gsx600f clutch problem
mmartian71
PostPosted: 21:09 - 31 Mar 2005    Post subject: gsx600f clutch problem Reply with quote
hi newbie here with what maybe a daft question i have a gsx600f that i am slowly getting back into running order after sitting for 2 years. i have just removed the cluch cleaned and reoiled it, and replaced it exactly as it came out but previous to removing it i could slip it into gear and turn the back wheel by hand now i am still able to engage the gears but the wheel will not turn, any ideas would be greatly appreciated. Many thanks
PostPosted: 14:38 - 01 Apr 2005    Post subject: Reply with quote
How much of the clutch did you take apart? Just take the plates out?
On the Bandit (and the Teapot which has the same engine I presume) the clutch cable connects down to a unit on the sprocket which then pushes a long rod through the gearbox to the centre of the clutch. Often there is a ball bearing at one end of the rod and these can get lost. Worth checking, depending on how much you have stripped down.
mmartian71
PostPosted: 14:57 - 01 Apr 2005    Post subject: Reply with quote
hi i took the plates out and the sprocket that the cable is attached to along with the rod that goes from it into the engine.
The last post was made 21 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 36 Kb
