| Jozzer |
 Jozzer Two Stroke Sniffer
 Posted: 16:40 - 25 Sep 2020 Post subject: Still baffling me... |
Ok chaps, a while ago I posted that my 2003 ZZR600E was having running issues which I initially put down to fuelling issues, well, turns out it's an ignition problem !...
Who knew eh...
The problem is a weak pinky/red spark emanating from all 4 plugs so I initially pulled all of the electrical joints that I could find and checked/cleaned and sprayed with spray grease then reassembled accordingly, still no different, so, for the past few months I've been meticulously testing/replacing one part after another, some new, some used in the vein hope of curing the problem and it's at this point in time that I'm now about done with it only having the genny and the starter left...
I'm wondering if any of you wise folk on here might be able to suggest where I'm going wrong with it, apart from wasting my time by spending money on parts I don't actually need that is...
I'm completely baffled by the whole affair now and although I'll happily admit I'm no demon when it comes to elastictrickery I'd suggest that replacing an entire electrical system with known good parts is child's play, or so I thought...
Anyone able to give me any pointers before I decide to do something silly like employ that large (14lb) sledgehammer that's been winking at me from the corner of the workshop for the last few months, that or it's got a full tank of fuel and I've got a spare match to hand...
Any help would be most appreciated, many thanks in advance...
Jozzer...  |
| steve the grease |
 Posted: 16:58 - 25 Sep 2020 Post subject: |
Hey I'm no electronics expert by a long way, but, if there are 2 double ended coils feeding the 4 cylinders 1-4 and 2-3 I would think it's very unlikely that both coils have gone flaky and are delivering a poor low quality pink looking spark. Which would tend to suggest , to me anyway that its the device triggering the coils that is probably at fault. Or possibly that the supply to the ECU/ignition module is somehow prejudiced, maybe a poor connection in the ignition switch, dropping a volt or twoin the supply line. I'm sure you have checked that you are getting a good clean 12-13v to the ecu/ ignition. In that case I would suspect that there is an issue in the ECU/ ignition module itself. A company called BBA Reman are good at stuff like that. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
| Jozzer |
 Posted: 17:16 - 25 Sep 2020 Post subject: |
| steve the grease wrote: | Hey I'm no electronics expert by a long way, but, if there are 2 double ended coils feeding the 4 cylinders 1-4 and 2-3 I would think it's very unlikely that both coils have gone flaky and are delivering a poor low quality pink looking spark. Which would tend to suggest , to me anyway that its the device triggering the coils that is probably at fault. Or possibly that the supply to the ECU/ignition module is somehow prejudiced, maybe a poor connection in the ignition switch, dropping a volt or twoin the supply line. I'm sure you have checked that you are getting a good clean 12-13v the ecu/ ignition. |
Thanks for your input buddy, when I initially discovered the issue my first port of call was the charging system (reg/rec) so checked the charging rates etc and got back 12.7 static at the battery, 13.6-7 at idle and 14.6 I think it was at 4000 rpm so no issues with that as far as I know, since then I've replaced everything barring the genny and the starter motor although I did strip, clean and rebuild the starter (it was full of crap) and still no different...
That's about the full extent of my electrical knowledge if I'm honest buddy "although" you'd have thought that replacing the entire (and I mean "entire" as in loom n'all) electrical system piece by piece might just have cured the issue wouldn't you, well "apparently not" it would seem...
I'm completely stumped/hacked off/disheartened by the whole affair now, I bought the bike as a way back into biking and not as a one stop lesson in automotive electrical issues, should'a just stuck with the car...
Cheers, Jozzer...  |
| Jozzer |
 Posted: 17:47 - 25 Sep 2020 Post subject: |
| Jozzer wrote: |
Now, this is one thing that had crossed my mind, are the coils supposed to be earthed to the frame ?...
They're bolted to 2 metal brackets via rubber grommets, the brackets are then bolted to the frame and there's no sign of any earthing wires anywhere, never has been, is that correct buddy ?...
Ps, the motor is earthed via the frame isn't it ?...
I have checked both of these already by using a stand alone earth cable from motor to chassis and coil to chassis but still no change... |
It's a problem I had on other kawasakis, not sure if that one is supposed to be earthed or not.
I take it you have changed the plugs?
For what it's worth, stop worrying about the charging system. A fully charged battery will run the bike. A lot of race bikes run on "total loss", they remove the alternator altogether to reduce rotating crank mass and slight power losses due to the draw from the charging system. A charged battery will go race distance. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jozzer |
 Posted: 17:57 - 25 Sep 2020 Post subject: |
| stinkwheel wrote: | | Jozzer wrote: |
For what it's worth, stop worrying about the charging system. A fully charged battery will run the bike. A lot of race bikes run on "total loss", they remove the alternator altogether to reduce rotating crank mass and slight power losses due to the draw from the charging system. A charged battery will go race distance. |
Yeah, I'm past the charging system I think buddy and "yes" the plugs were the very first thing to be replaced upon discovering the weak spark issue, closely followed by leads/coils and so on and so on...
Although I'm no wiz kid with electrics I'm no complete dough-bake either but this has got me proper hog tied buddy, never come across anything like this before if I'm honest... |
| Nobby the Bastard |
 Posted: 19:47 - 25 Sep 2020 Post subject: |
Again off a different model but I've seen a few kawasakis get really badly corrosion running up the insulation of the main power feed wire. It'll be the big fat one running from the main fuse up to the front of the bike. Seen it happen at either end. Often white. The main fuse is usually on top of the starter solenoid. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jozzer |
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
| Jozzer |
| Hong Kong Phooey |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Jozzer |
| jeffyjeff |
| Robby |
 Robby Dirty Old Man
| Jozzer |
 Posted: 10:50 - 05 Oct 2020 Post subject: |
Well, turns out the left hand switch unit is the culprit so far as the spark issue is concerned, I bought a cheap one on eBay, plugged it in and the spark is back...
Also the NEW!!! battery I bought just a few weeks ago seem to be duff, I put the old one back in and it wanged over like an absolute arse, who knew that a new battery would have had issues...
Thanks fer all yer input chaps, hopefully we're on a winner at last, just glad I didn't lose my rag completely and torch/smash the sodding thing now...  |
| sickpup |
 sickpup Old Timer
| Jozzer |
| Nobby the Bastard |
| Jozzer |
 Posted: 18:53 - 05 Oct 2020 Post subject: |
The last post was made 5 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
