| Bhud |
 Bhud World Chat Champion
 Posted: 11:38 - 17 Jun 2020 Post subject: Plugging up holes in fork stanchions |
Anyone know about vintage air assist systems?
I'm in the process of putting my Kawasaki GT550 back together. Like many 80s bikes, it has air-assisted forks. These are bog standard, simple 70s-style forks, with a single difference: they rely on air pressure and the forks' spring rate to provide resistance. There's a little hole along each fork stanchion, and a joining assembly between them, and a single Schrader valve that has to be pumped up (min. 11 psi).
I want to remove this air assist system and replace it with new progressive fork springs and spacers. The reasons: 1) it's nearly 40 years old, and while it still holds air and works, who knows when the rubber seals might give; 2) the front suspension works no better than a simple old-school motorcycle fork system; 3) I really want to give progressive springs a try.
I've been in touch with a few makers of prog springs, and they won't do it my way. They suggest replacing the entire fork internals with cartridge emulators, and new damping assembly. Plus use linear rate springs instead of progressive. However, I am pretty sure that I could get away with simply replacing the springs and putting the standard fork oil amount, if I could stop up those air assist holes on the stanchions.
Is this a dumb idea? If not, any thoughts on how I could plug up those holes? |
| Bhud |
 Posted: 15:13 - 17 Jun 2020 Post subject: |
Cheers, looks like it might work. The holes are about 3mm in diameter, so if I make them wider I could stuff them with one of those little plugs.
I'm hoping it won't come to that, because there's no turning back from that point. I thought of another solution: covering the holes with the lower fork yoke. To my mind, in theory, that should work, if I turn them so they face inwards and position the stanchions so that the holes face the steel of the yokes. This ought to be enough to stop a pumping-out effect. I'll give it a try with 15W fork oil and long spacers. The springs themselves look like normal springs, but are noticeable softer, with 2 clear coil frequencies. The replacements sold by the likes of Ikon appear to be just like-for-like, with exactly the same length. I think if I beef up the existing springs with a spacer, and cover up the holes, it should sort of work. |
| F18 |
 F18 Renault 5 Driver
| Bhud |
 Posted: 15:38 - 17 Jun 2020 Post subject: |
You're right, it worked OK, but it was not a sophisticated system. Picture just an ordinary fork, with a spring and a damper rod and oil. Halfway up each stanchion, there's a 3mm hole. You put an air balancer (just a steel bracket with a cavity and a Schrader valve) in between where these holes are, when the bike is assembled. The balancer has rubber seals above and below, to hold in the air. You inflate it through the Schrader valve, and each fork now has internal air pressure higher than atmospheric pressure.
The only difference from any other basic motorcycle forks is this air assist balancer system, and softer springs. The thinking must have been, air under pressure provides a more progressive resistance than a spring on its own. The standard rear shocks have a similar system. As a result, this bike is incredibly comfortable. However, besides having crumbly old seals that look like they shouldn't be going back on, it's not a "tight" feeling ideal for handling. What I'm looking to achieve is a well-maintained suspension system, a specific amount of static sag with me on the bike (which you can't get with the standard suspension setup), a certain rebound rate suitable for hard braking, minimal dive, etc. The rear shocks have already been replaced (not with Chinese junk) to achieve the handling characteristics I want, and I would like the performance of the front to match.
| kramdra |
 kramdra World Chat Champion
| Bhud |
| Bhud |
The last post was made 6 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
