Dodgy wifi or dodgy ISP?
Freddyfruitba...
PostPosted: 12:23 - 07 Jun 2020    Post subject: Dodgy wifi or dodgy ISP? Reply with quote
I quite often find that my home wifi and/or fixed-connection internet speed goes really slow or intermittent. Sometimes helped by turning everything off-and-on-again, sometimes not; and I suspect the main cause may be the actual signal which is coming into the house as opposed to problems inside the house.
This is probably a really numpty question, but how can I quickly and easily assess the ISP's signal and determine whether it's that or something else, under my control? It's particularly a PITA because the signal on my devices very rarely stops, it just slows down, which makes it harder to pinpoint.
FWIW I'm on Virgin, with a BT Whole Home mesh wifi network hooked up the Virgin modem.
bugeye_bob
PostPosted: 15:58 - 07 Jun 2020    Post subject: Re: Dodgy wifi or dodgy ISP? Reply with quote
Is this after long periods of not using the internet?
My mate is on Virgin and as he works away and doesn't use the internet at home for long periods, his speed gets throttled to a slow speed, he has to call them up and it goes back to 200 meg or something close.
duhawkz
PostPosted: 16:29 - 07 Jun 2020    Post subject: Reply with quote
first step would be to conduct a speed test, with the a computer connected via cable directly to the router. To see if you're getting the advertised speed for you line.
use speedtest.net or https://speedtest.btwholesale.com
then try it again when its slowing down to see if your line speed has dropped.
xX-Alex-Xx
PostPosted: 17:12 - 07 Jun 2020    Post subject: Reply with quote
If you want to rule out WiFi, connect your laptop to the router with a network cable.
My wife’s parents are on Virgin, and after seeing their performance I wouldn’t touch them with a barge pole. Yes they advertise the fastest speeds, but from what I’ve seen their internet drops for a least a few minutes a few times every day.
My VDSL with plusnet is “only” 70Mb/s but I’ve had literally zero downtime (that I’ve noticed) and that’s impressive considering I work from home and rely on it all day.
DILLIGAF
PostPosted: 20:55 - 07 Jun 2020    Post subject: Reply with quote
xX-Alex-Xx wrote:
but from what I’ve seen their internet drops for a least a few minutes a few times every day..
Well you've seen a very odd case that they should look in to. Fibre doesn't work like that and if it did it would be widely affecting a bunch of folk.
Virgin are not bad in the slightest, their boxes are. Only thing it's good for is modem only mode. Do that.
Hong Kong Phooey
PostPosted: 12:55 - 26 Jun 2020    Post subject: Reply with quote
Plenty of shitty routers used by ISPs.
Buggy wifi, old firmware, causing slow speeds or dropped connections. Changing for the same model sometimes helps, other times mithering them to push for a better router does it.
PostPosted: 16:05 - 26 Jun 2020    Post subject: Reply with quote
If we are talking about providers, at the moment I am on BT with about 40mbps.
Vodafone have installed fibre in our street and are advertising much faster and cheaper. Does anyone actually know if they are any good bearing in mind I've never had any problems with BT other than the price.
Triumph Trophy Launch Edition
xX-Alex-Xx
PostPosted: 17:37 - 26 Jun 2020    Post subject: Reply with quote
Steer clear of Vodafone. It’s great when it works, but they leave you for days if anything goes wrong. Bills will go up at least 10 quid a month more than what you signed up by the end of your contract. They also tag random charges on when you want to leave, hoping you won’t notice.
DILLIGAF
panrider_uk
PostPosted: 18:39 - 27 Jun 2020    Post subject: Reply with quote
I use Vodafone for home (business) broadband) and it's fine.
I have the ocasional dropout from the router (had that with BT and Talktalk before them so they're all crap in that respect) but have my own good router to install when I find my round tuit.
Speeds are good and price is good.
Our leased line at work is provided by NTE and runs over Vodafone's network.
Good speeds on that too (as you'd expect on a leased line), very reliable and several thousand £ a year cheaper than BT.
duhawkz
PostPosted: 22:38 - 28 Jun 2020    Post subject: Reply with quote
I've had vodafone fibre for a couple of years now, I haven't had issues with it.
I think I'm paying around £33 a month for 76mb fibre and evening and weekend calls
McHattrick
PostPosted: 23:37 - 28 Jun 2020    Post subject: Reply with quote
I have been with BT for years and they are generally pretty good.
I got a call from them earlier in the year with an offer to upgrade to fibre and it was working out about same as I was already paying (phone and internet). so how could i refuse.
They threw in one of their extenders which is brilliant. We now have coverage all over top floor (I previously used Netgear extender but it is not a patch on BTs).
We are running 2 x PS4, streaming Netflix, 2 or 3 PCs, tablets.. all at same time without a blip.
Worth a call.. suggest you are thinking about changing ISP..
If it aint broke... fix 'til it is.
The last post was made 6 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 69.39 Kb
