| hirmalde |
 hirmalde Derestricted Danger
 Posted: 14:28 - 03 Oct 2020 Post subject: Bike won't idle |
So I'm having a really tough time getting a ybr 125 to idle without choke. Trust me, I've done pretty much everything there is to do bar putting in a new carb altogether but still it just revs down and dies. Single carb, no diaphragm.
Idle screw is maxed out and even with full choke it can barely hold 1000rpm.
Any ideas?
Again, I have done pretty much everything or at least the things I have read up that may fix it but it still doesn't work. Looking for a detailed diagnosis path if anybody would be so kind?
I didn't realise this would get me so down but that's mechanicals for you!
Thanks in advance  |
| Nobby the Bastard |
| hirmalde |
| jaffa90 |
 jaffa90 World Chat Champion
| hirmalde |
| jaffa90 |
 Posted: 16:07 - 03 Oct 2020 Post subject: |
You could have unwanted air going in inbetween the carb and engine.
So it`s more fuel or less air at low revs.
WD Forte on here eats YBR`s for breakfast.  |
| Robby |
 Robby Dirty Old Man
 Posted: 12:56 - 04 Oct 2020 Post subject: |
I'll assume you're new to this and it's your first time cocking around with a carb.
First off, is the idle the only problem? Does it rev up cleanly and ride ok otherwise, or is it hesitant/lacking in power, getting worse as the bike warms up?
If so, you're probably operating the carb back to front. You're turning it off when it should be on, and vice versa.
Next up, drain the carb into a cup and look for water in the fuel. There is a drain screw on the bottom of the carb, possibly going into a narrow pipe that exits down around your right foot. There will be about half a cupful of fuel in the carb. If there is any water in there, it means you have water sitting in the bottom of your fuel tank.
Last thing if there is no water in the fuel and you were using the choke properly is to get the carb off the bike, strip and clean, and set everything up according to the workshop manual. Pay particular attention to float height and mixture screw setting. |
| Jozzer |
 Jozzer Two Stroke Sniffer
| hirmalde |
| Fizzer Thou |
 Posted: 21:32 - 06 Oct 2020 Post subject: |
Either or both of the intake manifold 'O' rings have split and so is leaking in too much air.Part #2 on the fiche
https://www.fowlersparts.co.uk/parts/5451555/ybr125ed-2005-3d91-europe-black-metallic-x/intake
By the looks of the diagram,there is a bleed tube off the side of the intake manifold.What happens if you blank that tube off with some tape or a cap?Does the engine rev properly then after resetting the carb back to the normal settings?It may well be that the hose going to that spigot has split somewhere along its length
Much cheaper than a new carb  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| oilyrag |
 oilyrag Nova Slayer
The last post was made 6 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
