Chain vs Belt vs Shaft
Easy-X
PostPosted: 20:08 - 06 Nov 2020    Post subject: Chain vs Belt vs Shaft Reply with quote
I saw a YT vid on belt drive conversion... for a push bike Shocked but recently I've discovered* there are plenty of belt drive conversion kits for motorbikes.
Just wondering on the pros & cons of such a thing. For example, does a belt dispense with the need for the cush drive?
Then I thought "can shaft-drives have torque converters?"
One of my many "you know nothing, Jon Snow!" threads Shifty
*As in "you twat, they've been out for ages"
Riejufixing
PostPosted: 20:45 - 06 Nov 2020    Post subject: Re: Chain vs Belt vs Shaft Reply with quote
A toothed belt is just like a gear or a chain drive, and it is not supposed to stretch significantly.
PostPosted: 22:00 - 06 Nov 2020    Post subject: Reply with quote
Having owned 3 belt drive bikes, I feel like I can speak from some level of knowledge on the subject.
None of the bikes in question had cush drives. Although the Belt does not stretch, it does have some level of flex in it.
A belt drive is actually more expensive than the equivalent chain and sprockets because the belt pulleys need to be more accurately machined and mounted, and any damage to the pulley will wear the belt out quick smart. Belts themselves are often more expensive than chains and obviously harder to get. Tensioning is also an issue with some manufacturers going for crude fixed tensioners, and some putting in complex sprung tensioners - I think BMW produced a few bikes with no tensioner at all.
So why go belt drive? Well Buell went belt drive because Harley wanted them to differentiate from Japanese manufacturers (for no real reason other than fear!). There is no adjustment available because there is no need, so the wheel is always fixed and 100% in line with the front. You don't need to lube it, you don't need to adjust it, and belts can last about 40,000 miles if they are good quality and you make sure to check for little stones and stuff getting stuck between the belt and the pulley.
I think there is a limit in the power you can put through a belt, but they certainly do take a fair amount of torque.
I wouldn't change from a chain though, in fact there were loads of aftermarket manufacturers making chain conversion kits for belt drive bikes.
Robby
Dirty Old Man
PostPosted: 23:01 - 06 Nov 2020    Post subject: Reply with quote
A belt can last a stupidly long time. Some Harley riders on US forums claim upwards of 100k miles from a belt. They can also handle significant torque. This shouldn't be surprising, the belt is using clever aramid materials.
I prefer them to a chain, because I can ignore the belt and check/change the tension when I need a new rear tyre. Basically the same reasons I like shaft drive.
Downsides, particularly for sports bikes. You are unlikely to find different sprocket sizes, so your gearing is set where it is. The fact that they aren't used in racing suggests they wouldn't work for racing - possibly trouble with heat at sustained silly speeds. They are typically a bit wider than a chain, which could be an issue in a physically small bike with an already amusing setup for the chain run.
Far more expensive than a chain setup, and I'm less trusting of the pattern parts out there. So that means that a belt and sprockets is likely to cost £300-500 to be sure of decent parts.
Riejufixing
PostPosted: 00:42 - 07 Nov 2020    Post subject: Reply with quote
Drive belts do not stretch under normal circumstances, for obvious reasons. They flex, because they need to be flexible, to go around pulleys. If there is no cush drive, it is because it isn't needed, rather than "the belt does the job", which it does not and can not. I can't see any harm in having a belt on a cush drive, though, but ICBW.
Shaft
PostPosted: 00:51 - 07 Nov 2020    Post subject: Re: Chain vs Belt vs Shaft Reply with quote
That's a completely different transmission question.
Easy-X
PostPosted: 12:30 - 07 Nov 2020    Post subject: Re: Chain vs Belt vs Shaft Reply with quote
Yes, one of my unfortunate "stream of consciousness" moments Sad
Well it sounds like belts suit the sort of long haul, all mouth and no trousers cruiser aesthetic. Have Harley ever had a dabble with shaft drives?
PostPosted: 12:38 - 07 Nov 2020    Post subject: Reply with quote
The teeth are flexible though, unlike the teeth on a sprocket. The belt itself doesn't stretch like an elastic band, but the teeth do bend under load a little bit. I assume this provides the cush drive effect? It's going to have more 'give' in it than a chain, and also less lash which is the reason why cush drives are put onto bikes.
PostPosted: 14:39 - 07 Nov 2020    Post subject: Reply with quote
I'd go for belt drive all day long given the option, clean and minimal maintainance required. Mrs stinkwheels GPz305 was belt drive and it was tensioned exactly like a chain would be. Used to squeak sometimes.
In theory a chain delivers more power to the wheel, but that's a clean, well lubed and unworn chain.
Can I also present for consideration the fully enclosed chain drive. Those are good too.
WD Forte
PostPosted: 17:56 - 07 Nov 2020    Post subject: Re: Chain vs Belt vs Shaft Reply with quote
Yep, thas exactly what automatic cars have innit?
For a bike though, whilst doable it would be a complex
and very expensive bit of over engineering few would seriously
consider or bother with.
I likes me shaftys me but
I'd rather have a belt than a chain for its simplicty and reliability
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 18:12 - 07 Nov 2020    Post subject: Reply with quote
Nobody has mentioned hydraulic motors....
Triumph Sprint ST 1050
WD Forte
PostPosted: 18:22 - 07 Nov 2020    Post subject: Reply with quote
Yep, doable, but that's adding more complexity/cost though innit?
engine to power pump then pipework to hubs al la diggers n stuff
You could also have the engine drive a genny to power electric hubs
What about steam?
No one mentions steam any more, not fair
i wouldn't mind having a coal scuttle full of nutty slack
in place of the tank to power my chuff chuff bike
bikers smell of wee
Robby
Dirty Old Man
PostPosted: 18:32 - 07 Nov 2020    Post subject: Reply with quote
Honda DN-01 used hydraulic drive to the rear wheel. I want one.
PostPosted: 18:34 - 07 Nov 2020    Post subject: Reply with quote
With good reason. Production bikes don't use them. I'm sure there must be some funky Doc Brown contraptions out there but in general converting from mechanical to hydraulic and back to mechanical is woefully inefficient.
I'm hoping that battery and motor technology improves enough so I can experience 2-wheel drive direct drive electric power in a motorbike, before I get too old.
PostPosted: 01:53 - 08 Nov 2020    Post subject: Reply with quote
Yamaha did some production bikes with a hydraulic motor in the front hub.
PostPosted: 08:16 - 08 Nov 2020    Post subject: Reply with quote
Ohlins add-on wasn't it, in a desert racer? I think they only made limited numbers just enough so they could call them production bikes but I don't think they were sold to the public for use on the road. I remember the journo's article raging about it driving out of corners in the dirt which means that for the application the system would have been a benefit I guess.
PostPosted: 11:46 - 08 Nov 2020    Post subject: Reply with quote
WR450F 2-trac. I remember seeing them for sale in the Yamaha catalogue.
They made a couple of concept sportsbikes with the same system. Apparently almost impossible to lowside. Even if the rear spins up and steps out, you could still steer the thing round the corner with the front wheel.
PostPosted: 12:00 - 08 Nov 2020    Post subject: Reply with quote
And since were covering all our bases. Two early drive systems.
How about direct crank drive. Hildebrand & Wolfmüller. https://youtu.be/jbbsDds1tbU
Or Wheel mounted gnome rotary. Megola.
https://youtu.be/c4Cq49IDfOc
And of course the velosolex, roller-friction drive.
https://youtu.be/BLxuQ0S_Qg8
Easy-X
PostPosted: 14:39 - 08 Nov 2020    Post subject: Reply with quote
Oh hai! The guys from the Speedway called, they want a word Wink
PostPosted: 16:58 - 08 Nov 2020    Post subject: Reply with quote
Although they lowside fairly frequently.
sickpup
Old Timer
PostPosted: 22:37 - 08 Nov 2020    Post subject: Reply with quote
No it didn't, it used a shaft. It did use a hydrostatic CVT or something though.
TravisBickle
PostPosted: 06:40 - 15 Nov 2020    Post subject: Reply with quote
I think I read somewhere Yamaha done a 2WD WRX450 that had hydraulic drive on the front wheel???
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
TravisBickle
PostPosted: 06:43 - 15 Nov 2020    Post subject: Reply with quote
Sorry stinkwheel just seen you beat me to it. That's it the 2trac. I looked to buy one recently but couldn't find one for love nor money. Wonder why it didn't take on?
2024 BMW M1000XR
The last post was made 5 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 127.63 Kb
