| Easy-X |
 Easy-X Super Spammer
 Posted: 20:08 - 06 Nov 2020 Post subject: Chain vs Belt vs Shaft |
I saw a YT vid on belt drive conversion... for a push bike but recently I've discovered* there are plenty of belt drive conversion kits for motorbikes.
Just wondering on the pros & cons of such a thing. For example, does a belt dispense with the need for the cush drive?
Then I thought "can shaft-drives have torque converters?"
One of my many "you know nothing, Jon Snow!" threads
*As in "you twat, they've been out for ages" ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Riejufixing |
 Riejufixing World Chat Champion
| MarJay |
 MarJay But it's British!
 Posted: 22:00 - 06 Nov 2020 Post subject: |
Having owned 3 belt drive bikes, I feel like I can speak from some level of knowledge on the subject.
None of the bikes in question had cush drives. Although the Belt does not stretch, it does have some level of flex in it.
A belt drive is actually more expensive than the equivalent chain and sprockets because the belt pulleys need to be more accurately machined and mounted, and any damage to the pulley will wear the belt out quick smart. Belts themselves are often more expensive than chains and obviously harder to get. Tensioning is also an issue with some manufacturers going for crude fixed tensioners, and some putting in complex sprung tensioners - I think BMW produced a few bikes with no tensioner at all.
So why go belt drive? Well Buell went belt drive because Harley wanted them to differentiate from Japanese manufacturers (for no real reason other than fear!). There is no adjustment available because there is no need, so the wheel is always fixed and 100% in line with the front. You don't need to lube it, you don't need to adjust it, and belts can last about 40,000 miles if they are good quality and you make sure to check for little stones and stuff getting stuck between the belt and the pulley.
I think there is a limit in the power you can put through a belt, but they certainly do take a fair amount of torque.
I wouldn't change from a chain though, in fact there were loads of aftermarket manufacturers making chain conversion kits for belt drive bikes. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Robby |
 Robby Dirty Old Man
| Riejufixing |
| Shaft |
 Shaft World Chat Champion
| Easy-X |
| MarJay |
 Posted: 12:38 - 07 Nov 2020 Post subject: |
| Riejufixing wrote: | | MarJay wrote: | Although the Belt does not stretch, it does have some level of flex in it. |
Drive belts do not stretch under normal circumstances, for obvious reasons. They flex, because they need to be flexible, to go around pulleys. If there is no cush drive, it is because it isn't needed, rather than "the belt does the job", which it does not and can not. I can't see any harm in having a belt on a cush drive, though, but ICBW. |
The teeth are flexible though, unlike the teeth on a sprocket. The belt itself doesn't stretch like an elastic band, but the teeth do bend under load a little bit. I assume this provides the cush drive effect? It's going to have more 'give' in it than a chain, and also less lash which is the reason why cush drives are put onto bikes. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| stinkwheel |
 Posted: 14:39 - 07 Nov 2020 Post subject: |
I'd go for belt drive all day long given the option, clean and minimal maintainance required. Mrs stinkwheels GPz305 was belt drive and it was tensioned exactly like a chain would be. Used to squeak sometimes.
In theory a chain delivers more power to the wheel, but that's a clean, well lubed and unworn chain.
Can I also present for consideration the fully enclosed chain drive. Those are good too. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
| Nobby the Bastard |
| WD Forte |
| Robby |
 Robby Dirty Old Man
| Pete. |
 Pete. Super Spammer
| stinkwheel |
| Pete. |
 Pete. Super Spammer
| stinkwheel |
| stinkwheel |
| Easy-X |
| stinkwheel |
| sickpup |
 sickpup Old Timer
| TravisBickle |
 TravisBickle World Chat Champion
| TravisBickle |
The last post was made 5 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
