Info on halogen bulbs please
meyrick
PostPosted: 19:34 - 02 Apr 2005    Post subject: Info on halogen bulbs please Reply with quote
Hi,
I'm in the process of replacing my tungsten unit with a halogen one via relays etc. and I'm a bit puzzled by the new bulb (it's a 55/60 P43T by the way). I was trying to figure out which pin was for high beam and which for dipped beam and I am still none the wiser. The thing is, according to my multimeter each of the three pins is connected to the other two by almost no resistance (~1ohm). That can't be right can it?
So I guess my questions are:
1.) Which pin is high and which is dipped and should they be + or - (I'm assuming the other pin is a common + or -).
And:
2.) Is my bulb buggered? What's with all the pins being connected to each other?
The bulb looks fine on inspection, it's not blown and I bought it this morning. Help me get back on the road while the weather's still good!!! Praying Cheers Thumbs Up
Fortuna
PostPosted: 17:12 - 03 Apr 2005    Post subject: Reply with quote
OK here goes,
I don't have the pin out but will search for you.
Yes less than 10 ohms is correct as the filament is metal and therefore a good conductor. As it has a low resistance a lot of current can pass through lighting it up.
On a halogen lamp there will be one ground and two live feeds (dip and main).
meyrick
PostPosted: 19:35 - 03 Apr 2005    Post subject: Reply with quote
Fortuna wrote:
OK here goes,
Cheers Thumbs Up I just took another look at the bulb and - duh! - I see now how all the pins are connected. I was expecting...hell I have no idea what I was expecting, I just had it all wrong in my head.
I can't find the pin out info anywhere, despite multiple google attempts. I think it's time to go into the garage with some battery leads and a pair of sun glasses - lol Laughing
Thanks for posting Thumbs Up
meyrick
PostPosted: 22:44 - 03 Apr 2005    Post subject: Reply with quote
I just went into the garage and tested the bulb inside the headlight unit to determine the pin out. As it was such a pain, here are my findings for any who may need them in future:
Assuming you are looking at the back end of a P43T also known as an H4 halogen bulb...
Fortuna
PostPosted: 15:37 - 04 Apr 2005    Post subject: Reply with quote
Bit late, but I can confirm that is correct. As long as it's H4 you should be good to go Thumbs Up
meyrick
PostPosted: 15:52 - 04 Apr 2005    Post subject: Reply with quote
Cheers Thumbs Up I'm just about to enter the 'birds nest' inside the CB125T headlight and wire it all up Laughing
The last post was made 21 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 48.3 Kb
