GSXR 125 Idle revs
gsxrdave
PostPosted: 14:55 - 27 Sep 2020    Post subject: GSXR 125 Idle revs Reply with quote
Hi all Can anyone help me with my gsxr125 Its a 68 plate and recently i've had trouble with it cutting out when i come to a stop at a junction
Seems like the idle revs are not high enough. Is there an easy way to adjust the revs so i can bring them up a bit?
Thanks for your help
xX-Alex-Xx
PostPosted: 15:37 - 27 Sep 2020    Post subject: Reply with quote
Check the user manual. It’ll say in there. Isn’t it still under warranty with the dealer?
DILLIGAF
jaffa90
PostPosted: 15:44 - 27 Sep 2020    Post subject: Reply with quote
It`s not a case of adjusting idle revs just after 2 years, as xX-Alex-Xx states it could be a warranty job.
NJD
PostPosted: 15:59 - 27 Sep 2020    Post subject: Reply with quote
Rolling Eyes
With the bike in neutral and the engine running what's the idle speed like versus what the manual (workshop, owners or Google search) says it should be?
If it doesn't have any issue with running of its own steam in the above condition (at a standstill in neutral) then see if it changes when its put in gear and the clutch is pulled in -- maybe all the way (or as far as you can without excessive force).
At a very basic level it comes across that (1) you're either a new rider adjusting to the machine or (2) it just needs the clutch adjusting -- as you only mention this issue occurs when coming to a stop.
Very basic thing to do if so, and saves you a trip.
MCN
PostPosted: 22:20 - 28 Sep 2020    Post subject: Reply with quote
What service history?
If it is missing some service adjustments (Procedures), parts and etc. then it may not run as desired.
The last post was made 5 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 42.76 Kb
