Bolts, Oil, Torque ?
droog
PostPosted: 11:16 - 15 Aug 2020    Post subject: Bolts, Oil, Torque ? Reply with quote
Hi, I trust everyone is enjoying their weekend. Smile
I'm fitting the CBR cam holder and have been referring to the Honda Shop manual and the Haynes manual for the CBR600.
The Honda shop manual and the Haynes manual seem to contradict each other regarding oiling the cam holder bolts:
The Honda Shop manual recommends oiling the cam holder bolts prior to refitting the camholder:
'Apply engine oil to the threads and seating surfaces of the camshaft holder bolts'.
The Haynes on the other hand doesn't mention oiling the bolts and even warns not to get any engine assembly lube or engine oil into the cam holder bolt holes as this will:
'affect the tightness of the bolts and the seating of the holder'
My personal understanding is that oil on bolt threads can throw off the intended torque wrench setting (12 Nm in this case) and can lead to either an over-tightened or under tightened bolt.
On that basis my instinct is to agree with the Haynes and leave the bolts dry - but on the other hand it was Honda who designed and built the bike and wrote the manual and presumably woulld have specifically prescribed 12 Nm in torque for an oiled bolt and not a dry bolt - so surely the shop manual is right in this and I should be oiling the bolts?
(the cam holder bolts came out as dry as a bone and showed no signs that they had ever been oiled in the first place).
Cheers for any advice.
PostPosted: 11:28 - 15 Aug 2020    Post subject: Reply with quote
Well, I would generally go with the manufacturers workshop manual over an aftermarket one. They usually have a little indicator on the exploded diagram for which lubricants should be applied where too.
It does seem quite unequivocal in its written description though.
Probably less likely to snap if overtightened than a more traditional cam cap anyway.
Remember a torque wrench isn't a panacea, if it feels like you're overtightening, stop.
droog
PostPosted: 12:42 - 15 Aug 2020    Post subject: Reply with quote
Thanks Stinkwheel - I appreciate your perspective on this. I'll go with the shop manual as you advised - I'm not really in a position to contradict Honda on how to reassemble their engines Mr. Green
Thanks also for the sage advice regarding the torque wrench - yeah - it's easy to put too much faith in the torque wrench sometimes and end up bypassing common sense and 'feel' resulting in a snapped bolt.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:47 - 15 Aug 2020    Post subject: Reply with quote
By the same token, the official workshop manual for a particular bike states 'use threadlock' in a situation where it clearly shouldn't be used....
Triumph Sprint ST 1050
Bhud
PostPosted: 12:48 - 15 Aug 2020    Post subject: Reply with quote
I am not an engineer. What I usually do is give them a quick blast with carb cleaner in case they picked up any debris from the bench or the floor, before putting them back in the head.
In that application, where you have very low torque fasteners, in my view overtightening could occur if the bolt is oiled or greased, therefore I don't do it. Also, it seems to be unnecessary, because you have mild steel bolts going into aluminium, the bolt's head getting sloshed over with lots of oil or just sitting there with a film of oil. This means it's highly unlikely that ionic transfer would take place between a cathodic steel bolt and an anodic aluminium threaded hole.
In your case, what I would guess has happened is that when Honda assembled the engine, they applied an anti-corrosion compound to those bolts. Subsequently, either the act of removing the bolts, or handling them after removing them, caused that compound to be removed as well. Honda, probably anticipating this, advises you to then oil the bolts with engine oil when reusing them. I don't know for sure that this is the cause. However, I would be surprised if those bolts could suffer galvanic corrosion.
PostPosted: 12:53 - 15 Aug 2020    Post subject: Reply with quote
You could also look them up on an engineering chart to see if the torque value they are quoting fits with an oiled or dry fastener of that size, thread and grade.
jeffyjeff
Words of wisdom. Likely gained by experience. I, for one, have stripped threads when using a properly calibrated and adjusted torque wrench; trusting the wrench and torque spec more than my own sense and inner voice.
droog
PostPosted: 13:11 - 15 Aug 2020    Post subject: Reply with quote
Yeah me too - when I fiirst started spannering I thought that an accurate torque wrench coupled with a shop manual torque rating was a failsafe and infallible combination - but it ain't necessarily so.
droog
PostPosted: 13:13 - 15 Aug 2020    Post subject: Reply with quote
That's excellent advice - thanks Stinkwheel - I'll check that out - much appreciated!
droog
PostPosted: 13:16 - 15 Aug 2020    Post subject: Reply with quote
Thanks Bhud - yeah agree - based on past experience the overtightening of oiled bolts is exactly what I am scared off - thanks for the advice and detail - very interesting. Very Happy
droog
PostPosted: 13:17 - 15 Aug 2020    Post subject: Reply with quote
Yeah good point - neither the Shop or Haynes manuals are infallible - they also make mistakes.
MCN
PostPosted: 18:24 - 15 Aug 2020    Post subject: Reply with quote
Did you set a lbs/in torque using a lbs/ft wrench. 😎
PostPosted: 18:56 - 15 Aug 2020    Post subject: Reply with quote
OK, not specifically motor cycle applications but on 99.99% of machinery I have worked on they specify torque on a dry bolt or with a specific thead treatement ie, Loctite 242 or similar.
If it's a wet bolt, they normally say hand tight plus a specific further tuen of the bolt, ie, hand tight plus 180 degrees or plus 1/4 of a turn.
I would certainly not trust using a torgue wrench on a low torque oiled bolt, it's an instant receipe for disater in my view.
droog
PostPosted: 19:35 - 15 Aug 2020    Post subject: Reply with quote
Hi Polarbear - yes - I've been mulling it over and I'll skip the oil and stick with a dry bolt with the torque wrench.
I've got a decent, brand new, low range (4 Nm to 20 Nm) torque wrench but to be honest I've even got a bit spooked about using that and am wondering if I should just use a standard wrench and go by feel instead?
I've done plenty of spannering but this is the first time I've worked on the cylinder head so I'm reviewing every step.
PostPosted: 19:40 - 15 Aug 2020    Post subject: Reply with quote
You will be amazed how quickly that torque wrench clicks. Small torques are so misleading. It clicks while you think it is still slack. Just don't think, 'a nip up for luck'.
droog
PostPosted: 19:49 - 15 Aug 2020    Post subject: Reply with quote
Cheers Polarbear - my plan is to tighten the bolts in sequence with a conventional wrench a quarter turn at a time - when the bolts are kissing the surface of the cam-holder I'll bring out the torque wrench and tighten each bolt to torque spec in sequence.
If the bolt is feeling tight I won't force a click.
smokin joe
PostPosted: 20:04 - 15 Aug 2020    Post subject: Reply with quote
A couple of times I've tried a torque wrench when fitting plugs to both cars and bikes, thought they felt way too tight before the wrench clicked and backed them off before using a plug spanner and going by feel. I've never had one come loose, but I'd rather that than hearing that horrible bang that denotes a stripped thread.
droog
PostPosted: 20:20 - 15 Aug 2020    Post subject: Reply with quote
Yeah - I agree - with the spark plugs I always used a spanner and went with the mantra;
Brand new spark plug: Half Turn after the plug initially seats to compress the crush washer.
Re-fiitting old spark plug: Quarter turn after the plug initially seats.
But for working on engine components everyone advises using a (calibrated) torque wrench.
jeffyjeff
PostPosted: 05:36 - 16 Aug 2020    Post subject: Reply with quote
Ha ha. I think I'll send that dammed 1/2" drive lbs/inch torque wrench back to Amazon. It's done nothing but strip out every fastener I've used it on...even when I put a 4 foot cheater on it. POS Crying or Very sad
Easy-X
PostPosted: 09:53 - 16 Aug 2020    Post subject: Reply with quote
Also, know your materials. Be extra weary of something like a 6mm bolt going into an aluminium block, e.g. exhaust manifold, versus steel on steel which can take much more torque.
droog
PostPosted: 10:21 - 16 Aug 2020    Post subject: Reply with quote
Yeah, excellent point - I'm super cautious around aluminium, steel bolts and torque wrenches these days - based on past experiences which involved reverse drill bits and helicoil kits. Very Happy
kramdra
PostPosted: 13:32 - 16 Aug 2020    Post subject: Reply with quote
Not true if you use the proper torque wrench. It is a bad idea to use a 7-112nm wrench on a 12nm bolt, but a small 4-20nm wrench will be perfect.
My wrench is a Sealey 4-20nm. I oiled the cam cap bolt threads and followed the process. I had to remove the cams about 5 times and no damage has occured to the bolts or head.
droog
PostPosted: 14:48 - 16 Aug 2020    Post subject: Reply with quote
That's encouraging kramdra Smile
I've got new oil seals and washers for the cam-holder which I don't want to torque down until I'm sure the adjusted clearances are correct and the compression is back on cylinder 2 (fingers crossed) - so I'm going to do a test fitting/reassembly using the old washers and seals before I use the new parts.
If the clearances are correct and I've got decent compression back on cylinder two the camholder is coming off again to fit the new oil seals and washers.
kramdra
PostPosted: 15:05 - 16 Aug 2020    Post subject: Reply with quote
If you have them, just fit it. I did not bother to replace mine they were still good, no leaks.
droog
PostPosted: 15:37 - 16 Aug 2020    Post subject: Reply with quote
Yep - may do that if the clearances are in spec and I've got compression back. Cheers.
The last post was made 6 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 131.17 Kb
