| stirlinggaz |
 stirlinggaz World Chat Champion
| stinkwheel |
| MarJay |
 MarJay But it's British!
 Posted: 20:16 - 17 Aug 2020 Post subject: |
https://www.nitron.co.uk/products/motorcycles/ntr-r1-shock ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| jeffyjeff |
 jeffyjeff World Chat Champion
| stirlinggaz |
| stirlinggaz |
 Posted: 06:23 - 18 Aug 2020 Post subject: |
Hi,
Nice shocks but don't list 1 for my bike.
I'm presuming they don't do custom builds which would be out of my price range anyway.
cheers,
GAZ |
| stinkwheel |
 Posted: 08:30 - 18 Aug 2020 Post subject: Re: Rear shock cross compatibility? |
| stirlinggaz wrote: |
Hi,
Why? I'm unable to find an oem replacement for it. |
So we can get an idea of what the original one looks like to see if there is anything odd about it. or even to confirm it's a mono or twin shock, which was implied but not 100% clear in your OP. Not all shocks are made the same way. Some have oddball mountings, other have a shorter sprung area with a longer damper section to fit through bits of frame etc.
So it's a TDR125? Which from pictures appears to be a mostly vanilla, preload adjustable monoshock with an unusually wide top mount.
It's mostly about the length and spring rate and there certainly are Chinese places online that sell shocks by length so if you were to get one that length designed for a roughly equivalent weight bike, you'll probably be close on the money. As with all chinese stuff, quality varies massively so you take a gamble. i do know quite a few club racers who use them so good ones are out there.
That top mount is a little trickier, you're probably going to need to make up a couple of alloy or steel spacers. You might be able to cut down the original sleeve for this. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| stirlinggaz |
| stirlinggaz |
| stinkwheel |
| Kris |
 Kris World Chat Champion
| stirlinggaz |
| kgm |
 kgm World Chat Champion
 Posted: 18:14 - 19 Aug 2020 Post subject: |
| Kris |
| Riejufixing |
 Riejufixing World Chat Champion
| stirlinggaz |
 Posted: 20:06 - 19 Aug 2020 Post subject: |
Hi,
Seen these advertised but they say it's not suitable for the later bikes ( 94 onwards iirc) although I'm not sure if there are actually any differences.
I've emailed them asking for measurements.
This was actually the reason I posted in 1st place as it made me think that if a shock has same fittings, same length & its for the same type of bike, what's to stop me fitting it?
Overkill maybe, but nice bit of kit & I would seriously consider it IF it was gaurunteed to fit.
cheers,
GAZ |
| stirlinggaz |
| sickpup |
 sickpup Old Timer
| Riejufixing |
| stirlinggaz |
| stirlinggaz |
| Riejufixing |
 Posted: 12:56 - 20 Aug 2020 Post subject: |
You might be able to do it by hand. You might need to compress the spring with something, though. Try it. Adjust the adjuster to the softest setting by turning it, put the bottom of the shock absorber on something solid like a workbench, or in a vice, get your hands around the top bit, at the top of the spring, as if you were trying to strangle it, and push down. If the spring can be compressed by hand, you will be able to pop out the collets or remove the collar if it's one of the sort with a gap in it, and that will allow you to remove the spring. If the spring's too strong to compress by hand, improvise with clamps or something, and get the collar or collets off as before, then get the spring off.
Once the spring's off, you can test the damper. Work it down and up, and see a) if there's any damping (or squishy bubbling noises), in which case there's at least some oil in it, or b) whether after you push the top of the damper down, it pops back up again, in which case there's still at least some gas in it.
Edit: I've just looked at your pic, the spring looks rather tough, it might not compress easily by hand. Clamp job or similar if not, but no harm done seeing if it will compress.
Edit again: It won't explode if you just get the spring off! Do that first, then come back  |
| stirlinggaz |
 Posted: 13:21 - 20 Aug 2020 Post subject: |
| Riejufixing wrote: | You might be able to do it by hand. You might need to compress the spring with something, though. Try it. Adjust the adjuster to the softest setting by turning it, put the bottom of the shock absorber on something solid like a workbench, or in a vice, get your hands around the top bit, at the top of the spring, as if you were trying to strangle it, and push down. If the spring can be compressed by hand, you will be able to pop out the collets or remove the collar if it's one of the sort with a gap in it, and that will allow you to remove the spring. If the spring's too strong to compress by hand, improvise with clamps or something, and get the collar or collets off as before, then get the spring off.
Hi,
Therein lies the problem.
The adjuster at bottom doesn't move & I haven't thought of a way to compress the spring, it's quite a hefty bugger.
Any ideas?
I did try a spring compressor thingy intended for car shocks but couldn't get it to hook onto the coils.
I presume there is a motorcycle shock equivalent tool?
cheers,
GAZ
Edit : just looked up the correct tool to compress spring..50 quid for something I'm likely to never use again.
As much as I like buying tools I think I'll pass. |
| Riejufixing |
The last post was made 6 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
