Plugging up holes in fork stanchions
Bhud
PostPosted: 11:38 - 17 Jun 2020    Post subject: Plugging up holes in fork stanchions Reply with quote
Anyone know about vintage air assist systems?
I'm in the process of putting my Kawasaki GT550 back together. Like many 80s bikes, it has air-assisted forks. These are bog standard, simple 70s-style forks, with a single difference: they rely on air pressure and the forks' spring rate to provide resistance. There's a little hole along each fork stanchion, and a joining assembly between them, and a single Schrader valve that has to be pumped up (min. 11 psi).
I want to remove this air assist system and replace it with new progressive fork springs and spacers. The reasons: 1) it's nearly 40 years old, and while it still holds air and works, who knows when the rubber seals might give; 2) the front suspension works no better than a simple old-school motorcycle fork system; 3) I really want to give progressive springs a try.
I've been in touch with a few makers of prog springs, and they won't do it my way. They suggest replacing the entire fork internals with cartridge emulators, and new damping assembly. Plus use linear rate springs instead of progressive. However, I am pretty sure that I could get away with simply replacing the springs and putting the standard fork oil amount, if I could stop up those air assist holes on the stanchions.
Is this a dumb idea? If not, any thoughts on how I could plug up those holes?
PostPosted: 12:41 - 17 Jun 2020    Post subject: Reply with quote
Hard to visualise what you have there but I'd imagine you could tap a thread into the holes and loctite a tapered plug in. What diameter is the hole?
https://www.ebay.co.uk/itm/1-16-2-BSPT-NPT-Male-Carbon-Steel-Countersunk-End-Plug-Hex-Socket-Hydraulic/283524266011?hash=item42035cf81b:g:6PIAAOSwffBdDcum
PostPosted: 12:51 - 17 Jun 2020    Post subject: Reply with quote
Another option to retain the air assist but do away with the complex seal arrangement would be to fit a couple of these in the holes. Schrader valves rarely fail and if they do, they are easily replaced.
https://www.ebay.co.uk/itm/2-GENUINE-SCHRADER-TYRE-VALVE-1-8-CAR-TRUCK-MOTORCYCLE-WHEEL-AIR-TANK-DRAIN-TAP/264530939715?hash=item3d9745cf43:g:I5oAAOSwY3VeeGxj
Bhud
PostPosted: 15:13 - 17 Jun 2020    Post subject: Reply with quote
Cheers, looks like it might work. The holes are about 3mm in diameter, so if I make them wider I could stuff them with one of those little plugs.
I'm hoping it won't come to that, because there's no turning back from that point. I thought of another solution: covering the holes with the lower fork yoke. To my mind, in theory, that should work, if I turn them so they face inwards and position the stanchions so that the holes face the steel of the yokes. This ought to be enough to stop a pumping-out effect. I'll give it a try with 15W fork oil and long spacers. The springs themselves look like normal springs, but are noticeable softer, with 2 clear coil frequencies. The replacements sold by the likes of Ikon appear to be just like-for-like, with exactly the same length. I think if I beef up the existing springs with a spacer, and cover up the holes, it should sort of work.
F18
PostPosted: 15:27 - 17 Jun 2020    Post subject: Reply with quote
Will the seals be happy in oil ?
I'd go with your manufacturer, build some designed for the job.
- actually, and especially as they don't leak now, I'd stick with the air; it worked okay.
Summer is just around the corner
Bhud
PostPosted: 15:38 - 17 Jun 2020    Post subject: Reply with quote
You're right, it worked OK, but it was not a sophisticated system. Picture just an ordinary fork, with a spring and a damper rod and oil. Halfway up each stanchion, there's a 3mm hole. You put an air balancer (just a steel bracket with a cavity and a Schrader valve) in between where these holes are, when the bike is assembled. The balancer has rubber seals above and below, to hold in the air. You inflate it through the Schrader valve, and each fork now has internal air pressure higher than atmospheric pressure.
The only difference from any other basic motorcycle forks is this air assist balancer system, and softer springs. The thinking must have been, air under pressure provides a more progressive resistance than a spring on its own. The standard rear shocks have a similar system. As a result, this bike is incredibly comfortable. However, besides having crumbly old seals that look like they shouldn't be going back on, it's not a "tight" feeling ideal for handling. What I'm looking to achieve is a well-maintained suspension system, a specific amount of static sag with me on the bike (which you can't get with the standard suspension setup), a certain rebound rate suitable for hard braking, minimal dive, etc. The rear shocks have already been replaced (not with Chinese junk) to achieve the handling characteristics I want, and I would like the performance of the front to match.
kramdra
PostPosted: 15:48 - 17 Jun 2020    Post subject: Reply with quote
Can you get a photo? How does the air balancer part 51044 attach? Is it a split clamp with seals top and bottom?
A strip of rubber sheet blocking the air hole inside the balancer clamp would probably be adequate and reversable.
The fork tubes being quite thin are not ideal to take a thread for a plug.
Bhud
PostPosted: 16:01 - 17 Jun 2020    Post subject: Reply with quote
No, it's in one piece and it slips over the stanchions (you install and remove it by pulling the fork down and away from the top yoke).
That's a great idea - might give it a go. But probably under the lower bottom yoke, as I'm managing the space in between the yokes (I've fitted a top yoke from a different bike in order to fit a normal handlebar instead of the standard clip-ons). I could put the balancer back on easily, but only by cutting away the bottom of the headlight mounting brackets to make space, which I'd rather not, unless absolutely necessary.
Yes, I agree. They are extremely thin. If the worst comes to the worst and I end up trying to plug the holes and ruining the forks, replacement forks for this bike are cheap. I don't think it will come to that, though. I have enough fork oil for an experiment, and I'll see what happens if I let the lower fork yoke block up the holes.
Bhud
PostPosted: 20:11 - 17 Jun 2020    Post subject: Reply with quote
Put back together, with 3-inch steel spacers. Bounced around a lot, with roughly 250ml 15W fork oil in each fork (exact level should be 255ml). No fork oil leaks. So far so good! Sag is in the right ballpark. Will have to take it for a brief run to check no oil is seeping before taking measurements and cutting precise spacers, and dumping the (new) oil and putting in the right amount. But I think I'm there.
The last post was made 6 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 63.95 Kb
