Hoba VFR 800 Vtec - Low rev rattle/clatter. Cam chain?
krebsy
PostPosted: 13:35 - 01 Oct 2009    Post subject: Hoba VFR 800 Vtec - Low rev rattle/clatter. Cam chain? Reply with quote
Just noticed on my '53 plate VFR that at tickover there is a very percievable tapping noise. Only happens when the revs are low and the bike doesn't feel any different when riding. I was thinking that it might be something like the cam chain tensioner or the chain might've cracked a link or something.
Any thoughts and Ideas? I'd rather dothe fixing myself as the cost of servicing on a VFR is bloody stupid.. Wink
Ta,
K.
What's my New Year's resolution?
1280 x 1024.
PostPosted: 13:47 - 01 Oct 2009    Post subject: Reply with quote
Or more likely, the clutch.
They can get rattly after a period of time, the clutch basket gets notched. My VFR750 sounded like a Ducati before I took the clutch basket off and burred the edges of it straight again.
krebsy
PostPosted: 14:10 - 01 Oct 2009    Post subject: Reply with quote
cheers.
I'll give it another listen to and see.
Ta,
K.
1280 x 1024.
andys675
PostPosted: 15:40 - 01 Oct 2009    Post subject: Reply with quote
there aren't any camchains on your VFR, or any chain adjusters
only the big service should be dear as its takes ages to set up the clearances on a VTEC something like £700 is normal
clutch rattle or cam end float, normal VFR noises at tickover
There is a gap of 11 years, 5 days between these two posts...
RodRides This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
xX-Alex-Xx
PostPosted: 16:59 - 03 Oct 2020    Post subject: Re: Cam Chain Noise in your VFR Reply with quote
RodRides wrote:
It is common in as little as 35,000km for the cam chain tensioners on your VFR to slack and let the chains rattle. You can re-tension them though. See Video
https://youtu.be/UuYjv1t-pn8
It’s probably been fixed in the 11 years since this post was made. Wink
DILLIGAF
Robby
Dirty Old Man
PostPosted: 12:59 - 04 Oct 2020    Post subject: Reply with quote
RodRides embeds bestiality in his youtube videos.
bhinso
PostPosted: 21:08 - 04 Oct 2020    Post subject: Reply with quote
RodSpams more like.
Jozzer
PostPosted: 18:48 - 05 Oct 2020    Post subject: Reply with quote
Difficult one without actually hearing it but when we're the valve clearances last done ?...
A consistent tapping would suggest valve clearances, an audible rattle would suggest cam chain tensioner which aren't particularly reliable on Hondas and is something they should have sorted out years ago but never did for some reason...
Does it make a difference when it's hot or cold, not entirely sure if your particular VFR has a cam chain or is gear driven, some are and some aren't depending on year...
The last post was made 5 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 15 - Page Size: 59.9 Kb
