| droog |
 droog Spanner Monkey
 Posted: 11:16 - 15 Aug 2020 Post subject: Bolts, Oil, Torque ? |
Hi, I trust everyone is enjoying their weekend.
I'm fitting the CBR cam holder and have been referring to the Honda Shop manual and the Haynes manual for the CBR600.
The Honda shop manual and the Haynes manual seem to contradict each other regarding oiling the cam holder bolts:
The Honda Shop manual recommends oiling the cam holder bolts prior to refitting the camholder:
'Apply engine oil to the threads and seating surfaces of the camshaft holder bolts'.
The Haynes on the other hand doesn't mention oiling the bolts and even warns not to get any engine assembly lube or engine oil into the cam holder bolt holes as this will:
'affect the tightness of the bolts and the seating of the holder'
My personal understanding is that oil on bolt threads can throw off the intended torque wrench setting (12 Nm in this case) and can lead to either an over-tightened or under tightened bolt.
On that basis my instinct is to agree with the Haynes and leave the bolts dry - but on the other hand it was Honda who designed and built the bike and wrote the manual and presumably woulld have specifically prescribed 12 Nm in torque for an oiled bolt and not a dry bolt - so surely the shop manual is right in this and I should be oiling the bolts?
(the cam holder bolts came out as dry as a bone and showed no signs that they had ever been oiled in the first place).
Cheers for any advice. |
| stinkwheel |
 Posted: 11:28 - 15 Aug 2020 Post subject: |
Well, I would generally go with the manufacturers workshop manual over an aftermarket one. They usually have a little indicator on the exploded diagram for which lubricants should be applied where too.
It does seem quite unequivocal in its written description though.
Probably less likely to snap if overtightened than a more traditional cam cap anyway.
Remember a torque wrench isn't a panacea, if it feels like you're overtightening, stop. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| droog |
| Nobby the Bastard |
| Bhud |
 Bhud World Chat Champion
 Posted: 12:48 - 15 Aug 2020 Post subject: |
I am not an engineer. What I usually do is give them a quick blast with carb cleaner in case they picked up any debris from the bench or the floor, before putting them back in the head.
In that application, where you have very low torque fasteners, in my view overtightening could occur if the bolt is oiled or greased, therefore I don't do it. Also, it seems to be unnecessary, because you have mild steel bolts going into aluminium, the bolt's head getting sloshed over with lots of oil or just sitting there with a film of oil. This means it's highly unlikely that ionic transfer would take place between a cathodic steel bolt and an anodic aluminium threaded hole.
In your case, what I would guess has happened is that when Honda assembled the engine, they applied an anti-corrosion compound to those bolts. Subsequently, either the act of removing the bolts, or handling them after removing them, caused that compound to be removed as well. Honda, probably anticipating this, advises you to then oil the bolts with engine oil when reusing them. I don't know for sure that this is the cause. However, I would be surprised if those bolts could suffer galvanic corrosion. |
| stinkwheel |
 Posted: 12:53 - 15 Aug 2020 Post subject: |
You could also look them up on an engineering chart to see if the torque value they are quoting fits with an oiled or dry fastener of that size, thread and grade. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| droog |
| droog |
| droog |
 Posted: 13:16 - 15 Aug 2020 Post subject: |
| Bhud wrote: | I am not an engineer. What I usually do is give them a quick blast with carb cleaner in case they picked up any debris from the bench or the floor, before putting them back in the head.
Thanks Bhud - yeah agree - based on past experience the overtightening of oiled bolts is exactly what I am scared off - thanks for the advice and detail - very interesting.  |
| droog |
| MCN |
 MCN Super Spammer
| Polarbear |
 Polarbear Super Spammer
| droog |
| Polarbear |
| droog |
| smokin joe |
 smokin joe Borekit Bruiser
| droog |
| jeffyjeff |
| Easy-X |
 Easy-X Super Spammer
 Posted: 09:53 - 16 Aug 2020 Post subject: |
Also, know your materials. Be extra weary of something like a 6mm bolt going into an aluminium block, e.g. exhaust manifold, versus steel on steel which can take much more torque. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| droog |
| kramdra |
 kramdra World Chat Champion
| droog |
| kramdra |
| droog |
The last post was made 6 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
