Socket set - is 1/2" needed?
Freddyfruitba...
PostPosted: 18:48 - 16 Dec 2020    Post subject: Socket set - is 1/2" needed? Reply with quote
My son - fledgling biker - is hoping to find a socket set in his Xmas stocking.
Personally I have a motley collection of sockets and bits collected over many years, whereas he's starting from scratch. I've been wondering what would be best to get him started, and like the look of the 34-piece Bahco S330 set. I do like Bahco kit, and that one is 1/4" and 3/8" which I'd have thought that would be suitable for most bike applications, with the notable exception of the rear wheel, right? (that being pretty necessary for chain adjustment). So, maybe I just buy the Bahco set plus the appropriate socket and handle for the wheelnut in 1/2"? I'm a bit out of touch with this TBH, since these days I ride a shaftie (ie no chain adjustment to do Thumbs Up) and don't do a hell of a lot of spannering these days anyway.
Thoughts?
PostPosted: 18:54 - 16 Dec 2020    Post subject: Reply with quote
I use 1/4 and 3/8 for almost everything.
Exception is the recessed rear wheel nuts on my VFR which is single side swingarm but I usually use one of those extending car wheel-braces for that.
I use big ring spanners for the wheel nuts on my other bikes.
Most of the things I use a 1/2" drive for are huge and you wouldn't get the socket in a standard set anyway. Like the 30mm for the top yoke nut.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:55 - 16 Dec 2020    Post subject: Re: Socket set - is 1/2" needed? Reply with quote
Thoughts?
Up to about 11mm, 1/4". You can do it with an adaptor socket with a 3/8" drive. Anything up to and including about 20mm fine with 3/8". It's only the really big stuff that really needs 1/2", but I tend to try and overlap drive size wherever I can.
Edit: An example, The pinch bolt for the swing arm on the strumpet is 17mm which is on the bottom end of big enough for 1/2", but my torque wrench that can do 55nm is 3/8". By comparison, the wheel retaining nut has to go up to about 155nm and is about 46mm in size.
Triumph Sprint ST 1050
xX-Alex-Xx
PostPosted: 20:17 - 16 Dec 2020    Post subject: Reply with quote
Only thing I really use half inch on is socket for the rear axle which IIRC is around the 35mm mark.
Everything else is 3/8. Won’t go wrong with a full set in that size.
DILLIGAF
NJD
PostPosted: 20:38 - 16 Dec 2020    Post subject: Re: Socket set - is 1/2" needed? Reply with quote
Thoughts?
As a gift for someone that is looking to get into working on their own bike for the first time I'd say this halfords dedicated 1/4 drive set because that was my first proper set and saw me through the majority of my basic spannering needs at the time. Thereafter I purchased what I needed when I needed it and eventually moved onto a full sized socket set and haven't stopped buying things since.
Whilst adequate for most things a 1/4 drive set alone wont undo everything, as you point out. When I first started adjusting chains I used a socket and ratchet to hold the axle and a large spanner of the correct size to undo the axle lock nut. Adjusting the chain adjusters required two ring spanners (open ended on one side and ring on the other) spanners and a steel ruler to measure chain slack. These days I whip the impact out to save my back, but that's a bit fancy for a new-goer. Likewise I never used to torque the axle up, but now do, and so there's another expensive (torque wrench).
I wouldn't worry about covering all basis because I've been buying hand tools for years and still see something new that takes my fancy basically every week.
Personally I'd recommend the Halfords and Sealey brands for hand tools in this case. IMO their a good mixture of quality at a decent price that's more than adequate for the home mechanic.
Your lads going to want a set of 3/8 sockets, spanners, pliers, hammers, tubs of grease, tooth brushes, wipes etc etc in no time. I'd leave the bulk of investment up to him in the long run.
Try to stick with dedicated 6 sided sockets where you can. Thumbs Up
Introduce him to the Halfords modular tray's and he wont go far wrong in the long run.
edit:
Search "FFX" on Google (usually good for prices on Sealey branded items). You could request a free catalogue from the Sealey site so he's got a guide to look for things in the future.
Likewise Amazon warehouse or Cash Converters sometimes throws up bargains.
Freddyfruitba...
PostPosted: 20:45 - 16 Dec 2020    Post subject: Reply with quote
That's great - thanks all for confirming.
So, Bahco jobbie duly ordered.
I'd still quite like to obtain the necessary 1/2" socket for his rear axle, along with a handle, to go along with the set. The bike's a Suzuki Van Van, and according to Fowler's, it's a castellated nut, part number 083193114A or 08319-31148. So, any ideas how I can reasonably easily find out what size this is? Am drawing a blank via Google, and TBH I suspect even if I asked my son the question (he's 100 miles away) he wouldn't have a clue without being able to assess it against a correctly sized spanner or socket...
Hong Kong Phooey
PostPosted: 20:56 - 16 Dec 2020    Post subject: Reply with quote
He's going to also need to keep the axle from turning, normally you get a set of big spanners in the bike tool kit to fit, they're usually two different sizes.
If you put a large adjustable spanner, and a big set of locking pliers/mole grips on the list it should cover most bases.
Then he'll just need to learn how to use them properly Laughing
Kawasaki Jimbo
PostPosted: 21:03 - 16 Dec 2020    Post subject: Reply with quote
Hong Kong Phooey wrote:
on the list
Torque wrench.
Pass the popcorn
Pigeon
PostPosted: 22:37 - 16 Dec 2020    Post subject: Reply with quote
Tend to go by torque wrench capability
1/4 = 5-25Nm (switch to 3/8 @ 20Nm)
3/8 = 10-65Nm (switch to 1/2 @ 55Nm)
1/2 = 30-210Nm
Generally a 3/8 will do. You get to know the majority of ratings and for the extra (circa 70Nm front axle, 80Nm swingarm, 90Nm rear axle), can have specific sockets on a breaker bar to take it the extra.
But a 1/2 set on top of a 3/8 isn't a bad investment over time. Useful for other tasks too.
Easy-X
PostPosted: 22:49 - 16 Dec 2020    Post subject: Reply with quote
Of course there's the other way round where you take a 1/2" wrench and put on a 1/4" adaptor and you twist the end off Shocked
Not that I would know, just something I was told, I'll get my coat...
WD Forte
PostPosted: 01:02 - 17 Dec 2020    Post subject: Reply with quote
Always had a 1/2" set cos lotsa car/van work and its mostly useful for bike work until it gets bit delicate then I use a 1/4" set for 10mm and 8mm headed bolts.
Nowt wrong with a 3/8 set of course but the two above have always covered my needs and never felt any real need 3/8
bikers smell of wee
MCN
PostPosted: 17:56 - 17 Dec 2020    Post subject: Reply with quote
I use 1/4 rarely.
I use 3/8 as standard. Bacho are superb socket sets.
A nice wee kit is their little 1/4 drive set. The ratchet is a little ratchet spanner that takes screwdriver bits.
There is a screwdriver bit with a 1/4 drive square to drive the 1/4 sockets in the set.
It could probably do as an under the seat kit. About the size of a fag packet.
https://saudi.desertcart.com/products/48153244-bahco-2058s26-ratchet-socket-bit-set-26-piece?gclid=CjwKCAiAoOz-BRBdEiwAyuvA6xgKAkNi6PFP7nxK2rGCjU4Lv7Lfsjm3aPClRsszW_JBF18KhPFXaBoC3bEQAvD_BwE
Anything up to 7/8 AF is ok with 3/8. (7/8 is getting up there for 3/8 though)
The torque required for stuff bigger than that kinda exceeds the capability of 3/8.
Ratchets get blown out quick, swivel pins/hinge joints stretch and the effort required becomes Olympian.
1/2 for wheel spindles and frame pivot nuts.
A bar, ratchet extensions and bike specific 1/2 sockets do fine.
ThatDippyTwat
PostPosted: 19:04 - 17 Dec 2020    Post subject: Reply with quote
I use 1/4" for most things. I break out the 1/2" when I have a big or stuck bastid to move (46mm hub nut on the VFR etc). 1/4" is more useful, but if you can pick up a Halfords Advanced set on one of the half price offers, it would be rude not to.
virus
PostPosted: 22:36 - 17 Dec 2020    Post subject: Reply with quote
1/2 = 30-210Nm
c'mon now, knock it off with the sensible advice. We all know youre supposed to give it 12 ugga duggas with the windy gun then when it strips the thread back it off half a turn and blame the next person to touch it.
own: 81 xs1100g...
WD Forte
PostPosted: 23:26 - 17 Dec 2020    Post subject: Reply with quote
For soem reason this has reminded me of the flogging spanners
we used back in my apprenticeship days
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Ftse1.mm.bing.net%2Fth%3Fid%3DOIP.TOmV9IZyIe0Tp5PiItoC5wAAAA%26pid%3DApi&f=1
bikers smell of wee
NJD
PostPosted: 14:09 - 18 Dec 2020    Post subject: Reply with quote
Well now's the time to learn: tell him to use the open end of a spanner and keep going down sizes one by one until he finds the one that doesn't fit, and then go up one and that's the correct size you'll need.
Send him down to Halfords to get this spanner set if he doesn't have one. It isn't their advanced range (so no warrenty, I believe) but will last him well and contains more than the sizes he'll need.
smokin joe
PostPosted: 17:54 - 18 Dec 2020    Post subject: Reply with quote
Like most people I've built up my toolkit as I've gone along buying what I needed at the time. Over fifty years of this has left me with a load of stuff that is scattered in various boxes in the garage where it can take ages to find what I need when doing a job on car or bike. Some of it is good quality, some so-so and some cheap crap.
Under the tree is my present from Santa this year - a 150 piece Halfords advanced socket and spanner set. Everything I need all in one box and top quality with a lifetime guarantee.
https://www.halfords.com/tools/hand-tools/socket-sets/halfords-advanced-150-pc-socket-and-spanner-set-735906.html
I am one happy bunny Very Happy Very Happy Very Happy Very Happy Very Happy
oilyrag
PostPosted: 21:20 - 18 Dec 2020    Post subject: Reply with quote
What about a multimeter and a test light? Both very useful and don't cost much.
Islander
PostPosted: 22:26 - 18 Dec 2020    Post subject: Reply with quote
Yes to the multimeter - it's an essential part of a toolkit. Test lamps not so much IMO but it's whatever you're used to really Smile
oilyrag
PostPosted: 23:46 - 18 Dec 2020    Post subject: Reply with quote
If you want to test a circuit properly you have to put a load on it. Using a test light or any bulb puts a load on the circuit. A multimeter doesn't load the circuit. Also you can use a test light as an easy way to supply 12V or ground to a circuit which you can't do with a multimeter. They are very useful if you know how to use them and they're cheap. You can even make your own with different amperage bulbs for different size circuits.
WD Forte
PostPosted: 01:10 - 19 Dec 2020    Post subject: Reply with quote
You are William Heath Robinson and I claim my five ponds
bikers smell of wee
oilyrag
PostPosted: 10:48 - 19 Dec 2020    Post subject: Reply with quote
On the higher current circuits like starter motor circuit a test light is not much of a load. A head light bulb would be about 5 amp. Better than the test light. The multimeter showing 12V doesn't mean anything if there's no current flow
The last post was made 5 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 122.4 Kb
