not rounded or replaced last time.
It may have been one of my other bikes I replaced with an off the shelf, stainless.
Edit - And it still fucking spins. Note that the spring assemply presses on the body of the damper tube, excerts zero pressure on the bolt, hence compressing had no effect. The damper rod itself does press on the "bolt assembly" but would probably bend if you tried it.
Small circlip removes the bolt assembly. The valve? end looks complicated. This is no problem the er40 chuck will hold the body tight to remove the bolt.
https://i.postimg.cc/nhVf7rTX/IMG-20200609-205529.jpg
https://i.postimg.cc/grFR51S7/IMG-20200609-211125.jpg
The thread is M10 x 1.25mm. |
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
The last post was made 6 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
