| Jefr0 |
 Jefr0 World Chat Champion
| hellkat |
 hellkat Super Spammer
 Posted: 14:42 - 13 Sep 2020 Post subject: |
When I worked up at 118 Piccadilly there was a fair few bays with locks up round the back of there, like off the top of Curzon. Bit of a trot down to Bond, but there always seemed to be an empty one when I needed it.
Otherwise, go underground I guess, is it more expensive than a train season ticket to park under Park Lane or Cavendish Square?
I think there's a bit down under in St James somewhere, too, under the hotel (American Bar)?
Its been a while since I was working in that manor, to be fair.
Can't comment on locks and chains.
Nothing's "safe" in Mayfair. Or in London in general, as you are probably aware. It's a bit of a lottery really.
Covering it over slows them down or puts them off, mine usually have a hand-brake lock as well these days, just to slow them down, but if they want it, they want it.
Bike safety in London is really just an illusion.
Your bike is as safe as the next, until it isn't. ____________________ Not nearly as interesting in real life. |
| droog |
 droog Spanner Monkey
| Ste |
 Ste Not Work Safe
| NJD |
 NJD World Chat Champion
 Posted: 22:56 - 13 Sep 2020 Post subject: |
| Jefr0 wrote: | I’m using a Honda CB125F 2018. Should I stick with this or buy a different bike? |
Small, light, nimble, good fuel range. Seems ideal for a city that is notorious for being backlogged with traffic constantly.
From a theft angle the argument is null and void simply because in London they seem to take anything and everything.
If you bike a different bike thinking its safer, per se, from theft then you're only loosing the money it took to swap to that bike on top of what you've already got invested.
| Jefr0 wrote: | Practical chain, pragmasis 13mm? What length? |
When I had a 125 I told myself that I'd never commute with more than a 13 mm because the weight would upset the balance of the bike, but I guess it depends on what else you carry and how tied down it is.
As Ste points out a 16 mm is probably the way to go, but unless you can find something to chain it to then I'd argue a 13 mm is basically the same because it would be lying on the floor anyway (that seems the norm in London motorbike bays). But, yes, if you can find something (anything) to chain it to then do; and in that case go with a 16 mm.
As for length it depends on what lock you use. I've discovered d-locks enable use of a shorter length for the same application due to the width in the shackle. Outside of a d-lock I'd opt for a round-lock (pragmasis website).
2.0 m is the norm and I'd go no shorter than 1.5 m for a 16 mm (with d-lock). Any shorter than that and its basically only useful to loop around the wheel and perhaps part of the frame. 2.0 m comes up heavy, mind.
You'd get away with a longer length on a 13 mm for less weight than a 16 mm, but in either case 2.0 m should be the max you'll need. I've got a 2.5 mm somewhere and its ridiculous.
| Jefr0 wrote: | Disc lock but one that will actually fit on my bike. |
Tried the rear sprocket? Front ends can be lifted. Common mistake people thinking front is more secure, but of course is the most used because "disc lock."
10 year warrenty from new and entirely waterproof, great bit of kit.
A US-20 is probably the one you'll want. A US-10 may come up way too short at times (on days you find yourself with one or two extra things) and a US-30 will be way too wide / large and have too much free space. Pack the bottom with a hoodie (makes it easier to tie down as a chain at the bottom of the bag prevents secure strapping and causes bag to move around).
The loops attach to the frame under the seat and pop out under the seat (staying on the bike all the time) and then a hook attaches to them and clips onto the bag. You'd have to take those hooks and bag with you everywhere you go. Kriega's are a tad too expensive to be leaving on the bike for no benefit, I'd say.
Their a roll bag so that means you'll have to unlock the bike, load the bag in the right order and then tie it up.. do all the clips up.. attach the hooks and then put onto the seat to ratchet down. Very worthwhile if you're commuting long distance but for 10 miles or so and if you're constantly getting ready outside (on cold and wet days) there may be more suitable solutions out there.
For this very reason I've just invested in a crap oxford tail-bag that attaches under the seat via a Velcro strap and four bungees on the bike to be left there to see how much time it saves me (not caring about it getting wet, or being stolen). The idea being its square, stays on the bike and this means I can throw the locks in as I go only needing to zip it up after (versus the faff mentioned above with a Kriega). A 16 mm will definitely brake the ones that have a detachable base so if you do go this route (going cheap via eBay) get one that doesn't have a detachable base. Their worse in every way over a Kriega, and I'd never really recommend one.
I'd get a couple of Rok straps from J&S for £10 to be left on the bike to aid in keeping it tight to the pillion seat.. whatever brand you go with. A 16 mm hitting you in the back due to loose straps or going over a bump can probably cause long term damage.
Alternatively a cheap top-box, a roll bag or a backpack. Look at SBS and J&S and shop on eBay, but I'd get the warrenty for a Kriega just because used ones go for not much less than new.
Kriega do combo kits if you've got loads of cash. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Robby |
 Robby Dirty Old Man
| Jefr0 |
 Posted: 22:49 - 14 Sep 2020 Post subject: |
Thanks for all the replies, can always rely on BCF!
@hellkat - Season ticket over £3k for train. Parking is free underground at Cavendish square (walked there today for a look) or parking in bays nearby is approx £150 a year.
Very true about security, London sucks.
@Droog - Thanks. I've taken a look at Q parks near Bond Street and can see a few dotted about, I imagine might be first come first serve.
@Ste - Thanks for the advice. There's not really a right answer is there. I was mugged for my bike in Greenwich 13 years ago, they waited till I removed all my security.
By the way, can you link me to the vid of your avatar, used to crack me up
@NJD - Strong advice, thank you. RE the chains, I didn't realise there was so much choice! I only have a front disk, rear is drum.
Thanks for your advice on the bags. Ive never actually used a tail bag so I appreciate what you've mentioned as it'll come in handy!
@Robby - I didn't actually know how secure they were or not, after visiting one today (underground) it would take a braver thief to take it on (not ruling theft out)
I'll be using a few devices I think, as you say, to make it more time consuming to nick. Hopefully doesn't get knocked over, that'd be depressing to come back to!
Trains/tubes seem to be getting busier lately so looking to go in on the bike ASAP! ____________________ Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95) |
| hellkat |
 Posted: 09:08 - 15 Sep 2020 Post subject: |
I've learnt something.
Pleased to know Q park let bikes park for free.
Nice one!  ____________________ Not nearly as interesting in real life. |
| droog |
| Ste |
 Ste Not Work Safe
 Posted: 09:47 - 15 Sep 2020 Post subject: |
| Robby |
 Robby Dirty Old Man
| ThunderGuts |
| droog |
| ThunderGuts |
| droog |
The last post was made 5 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
