Bolt on cylinder head snapped.
DarrenJ
PostPosted: 00:49 - 04 Apr 2005    Post subject: Bolt on cylinder head snapped. Reply with quote
On the cylinder head one of the four bolts has snapped off. Will I have to get it fixed or will it be alright running of three?
tatters
Exxon Valdez
PostPosted: 00:53 - 04 Apr 2005    Post subject: Reply with quote
you should really get it replaced or your cyclinder head might leak.
what bike is it by the way?
PostPosted: 01:39 - 04 Apr 2005    Post subject: Reply with quote
Yes, you will need to replace it. If you run the bike for any period of time you will warp the cylinder head and cost yourself even more money replacing it/getting it skimmed.
BFG
PostPosted: 14:24 - 04 Apr 2005    Post subject: Reply with quote
Absolutely.
Depending where the break is, it might be an engine out job. But let's hope not. Can you post a photo?
tatters
Exxon Valdez
PostPosted: 14:43 - 04 Apr 2005    Post subject: Reply with quote
hopefully if its just the head of the bolt has snaped off you might be able to get a hole of it with a stud extractor or some mole grips. next time you do the cyclinder head bolts up use a torque wreach set to the correct torque and tighten in a opersite sequnce. 1,4,2,3
Frost
PostPosted: 15:59 - 04 Apr 2005    Post subject: Reply with quote
If the stud is mashed, take the head off and put a nut onto the stud. put another nut onto i winding down the first to make room.
Undo the lower nut whilst tightening the upper nut crushing the two nuts together. you can then undo the lower nut which will undo the stud completely. Use the same method to put another stud in and put a new bolt on.
hope that helps
The last post was made 21 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 47.76 Kb
