| kramdra |
 kramdra World Chat Champion
 Posted: 10:27 - 24 Aug 2020 Post subject: Fairing nuts |
https://i.postimg.cc/8zjngQRv/IMG-20200824-112043.jpg
For the areas circled. These are the headlight mounts. I can not remember what nuts were originally there, suspect it was those nuts on a clip.
Is there a better option? |
| stinkwheel |
 Posted: 10:56 - 24 Aug 2020 Post subject: |
There is a better way. Make up a bracket and fit the headlamp to the subframe. Then you don't have a big heavy thing attached to the inside of your plastic fairing by flimsy plastic lugs.
However yes, they are usually held on with those captive nuts on clips. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| droog |
 droog Spanner Monkey
 Posted: 11:46 - 24 Aug 2020 Post subject: |
Dunno if this helps but mine is in bits so I took some photos to help me put it back together again.
The two holes above the headlight take a couple of clips - the inner clip is secured with an M5 bolt and a washer, the outer clip secures the trim panel and takes a standard fairing bolt I think.
The hole in the centre takes a clip and an M5 also.
https://i.ibb.co/XkVPRpy/top-right.jpg
https://i.ibb.co/Khswgjh/centre.jpg |
| kramdra |
| steve the grease |
 steve the grease Crazy Courier
The last post was made 5 years, 165 days ago. Instead of replying here, would creating a new thread be more useful? |
