Fairing nuts
kramdra
PostPosted: 10:27 - 24 Aug 2020    Post subject: Fairing nuts Reply with quote
https://i.postimg.cc/8zjngQRv/IMG-20200824-112043.jpg
For the areas circled. These are the headlight mounts. I can not remember what nuts were originally there, suspect it was those nuts on a clip.
Is there a better option?
PostPosted: 10:56 - 24 Aug 2020    Post subject: Reply with quote
There is a better way. Make up a bracket and fit the headlamp to the subframe. Then you don't have a big heavy thing attached to the inside of your plastic fairing by flimsy plastic lugs.
However yes, they are usually held on with those captive nuts on clips.
droog
PostPosted: 11:46 - 24 Aug 2020    Post subject: Reply with quote
Dunno if this helps but mine is in bits so I took some photos to help me put it back together again.
The two holes above the headlight take a couple of clips - the inner clip is secured with an M5 bolt and a washer, the outer clip secures the trim panel and takes a standard fairing bolt I think.
The hole in the centre takes a clip and an M5 also.
https://i.ibb.co/XkVPRpy/top-right.jpg
https://i.ibb.co/Khswgjh/centre.jpg
kramdra
PostPosted: 11:55 - 24 Aug 2020    Post subject: Reply with quote
Thanks for the pics, I think I had those clips sieze so I superglued wellnuts instead. Fine until you take it off.
SW - that would be quite a challenge, but the headlight does slot into the subframe so its weight is supported, these mounts just keep the headlight in the fairing slot and add a lot of rigidity to the fairing, theres also two nut inserts below.
I think Im going to clean it up, abs-slurry glue abs sheet in place to about 10mm thick, with an m5 nut insert.
steve the grease
PostPosted: 17:35 - 24 Aug 2020    Post subject: Reply with quote
Those , ' nuts on clips' are called chimney nuts, so it seems [url] https://www.ebay.co.uk/itm/M6-M8-M10-LONG-REACH-CHIMNEY-U-NUT-LUG-NUTS-SPEED-SPIRE-CAPTIVE-CLIPS-THREADED/323992945875?hash=item4b6f7c04d3:g:H00AAOSwQApd3RqG[/url]
All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
The last post was made 5 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 44.14 Kb
