Still baffling me...
Bike Chat Forums Index -> The Workshop via View Category
Jozzer
PostPosted: 16:40 - 25 Sep 2020    Post subject: Still baffling me... Reply with quote
Ok chaps, a while ago I posted that my 2003 ZZR600E was having running issues which I initially put down to fuelling issues, well, turns out it's an ignition problem !...
Who knew eh... Rolling Eyes
The problem is a weak pinky/red spark emanating from all 4 plugs so I initially pulled all of the electrical joints that I could find and checked/cleaned and sprayed with spray grease then reassembled accordingly, still no different, so, for the past few months I've been meticulously testing/replacing one part after another, some new, some used in the vein hope of curing the problem and it's at this point in time that I'm now about done with it only having the genny and the starter left...
I'm wondering if any of you wise folk on here might be able to suggest where I'm going wrong with it, apart from wasting my time by spending money on parts I don't actually need that is...
I'm completely baffled by the whole affair now and although I'll happily admit I'm no demon when it comes to elastictrickery I'd suggest that replacing an entire electrical system with known good parts is child's play, or so I thought...
Anyone able to give me any pointers before I decide to do something silly like employ that large (14lb) sledgehammer that's been winking at me from the corner of the workshop for the last few months, that or it's got a full tank of fuel and I've got a spare match to hand...
Any help would be most appreciated, many thanks in advance...
Jozzer... Thumbs Up
steve the grease
PostPosted: 16:58 - 25 Sep 2020    Post subject: Reply with quote
Hey I'm no electronics expert by a long way, but, if there are 2 double ended coils feeding the 4 cylinders 1-4 and 2-3 I would think it's very unlikely that both coils have gone flaky and are delivering a poor low quality pink looking spark. Which would tend to suggest , to me anyway that its the device triggering the coils that is probably at fault. Or possibly that the supply to the ECU/ignition module is somehow prejudiced, maybe a poor connection in the ignition switch, dropping a volt or twoin the supply line. I'm sure you have checked that you are getting a good clean 12-13v to the ecu/ ignition. In that case I would suspect that there is an issue in the ECU/ ignition module itself. A company called BBA Reman are good at stuff like that.
All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
PostPosted: 17:15 - 25 Sep 2020    Post subject: Reply with quote
You checked the frame earths on the coils for corrosion?
Jozzer
PostPosted: 17:16 - 25 Sep 2020    Post subject: Reply with quote
steve the grease wrote:
Hey I'm no electronics expert by a long way, but, if there are 2 double ended coils feeding the 4 cylinders 1-4 and 2-3 I would think it's very unlikely that both coils have gone flaky and are delivering a poor low quality pink looking spark. Which would tend to suggest , to me anyway that its the device triggering the coils that is probably at fault. Or possibly that the supply to the ECU/ignition module is somehow prejudiced, maybe a poor connection in the ignition switch, dropping a volt or twoin the supply line. I'm sure you have checked that you are getting a good clean 12-13v the ecu/ ignition.
Thanks for your input buddy, when I initially discovered the issue my first port of call was the charging system (reg/rec) so checked the charging rates etc and got back 12.7 static at the battery, 13.6-7 at idle and 14.6 I think it was at 4000 rpm so no issues with that as far as I know, since then I've replaced everything barring the genny and the starter motor although I did strip, clean and rebuild the starter (it was full of crap) and still no different...
That's about the full extent of my electrical knowledge if I'm honest buddy "although" you'd have thought that replacing the entire (and I mean "entire" as in loom n'all) electrical system piece by piece might just have cured the issue wouldn't you, well "apparently not" it would seem...
I'm completely stumped/hacked off/disheartened by the whole affair now, I bought the bike as a way back into biking and not as a one stop lesson in automotive electrical issues, should'a just stuck with the car...
Cheers, Jozzer... Thumbs Up
Jozzer
PostPosted: 17:20 - 25 Sep 2020    Post subject: Reply with quote
Now, this is one thing that had crossed my mind, are the coils supposed to be earthed to the frame ?...
They're bolted to 2 metal brackets via rubber grommets, the brackets are then bolted to the frame and there's no sign of any earthing wires anywhere, never has been, is that correct buddy ?...
Ps, the motor is earthed via the frame isn't it ?...
I have checked both of these already by using a stand alone earth cable from motor to chassis and coil to chassis but still no change...
PostPosted: 17:47 - 25 Sep 2020    Post subject: Reply with quote
It's a problem I had on other kawasakis, not sure if that one is supposed to be earthed or not.
I take it you have changed the plugs?
For what it's worth, stop worrying about the charging system. A fully charged battery will run the bike. A lot of race bikes run on "total loss", they remove the alternator altogether to reduce rotating crank mass and slight power losses due to the draw from the charging system. A charged battery will go race distance.
Jozzer
PostPosted: 17:57 - 25 Sep 2020    Post subject: Reply with quote
Yeah, I'm past the charging system I think buddy and "yes" the plugs were the very first thing to be replaced upon discovering the weak spark issue, closely followed by leads/coils and so on and so on...
Although I'm no wiz kid with electrics I'm no complete dough-bake either but this has got me proper hog tied buddy, never come across anything like this before if I'm honest...
Nobby the Bastard
Harley Gaydar
PostPosted: 18:30 - 25 Sep 2020    Post subject: Reply with quote
Depends on the type of coil. One is basically ht twin coils with both sparks being a positive. This requires an earth to complete the circuits. On this sort you can lose a single cylinder.
The other is just a single ht coil where one plug is positive and the other is negative. This wouldn't appreciate an earth oh the ht side on the coil. This sort will mean two cylinders would stop firing if the coil breaks down (or indeed any single item on the ht side.)
Triumph Sprint ST 1050
PostPosted: 19:47 - 25 Sep 2020    Post subject: Reply with quote
Again off a different model but I've seen a few kawasakis get really badly corrosion running up the insulation of the main power feed wire. It'll be the big fat one running from the main fuse up to the front of the bike. Seen it happen at either end. Often white. The main fuse is usually on top of the starter solenoid.
Jozzer
PostPosted: 20:11 - 25 Sep 2020    Post subject: Reply with quote
Two coils 4 leads on a 4 cylinder 16v motor running a wasted spark system buddy, left coil does 1 & 4, right coil does 2 & 3, black and green terminals on the coils "now" this is where some discrepancies come into the equation as the manual (Haynes) says red/black wire to green terminal but many voices on the internet say red/black wire to the black terminal, there are also a few that suggest it doesn't matter either way, what would you suggest buddy ?...
They're currently plugged in red/black wire to green terminal although turning them around made no difference to the spark anyway...
Nobby the Bastard
Harley Gaydar
PostPosted: 21:57 - 25 Sep 2020    Post subject: Reply with quote
I'm not talking about the low tension side. You'll always have two small thing wires to the coils.
I'm talking about the high tension side. The leads to the plugs may need the coil earthed depending on the internal design of the coil.
This is the same on all wasted spark systems whether 2 cylinder or 4 cylinder.
If the coils have rubbers holding them to the frame then they dont need an earth to the frame on the ht side.
Robby
Dirty Old Man
PostPosted: 15:41 - 26 Sep 2020    Post subject: Reply with quote
With a weak spark on all 4 plugs I would be looking upstream of the coils for a place where they all share a common positive feed, and hoping to find either a dirty/burnt/corroded plug, or a wire that shows high resistance and has corroded inside the insultation.
I'll be interested if you do work it out in the end, because a friend had a ZZR400 years ago that we couldn't find a problem with - but it was starting ok, but had no power and got worse as the miles went by. Could be a similar problem, and it's been nagging at me for years.
Jozzer
PostPosted: 18:36 - 26 Sep 2020    Post subject: Reply with quote
Yes buddy, rather hoping I do find the issue as I'm currently using my sons car to get to work and his test is next month, if he passes 1st time then I'm facing a 13 mile walk to get to work for 6am 5-7 days a week !...
Hong Kong Phooey
PostPosted: 15:41 - 29 Sep 2020    Post subject: Re: Still baffling me... Reply with quote
Was the bike running OK before in your ownership?
Were the old plugs doing the same as the new?
New plugs come pre-gapped, did you check the plug gap though?
Plugs the same rating? Not resistor when they shouldn't be?
What happens if you connect a car battery with jump leads?
Shared coils, the HT leads on plug are they known good?
Good earth connection to frame from battery?
Same for the coil circuit?
jeffyjeff
PostPosted: 06:33 - 30 Sep 2020    Post subject: Reply with quote
Just a thought: you might be running resistor type spark plugs with suppression type spark plug wires. That would increase the resistance in your high tension circuit and cause weak spark, even with good coils.
History shows again and again how nature points out the folly of men - BOC
Jozzer
PostPosted: 22:53 - 01 Oct 2020    Post subject: Reply with quote
Right, update time, the spark is now back to a blue colour although still very weak, I've tested all the main feed/earth wires that I can find and none have come back with a bad result, all connectors are clean and have been spray greased prior to reassembly so I now seem to be getting somewhere at least...
The one thing that has cropped up is the massive pull on the battery when the bike turns over, the battery (new) is holding 12.5v but drops to sub 6v when the starter button is engaged and when released the battery will recover back to 12.5 again fairly quickly, the spark although blue is all but non existent when the starter is engaged, very very weak and intermittent...
Does anyone happen to know what's a good minimum voltage the battery should be expected to drop to when turning the motor over, I'm damned sure sub 6v ain't right and I'd suggest 8-9v would more appropriate, got a mate who's lending me a starter motor to see if this makes any difference...
jeffyjeff
PostPosted: 01:47 - 02 Oct 2020    Post subject: Reply with quote
9.6 volts after a 15 second load at half the CCA rating is the standard for a 12V automotive battery.
In my opinion, your starter should not draw down your battery below 9.6 during cranking if your battery is fully charged. If your bike is fuel injected, the ECM might be affected at cranking voltages below 11.0V. In my experience, a strong, fully charged battery will maintain voltage greater than 11V during cranking.
Since your battery is dropping below 9.6 (assuming you started with a fully charged battery), start by replacing the battery, not the starter. No-load voltage will not give an accurate indication of battery condition.
Robby
Dirty Old Man
PostPosted: 12:30 - 02 Oct 2020    Post subject: Reply with quote
That is a useful bit of data for diagnosing the spark.
The coils need about 9v to work. More is better, but 9V is generally the bottom end of where they will put out enough voltage to create a spark that will jump the gap. Remember a coil acts as a voltage multiplier (and reduces current by the same amount). So if 30% less voltage is going in, 30% less voltage is coming out.
My first call would also be to replace the battery, it could just be old and knackered. Next job would be to strip and clean the starter motor, and replace the carbon brushes. These are cheap, but do watch a youtube video on doing it first - it's one of those jobs where you seem to need 5 hands unless you know the right technique.
Certainly a job to do when you have enough time to walk away and have a cuppa when its getting confusing, and do to on a well-lit work bench. Not exactly difficult or time consuming, just easy to make silly mistakes. I speak from experience.
Jozzer
PostPosted: 10:50 - 05 Oct 2020    Post subject: Reply with quote
Well, turns out the left hand switch unit is the culprit so far as the spark issue is concerned, I bought a cheap one on eBay, plugged it in and the spark is back... Thumbs Up
Also the NEW!!! battery I bought just a few weeks ago seem to be duff, I put the old one back in and it wanged over like an absolute arse, who knew that a new battery would have had issues... Rolling Eyes
Thanks fer all yer input chaps, hopefully we're on a winner at last, just glad I didn't lose my rag completely and torch/smash the sodding thing now... Very Happy
sickpup
Old Timer
PostPosted: 13:34 - 05 Oct 2020    Post subject: Reply with quote
There is nothing ignition wise or even main power wise routed through the left hand switch gear so I'm intrigued as to why you changed it and why you think it's the cure?
Jozzer
PostPosted: 18:38 - 05 Oct 2020    Post subject: Reply with quote
The ignition system, neutral light, side stand safety switch, kill switch and clutch kill switch for the side stand safety switch are all routed through the left hand switch unit buddy... Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 18:40 - 05 Oct 2020    Post subject: Reply with quote
No they're not. Lights, horn and indicators go through the LH switchgear.
Edit: I take it back, the clutch switch does. If it failed I would expect no spark at all, though.
Jozzer
PostPosted: 18:53 - 05 Oct 2020    Post subject: Reply with quote
I took it through the worst of last winters weather so can only presume the wiring in the unit didn't appreciate it baring in mind the bike had only done 1000 miles in 5yrs with the previous owner most of which I suspect were dry miles judging by the condition of the bike when I bought it... Very Happy
I'd vowed not to ride this one through winter as I've ruined so many other bikes by riding them through winter but as things transpired I ended up not having a choice... Sad
The last post was made 5 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 130.9 Kb
