RS125 Chain Removal
Rollins
PostPosted: 19:22 - 02 Apr 2005    Post subject: RS125 Chain Removal Reply with quote
Do I need a specialist tool to take the split link apart, or can I get away with a pair of external circlip pliers??!!!
I think the chain needs a good clean-up, as I adjusted it for the 3rd time in 4 months today - I have a feeling that Castrol chain wax isn't really working as I think...
"... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR
Guest
PostPosted: 19:58 - 02 Apr 2005    Post subject: Reply with quote
Ordinary pliers will do the job. This is putting the spring clip back on .........
https://img.photobucket.com/albums/v471/fastfitter/Re-fitclip.jpg
Taking it off is the same but backwards Wink
Rollins
PostPosted: 20:07 - 02 Apr 2005    Post subject: Reply with quote
Thanks Guest!! Thumbs Up
What's the best way to clean it up after it's removed? Soak in petrol?
I'm pretty sure the OE RS125 chain doesn't have O or X ring seals as well, so re-assembly should be easy.
2005 CBR600RR
tatters
Exxon Valdez
PostPosted: 20:39 - 02 Apr 2005    Post subject: Reply with quote
wd40 or parfun/white spirt is ok to clean a non-"o" ring chain, make sure you put the back of cilp facing towards the direction of travel as shown in the photo or it could fly off.
Guest
PostPosted: 21:00 - 02 Apr 2005    Post subject: Reply with quote
Wash it in a pan of paraffin with a stiff brush then wipe it down and let it dry.
I don't suppose you can get tins of LinkLyfe anymore? That was wonderful stuff - coil the chain up in the tin of grease and then heat it on the stove (when mum's gone shopping Wink ) so the grease melts and the chain sinks into it and gets thoroughly lubed. Ah, them were t'days Thumbs Up Very Happy
MattEMulsion
PostPosted: 21:19 - 02 Apr 2005    Post subject: Reply with quote
Castrol chain wax is crap in my opinion. Not only does it not really have much penetration but it turns a horrible yellow/green colour when it dries and looks terrible. The only good thing I can say is that it doesn't have too much fling. I now tend to use Motul Factory Line chain lube. It seems to be doing a much better job.
Yamaha YZF-R6
Gazdaman
I did a trackday!!!
PostPosted: 23:20 - 02 Apr 2005    Post subject: Reply with quote
A friend of the family (an IAM examiner in fact) burned down his kitchen doing just that!
Gaz
The last post was made 21 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 52.24 Kb
