Bike won't idle
hirmalde
PostPosted: 14:28 - 03 Oct 2020    Post subject: Bike won't idle Reply with quote
So I'm having a really tough time getting a ybr 125 to idle without choke. Trust me, I've done pretty much everything there is to do bar putting in a new carb altogether but still it just revs down and dies. Single carb, no diaphragm.
Idle screw is maxed out and even with full choke it can barely hold 1000rpm.
Any ideas?
Again, I have done pretty much everything or at least the things I have read up that may fix it but it still doesn't work. Looking for a detailed diagnosis path if anybody would be so kind?
I didn't realise this would get me so down but that's mechanicals for you!
Thanks in advance Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 14:59 - 03 Oct 2020    Post subject: Reply with quote
Have you been fucking with the air screw? Dont you mean maxed in?
Triumph Sprint ST 1050
hirmalde
PostPosted: 15:08 - 03 Oct 2020    Post subject: Reply with quote
Well yes but no setting on it works (fuel screw). It's the idle screw that's maxed in all the way clockwise until seated.
jaffa90
PostPosted: 15:23 - 03 Oct 2020    Post subject: Reply with quote
Was the pilot jet clear to see through?
hirmalde
PostPosted: 15:51 - 03 Oct 2020    Post subject: Reply with quote
yep
jaffa90
PostPosted: 16:07 - 03 Oct 2020    Post subject: Reply with quote
You could have unwanted air going in inbetween the carb and engine.
So it`s more fuel or less air at low revs.
WD Forte on here eats YBR`s for breakfast. Laughing
Robby
Dirty Old Man
PostPosted: 12:56 - 04 Oct 2020    Post subject: Reply with quote
I'll assume you're new to this and it's your first time cocking around with a carb.
First off, is the idle the only problem? Does it rev up cleanly and ride ok otherwise, or is it hesitant/lacking in power, getting worse as the bike warms up?
If so, you're probably operating the carb back to front. You're turning it off when it should be on, and vice versa.
Next up, drain the carb into a cup and look for water in the fuel. There is a drain screw on the bottom of the carb, possibly going into a narrow pipe that exits down around your right foot. There will be about half a cupful of fuel in the carb. If there is any water in there, it means you have water sitting in the bottom of your fuel tank.
Last thing if there is no water in the fuel and you were using the choke properly is to get the carb off the bike, strip and clean, and set everything up according to the workshop manual. Pay particular attention to float height and mixture screw setting.
Jozzer
PostPosted: 10:36 - 05 Oct 2020    Post subject: Reply with quote
First things first find out the standard carb settings reset them and go from there, if the carb is clean, undamaged and sealed properly (carb to head side) and it still doesn't idle then you have an issue somewhere else, fuel tap strainer, tank breather (located in the filler cap) kinked fuel line etc etc...
hirmalde
PostPosted: 19:39 - 06 Oct 2020    Post subject: Reply with quote
Thanks guys I'll check the tank breather. Definitely no water in the tank and yes it bogs down hard when revved. Refuses to rev in fact. Ordered a new carb now!
Fizzer Thou
PostPosted: 21:32 - 06 Oct 2020    Post subject: Reply with quote
Either or both of the intake manifold 'O' rings have split and so is leaking in too much air.Part #2 on the fiche
https://www.fowlersparts.co.uk/parts/5451555/ybr125ed-2005-3d91-europe-black-metallic-x/intake
By the looks of the diagram,there is a bleed tube off the side of the intake manifold.What happens if you blank that tube off with some tape or a cap?Does the engine rev properly then after resetting the carb back to the normal settings?It may well be that the hose going to that spigot has split somewhere along its length
Much cheaper than a new carb Wink
Always have a 'Plan B'
oilyrag
PostPosted: 17:11 - 07 Oct 2020    Post subject: Reply with quote
I'd start by checking the fuel level in the bowl. See if you're getting enough fuel to the bowl. Attach a clear hose to the carb drain and open the drain screw. Compare the fuel level to the spec in the manual.
The last post was made 6 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 66.8 Kb
