Chain Maintenence
struan80
PostPosted: 10:53 - 04 Nov 2020    Post subject: Chain Maintenence Reply with quote
Hello,
Can someone recommend some inexpensive chain oil please? Or what grade of oil.
I've got wax but in my head it is not getting in the nooks and crannies of the chain.
So I think I'm going to use oil first then wax from now on. I guess the wax will contain the oil.
What do you guys find best?
Thanks.
arry
PostPosted: 11:10 - 04 Nov 2020    Post subject: Reply with quote
Manufacturer recommendation is gear oil - it works, it's cheap and plentiful, and there's no reason not to use it.
Fortnine did a decent review:
https://www.youtube.com/watch?v=VnPYdcbcAe0
Easy-X
PostPosted: 11:53 - 04 Nov 2020    Post subject: Reply with quote
Everyone must be sleepy today if the word "Scottoiler" isn't in the first reply Wink
wr6133
PostPosted: 11:54 - 04 Nov 2020    Post subject: Reply with quote
Not a fan of waxes at all, whenever I try I just seem to end up with a chain that looks like it's been sporadically covered in Jizz.
I use this stuff, it doesn't fling too much. Sometimes they have it for sale in the Range for a few quid less. https://www.eurocarparts.com/p/wynns-clear-lube-500ml-555770010?type=shopping&gclid=CjwKCAiAv4n9BRA9EiwA30WNDx8KgDn7k5AQEwzpNL79xY36d7ZOjcfBO4Y8zw19XQxyCclu2-ZNfhoCvZ0QAvD_BwE
xX-Alex-Xx
PostPosted: 12:52 - 04 Nov 2020    Post subject: Reply with quote
I just clean my chain with a mix of 3 parts kerosene to 1 part engine oil. Cleans all the crap off and leaves a film of oil behind on the chain.
As above, Scottoilers work well too Wink
DILLIGAF
struan80
PostPosted: 13:07 - 04 Nov 2020    Post subject: Reply with quote
I think I'll go for gear oil coated in wax/ptfe thanks. The video just shows how we are being ripped off really.
Tankie
PostPosted: 14:17 - 04 Nov 2020    Post subject: Reply with quote
I use chainsaw lube applied with a Scottoiler, have done for years, it not only lubes the chain it keeps it clean, cheap as chips.
kramdra
PostPosted: 01:27 - 05 Nov 2020    Post subject: Reply with quote
Used engine oil. The challenge being to be on the last drips before the next oil change. Last year I got through all 3 litres. Plenty of fling will keep it clean.
Riejufixing
PostPosted: 10:39 - 05 Nov 2020    Post subject: Reply with quote
Who's tried similar to:
https://www.aliexpress.com/item/32953598658.html?spm=a2g0o.productlist.0.0.4b877c0d9obQhc&algo_pvid=20714deb-9670-44a9-bad2-3466ae06ae73&algo_expid=20714deb-9670-44a9-bad2-3466ae06ae73-0&btsid=0b0a050116045686173581481edeec&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
or:
https://www.aliexpress.com/item/4001163145946.html?spm=a2g0o.productlist.0.0.6c4b2f74y91NtK&algo_pvid=3a4ae0e8-5e6c-477d-81de-c348bdc08ecc&algo_expid=3a4ae0e8-5e6c-477d-81de-c348bdc08ecc-22&btsid=2100bb4716045689466931238e49bb&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Tankie
PostPosted: 11:43 - 05 Nov 2020    Post subject: Reply with quote
same item can be found on fleabay from the far east and i think shipping will be faster.
Tdibs
PostPosted: 12:15 - 05 Nov 2020    Post subject: Reply with quote
https://www.hse.gov.uk/mvr/topics/oil.htm
ThatDippyTwat
PostPosted: 14:13 - 05 Nov 2020    Post subject: Reply with quote
Used 10w40 from your oil changes. It's free.
Fisty
PostPosted: 21:49 - 05 Nov 2020    Post subject: Reply with quote
Fit a scottoiler.
Win at life.
Ignore Kramdras advice.
Win even harder.
Fatter and faster than Fret
trevor saxe-coburg-gotha
PostPosted: 22:32 - 05 Nov 2020    Post subject: Reply with quote
EP90 along the run of the chain before every ride, clean the chain w/ diseasel or wd every 500 miles (or after every ride in rain), and get 50k plus on chain and rear sprocket (front sprocket needs changing 2 or 3 times in that distance).
Islander
PostPosted: 23:10 - 05 Nov 2020    Post subject: Reply with quote
Scotoiler or PD Oiler would be my first choice. EP90 gear oil is good too.
Don't use used engine oil it'll have acids and other contaminants in it.
Old Git Racing
PostPosted: 09:46 - 06 Nov 2020    Post subject: Reply with quote
B&Q chainsaw oil, in an auto oiler. clean with white spirit every 500m
OGR
sickpup
Old Timer
PostPosted: 10:48 - 06 Nov 2020    Post subject: Reply with quote
Considering that engine oil carries metal 'bits' out of the engine I have to wonder if this is a good idea.
yen_powell
PostPosted: 11:03 - 06 Nov 2020    Post subject: Reply with quote
Back when I was a chain drive peasant (about 2 months ago) I would drip a bit of Halfords car oil on the inside run of the chain only, aiming at the x-rings, then run the bike in gear on the centre stand for a few seconds. I did this if it looked dry or after I got in from a rainy ride.
I have never cleaned a chain at all. I was getting around 30-40,000 miles from a chain and sprocket set and would only change them if I had to adjust it more than once every 6 months. This was on FJ1200s,750 Africa Twins (run them looser than Honda say), Varadero 1000 and Versys 1000.
XT1200Z and a DR350 in bits
Kawasaki Jimbo
PostPosted: 11:30 - 06 Nov 2020    Post subject: Reply with quote
I don't clean the chain these days either. 1 Litre of 90W gear oil is less than £10, is about the same viscosity as clean engine oil and will last for years. I brush it onto the full length of the chain (all sides), then wipe off the excess with a rag. I do this quite infrequently, there's almost no fling and the chain doesn't pick up grit like it did when I used sticky aerosols. Chain and sprockets get changed as a set and do around 40,000 miles.
I don't 'get' Scottoilers (a infrequent drop of oil falling onto one part of a spinning chain? How can that work?) except that it uses gear oil Thumbs Up and owners are likely to be fastidious despite the "fit and forget" claim.
xX-Alex-Xx
PostPosted: 12:50 - 06 Nov 2020    Post subject: Reply with quote
Also acidic from piston blowby contamination and lost a lot of its shear resistance.
It's not like NEW oil is expensive or you need a lot to keep a chain lubed Confused
DILLIGAF
Islander
PostPosted: 13:17 - 06 Nov 2020    Post subject: Reply with quote
They work, hence their popularity. Set to drip once a minute, over time the whole chain is going to get its share of fresh oil. It doesn't always fall on the same part you know Razz
xX-Alex-Xx
PostPosted: 13:40 - 06 Nov 2020    Post subject: Reply with quote
I don't get how gravity works but here I am stuck to the ground... Laughing
DILLIGAF
Kawasaki Jimbo
PostPosted: 14:46 - 06 Nov 2020    Post subject: Reply with quote
Laughing I don't doubt gravity, I do doubt that a dropper hovering above one side of the chain will alone provide complete lubrication. However, if all that's required is to lubricate the the roller/sprocket interface maybe that's enough. I like overall rust protection too though, including the side plates.
I suspect that an unlubricated O-ring chain would last a surprisingly long time. I'm just not prepared to try it!
https://www.webbikeworld.com/wp-content/uploads/2011/12/scottoilier-dispenser-tip-mounting-location.jpg
Tankie
PostPosted: 15:20 - 06 Nov 2020    Post subject: Reply with quote
Well Jimbo they do work , and very well ,these things have been on the market for years.
Some early Jap machines had chain oilers as a standard fitment e.g. Kawasaki H2
FretGrinder
PostPosted: 20:00 - 06 Nov 2020    Post subject: Reply with quote
This.
Started with the spray on stuff for ease of use, then moved onto gear oil as that's what the manual recommended, then discovered the awesomeness of the scottoiler Thumbs Up
Yamaha MT-09
ಠ_ಠ
The last post was made 5 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 127.8 Kb
