Parking by Bond Street & security advice
Jefr0
PostPosted: 13:45 - 13 Sep 2020    Post subject: Parking by Bond Street & security advice Reply with quote
Hi all
What’s parking like around Bond Street?
I’m using a Honda CB125F 2018. Should I stick with this or buy a different bike?
I can only find a few road bays with nothing to chain a bike to. The price of a annual train ticket is ridiculous so I want to commute again. Is it relatively safe?
I’m looking to spend good money on security. From what I’ve read on here, it’s Alma’s or Pragmasis. I’ve also got to think of carrying it.
So I need:
Practical chain, pragmasis 13mm? What length?
Squire padlock? Which one to work with it?
Disc lock but one that will actually fit on my bike. My 2 I have don’t fit
Tail pack to carry both the chain and disc lock which will hold up the weight and also fit to the bike well. Kreiga? Would be good to keep a set of waterproofs in. If it can be attached the bike so it doesn’t clip off that will be helpful.
Any advice would be great please!
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
hellkat
PostPosted: 14:42 - 13 Sep 2020    Post subject: Reply with quote
When I worked up at 118 Piccadilly there was a fair few bays with locks up round the back of there, like off the top of Curzon. Bit of a trot down to Bond, but there always seemed to be an empty one when I needed it.
Otherwise, go underground I guess, is it more expensive than a train season ticket to park under Park Lane or Cavendish Square?
I think there's a bit down under in St James somewhere, too, under the hotel (American Bar)?
Its been a while since I was working in that manor, to be fair.
Can't comment on locks and chains.
Nothing's "safe" in Mayfair. Or in London in general, as you are probably aware. It's a bit of a lottery really.
Covering it over slows them down or puts them off, mine usually have a hand-brake lock as well these days, just to slow them down, but if they want it, they want it.
Bike safety in London is really just an illusion.
Your bike is as safe as the next, until it isn't.
droog
PostPosted: 18:45 - 13 Sep 2020    Post subject: Reply with quote
There is dedicated bike parking in Brewer street NCP Soho - I used to park there when I was working in the area.
Q-Park do free parking for bikes and have sites in Soho and Leicester Square.
PostPosted: 21:06 - 13 Sep 2020    Post subject: Reply with quote
I'd go for something bigger than 13mm so that it can't be bolt cropped by hand. They're not cheap so consider it an investment.
Park next to a more desirable bike that's got worse security than your bike has.
Almax sell all their chains with the Squire SS65CS lock so I'd say that's the one to go for.
You're never going to be able to stop someone from cutting a chain using an angle grinder or they could always jump you after you've unchained your bike and put the key in the ignition as well. As long as the chain is big enough that it can't be cropped with bolt cutters then you'll be stopping at least some thieves.
NJD
PostPosted: 22:56 - 13 Sep 2020    Post subject: Reply with quote
Small, light, nimble, good fuel range. Seems ideal for a city that is notorious for being backlogged with traffic constantly.
From a theft angle the argument is null and void simply because in London they seem to take anything and everything.
If you bike a different bike thinking its safer, per se, from theft then you're only loosing the money it took to swap to that bike on top of what you've already got invested.
When I had a 125 I told myself that I'd never commute with more than a 13 mm because the weight would upset the balance of the bike, but I guess it depends on what else you carry and how tied down it is.
As Ste points out a 16 mm is probably the way to go, but unless you can find something to chain it to then I'd argue a 13 mm is basically the same because it would be lying on the floor anyway (that seems the norm in London motorbike bays). But, yes, if you can find something (anything) to chain it to then do; and in that case go with a 16 mm.
As for length it depends on what lock you use. I've discovered d-locks enable use of a shorter length for the same application due to the width in the shackle. Outside of a d-lock I'd opt for a round-lock (pragmasis website).
2.0 m is the norm and I'd go no shorter than 1.5 m for a 16 mm (with d-lock). Any shorter than that and its basically only useful to loop around the wheel and perhaps part of the frame. 2.0 m comes up heavy, mind.
You'd get away with a longer length on a 13 mm for less weight than a 16 mm, but in either case 2.0 m should be the max you'll need. I've got a 2.5 mm somewhere and its ridiculous.
Tried the rear sprocket? Front ends can be lifted. Common mistake people thinking front is more secure, but of course is the most used because "disc lock."
Jefr0 wrote:
Kreiga
10 year warrenty from new and entirely waterproof, great bit of kit.
A US-20 is probably the one you'll want. A US-10 may come up way too short at times (on days you find yourself with one or two extra things) and a US-30 will be way too wide / large and have too much free space. Pack the bottom with a hoodie (makes it easier to tie down as a chain at the bottom of the bag prevents secure strapping and causes bag to move around).
The loops attach to the frame under the seat and pop out under the seat (staying on the bike all the time) and then a hook attaches to them and clips onto the bag. You'd have to take those hooks and bag with you everywhere you go. Kriega's are a tad too expensive to be leaving on the bike for no benefit, I'd say.
Their a roll bag so that means you'll have to unlock the bike, load the bag in the right order and then tie it up.. do all the clips up.. attach the hooks and then put onto the seat to ratchet down. Very worthwhile if you're commuting long distance but for 10 miles or so and if you're constantly getting ready outside (on cold and wet days) there may be more suitable solutions out there.
For this very reason I've just invested in a crap oxford tail-bag that attaches under the seat via a Velcro strap and four bungees on the bike to be left there to see how much time it saves me (not caring about it getting wet, or being stolen). The idea being its square, stays on the bike and this means I can throw the locks in as I go only needing to zip it up after (versus the faff mentioned above with a Kriega). A 16 mm will definitely brake the ones that have a detachable base so if you do go this route (going cheap via eBay) get one that doesn't have a detachable base. Their worse in every way over a Kriega, and I'd never really recommend one.
I'd get a couple of Rok straps from J&S for £10 to be left on the bike to aid in keeping it tight to the pillion seat.. whatever brand you go with. A 16 mm hitting you in the back due to loose straps or going over a bump can probably cause long term damage.
Alternatively a cheap top-box, a roll bag or a backpack. Look at SBS and J&S and shop on eBay, but I'd get the warrenty for a Kriega just because used ones go for not much less than new.
Kriega do combo kits if you've got loads of cash.
Robby
Dirty Old Man
PostPosted: 11:05 - 14 Sep 2020    Post subject: Reply with quote
Theft from bays or NCP car parks isn't as common as you may think. Often CCTV and witnesses, so the thieves need to be brazen and quick - or the bike needs to be desirable.
A chain is good if you have something to chain the bike to, and you can be bothered to lug it around and use it. For the cost of a really good chain and padlock you can buy a disc lock and tracker. It is better to have several weaker security devices than one good one, because it needs more tools and techniques to get around them. Anyone with an angle grinder can get through a chain, getting through a disc lock is an entirely different proposition.
Don't spend more than the value of your insurance excess on security. Only use the security devices you can be bothered to fit.
Your bike is far more likely to get knocked over by someone else being clumsy than it is to get stolen.
Jefr0
PostPosted: 22:49 - 14 Sep 2020    Post subject: Reply with quote
Thanks for all the replies, can always rely on BCF!
@hellkat - Season ticket over £3k for train. Parking is free underground at Cavendish square (walked there today for a look) or parking in bays nearby is approx £150 a year.
Very true about security, London sucks.
@Droog - Thanks. I've taken a look at Q parks near Bond Street and can see a few dotted about, I imagine might be first come first serve.
@Ste - Thanks for the advice. There's not really a right answer is there. I was mugged for my bike in Greenwich 13 years ago, they waited till I removed all my security.
By the way, can you link me to the vid of your avatar, used to crack me up Laughing
@NJD - Strong advice, thank you. RE the chains, I didn't realise there was so much choice! I only have a front disk, rear is drum.
Thanks for your advice on the bags. Ive never actually used a tail bag so I appreciate what you've mentioned as it'll come in handy!
@Robby - I didn't actually know how secure they were or not, after visiting one today (underground) it would take a braver thief to take it on (not ruling theft out)
I'll be using a few devices I think, as you say, to make it more time consuming to nick. Hopefully doesn't get knocked over, that'd be depressing to come back to!
Trains/tubes seem to be getting busier lately so looking to go in on the bike ASAP!
hellkat
PostPosted: 09:08 - 15 Sep 2020    Post subject: Reply with quote
I've learnt something. Shocked
Pleased to know Q park let bikes park for free.
Nice one! Cool
droog
PostPosted: 09:42 - 15 Sep 2020    Post subject: Reply with quote
Nice one! Cool
Yep - 'Free' and 'West End of London' aren't words that usually occur in the same sentence Very Happy
PostPosted: 09:47 - 15 Sep 2020    Post subject: Reply with quote
https://www.youtube.com/watch?v=w6L1d7PbILw
Mr. Green
Robby
Dirty Old Man
PostPosted: 11:06 - 15 Sep 2020    Post subject: Reply with quote
Also worth mentioning having a disc lock bracket. I made up a bracket for my bike to hold my disc lock so I always have it with me, and don't have to rummage in a bag for it, or put it in my pocket (really bad idea if you crash).
I am lazy. I won't remember to pack my lock every day, or bother, so I make sure it's always on the bike.
ThunderGuts
PostPosted: 12:23 - 15 Sep 2020    Post subject: Reply with quote
On luggage, I've got a US-20 and it's brilliant. Used it to cart around my 14mm 1.5m chain and lock/disclock. Could take a 16mm. Advantage of a tailpack is as long as the loops are solid, you can strap heavy stuff to the pillion seat as it's designed to take that weight. Strapped down well it'll also stay solid with the bike so won't noticeably affect handling either (unlike a chain sliding about in a topbox). I also have a smaller US-05 which I use to keep a disclock and spare gloves in on winter rides out (cafe stops etc. where a disclock is adequate); if I want to carry more, the Kriega system means you can easily attach the different packs to each other.
If you go with Kriega, worth taking the seat off and properly attaching the loops to the frame. They're unobtrusive when not needed but a proper fixing place will make all the difference when you do need them. I had a piece of old camping mat (the karrimat type foam stuff) in mine to stop the chain leaving dents in the seat.
TG.
droog
PostPosted: 12:40 - 15 Sep 2020    Post subject: Reply with quote
Regarding carrying a chain - I bought a renntec rear rack for my cbr - perfect for looping a heavy chain through plus a couple fo bungees to stop it moving about.
ThunderGuts
PostPosted: 14:13 - 15 Sep 2020    Post subject: Reply with quote
I wouldn't recommend using bungees (even though you've presumably haven't had any issues yet); their elastic nature means if you hit a big bump they can give enough to release whatever they're holding down. I always use some sort of ratchet strap so you can tighten it up but it'll never give a mm unless you release the catch. Very light objects, e.g. pair of overtrousers, a rolled up raincover etc. could be held with bungees but I wouldn't use it for anything heavy.
TG.
droog
PostPosted: 14:54 - 15 Sep 2020    Post subject: Reply with quote
Yes totally agree Very Happy - but in my case the chain is passed up and under throught the bars of the rack a couple of times (so it is basically threaded through the rack) and finally locked to the rack with the chain padlock - by then it is nice and compact and safely secured to the rack - I should have mentioned that the the two short bungees are not there to actually secure the chain to the rack - they are just there to pull the chain tight enough against the rack to stop it rattling against the bars.
PostPosted: 18:11 - 15 Sep 2020    Post subject: Reply with quote
Nice one! Cool
ONLY in Westminster, mind.
The last post was made 5 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 98.91 Kb
