| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
 Posted: 18:48 - 16 Dec 2020 Post subject: Socket set - is 1/2" needed? |
My son - fledgling biker - is hoping to find a socket set in his Xmas stocking.
Personally I have a motley collection of sockets and bits collected over many years, whereas he's starting from scratch. I've been wondering what would be best to get him started, and like the look of the 34-piece Bahco S330 set. I do like Bahco kit, and that one is 1/4" and 3/8" which I'd have thought that would be suitable for most bike applications, with the notable exception of the rear wheel, right? (that being pretty necessary for chain adjustment). So, maybe I just buy the Bahco set plus the appropriate socket and handle for the wheelnut in 1/2"? I'm a bit out of touch with this TBH, since these days I ride a shaftie (ie no chain adjustment to do ) and don't do a hell of a lot of spannering these days anyway.
Thoughts? ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
| stinkwheel |
 Posted: 18:54 - 16 Dec 2020 Post subject: |
I use 1/4 and 3/8 for almost everything.
Exception is the recessed rear wheel nuts on my VFR which is single side swingarm but I usually use one of those extending car wheel-braces for that.
I use big ring spanners for the wheel nuts on my other bikes.
Most of the things I use a 1/2" drive for are huge and you wouldn't get the socket in a standard set anyway. Like the 30mm for the top yoke nut. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
 Posted: 18:55 - 16 Dec 2020 Post subject: Re: Socket set - is 1/2" needed? |
| Freddyfruitbat wrote: | My son - fledgling biker - is hoping to find a socket set in his Xmas stocking.
Thoughts? |
Up to about 11mm, 1/4". You can do it with an adaptor socket with a 3/8" drive. Anything up to and including about 20mm fine with 3/8". It's only the really big stuff that really needs 1/2", but I tend to try and overlap drive size wherever I can.
Edit: An example, The pinch bolt for the swing arm on the strumpet is 17mm which is on the bottom end of big enough for 1/2", but my torque wrench that can do 55nm is 3/8". By comparison, the wheel retaining nut has to go up to about 155nm and is about 46mm in size. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| NJD |
 NJD World Chat Champion
 Posted: 20:38 - 16 Dec 2020 Post subject: Re: Socket set - is 1/2" needed? |
| Freddyfruitbat wrote: | Thoughts? |
As a gift for someone that is looking to get into working on their own bike for the first time I'd say this halfords dedicated 1/4 drive set because that was my first proper set and saw me through the majority of my basic spannering needs at the time. Thereafter I purchased what I needed when I needed it and eventually moved onto a full sized socket set and haven't stopped buying things since.
Whilst adequate for most things a 1/4 drive set alone wont undo everything, as you point out. When I first started adjusting chains I used a socket and ratchet to hold the axle and a large spanner of the correct size to undo the axle lock nut. Adjusting the chain adjusters required two ring spanners (open ended on one side and ring on the other) spanners and a steel ruler to measure chain slack. These days I whip the impact out to save my back, but that's a bit fancy for a new-goer. Likewise I never used to torque the axle up, but now do, and so there's another expensive (torque wrench).
I wouldn't worry about covering all basis because I've been buying hand tools for years and still see something new that takes my fancy basically every week.
Personally I'd recommend the Halfords and Sealey brands for hand tools in this case. IMO their a good mixture of quality at a decent price that's more than adequate for the home mechanic.
Your lads going to want a set of 3/8 sockets, spanners, pliers, hammers, tubs of grease, tooth brushes, wipes etc etc in no time. I'd leave the bulk of investment up to him in the long run.
Try to stick with dedicated 6 sided sockets where you can.
Introduce him to the Halfords modular tray's and he wont go far wrong in the long run.
edit:
Search "FFX" on Google (usually good for prices on Sealey branded items). You could request a free catalogue from the Sealey site so he's got a guide to look for things in the future.
Likewise Amazon warehouse or Cash Converters sometimes throws up bargains. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Freddyfruitba... |
 Posted: 20:45 - 16 Dec 2020 Post subject: |
That's great - thanks all for confirming.
So, Bahco jobbie duly ordered.
I'd still quite like to obtain the necessary 1/2" socket for his rear axle, along with a handle, to go along with the set. The bike's a Suzuki Van Van, and according to Fowler's, it's a castellated nut, part number 083193114A or 08319-31148. So, any ideas how I can reasonably easily find out what size this is? Am drawing a blank via Google, and TBH I suspect even if I asked my son the question (he's 100 miles away) he wouldn't have a clue without being able to assess it against a correctly sized spanner or socket... ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
 Posted: 20:56 - 16 Dec 2020 Post subject: |
He's going to also need to keep the axle from turning, normally you get a set of big spanners in the bike tool kit to fit, they're usually two different sizes.
If you put a large adjustable spanner, and a big set of locking pliers/mole grips on the list it should cover most bases.
Then he'll just need to learn how to use them properly  ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Pigeon |
 Pigeon World Chat Champion
| Easy-X |
 Easy-X Super Spammer
 Posted: 22:49 - 16 Dec 2020 Post subject: |
Of course there's the other way round where you take a 1/2" wrench and put on a 1/4" adaptor and you twist the end off
Not that I would know, just something I was told, I'll get my coat... ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| WD Forte |
 WD Forte World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 17:56 - 17 Dec 2020 Post subject: |
I use 1/4 rarely.
I use 3/8 as standard. Bacho are superb socket sets.
A nice wee kit is their little 1/4 drive set. The ratchet is a little ratchet spanner that takes screwdriver bits.
There is a screwdriver bit with a 1/4 drive square to drive the 1/4 sockets in the set.
It could probably do as an under the seat kit. About the size of a fag packet.
https://saudi.desertcart.com/products/48153244-bahco-2058s26-ratchet-socket-bit-set-26-piece?gclid=CjwKCAiAoOz-BRBdEiwAyuvA6xgKAkNi6PFP7nxK2rGCjU4Lv7Lfsjm3aPClRsszW_JBF18KhPFXaBoC3bEQAvD_BwE
Anything up to 7/8 AF is ok with 3/8. (7/8 is getting up there for 3/8 though)
The torque required for stuff bigger than that kinda exceeds the capability of 3/8.
Ratchets get blown out quick, swivel pins/hinge joints stretch and the effort required becomes Olympian.
1/2 for wheel spindles and frame pivot nuts.
A bar, ratchet extensions and bike specific 1/2 sockets do fine. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| virus |
 virus World Chat Champion
 Posted: 22:36 - 17 Dec 2020 Post subject: |
| Pigeon wrote: | Tend to go by torque wrench capability
1/4 = 5-25Nm (switch to 3/8 @ 20Nm)
3/8 = 10-65Nm (switch to 1/2 @ 55Nm)
1/2 = 30-210Nm
Generally a 3/8 will do. You get to know the majority of ratings and for the extra (circa 70Nm front axle, 80Nm swingarm, 90Nm rear axle), can have specific sockets on a breaker bar to take it the extra.
But a 1/2 set on top of a 3/8 isn't a bad investment over time. Useful for other tasks too. |
c'mon now, knock it off with the sensible advice. We all know youre supposed to give it 12 ugga duggas with the windy gun then when it strips the thread back it off half a turn and blame the next person to touch it. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| WD Forte |
| NJD |
| smokin joe |
 smokin joe Borekit Bruiser
 Posted: 17:54 - 18 Dec 2020 Post subject: |
Like most people I've built up my toolkit as I've gone along buying what I needed at the time. Over fifty years of this has left me with a load of stuff that is scattered in various boxes in the garage where it can take ages to find what I need when doing a job on car or bike. Some of it is good quality, some so-so and some cheap crap.
Under the tree is my present from Santa this year - a 150 piece Halfords advanced socket and spanner set. Everything I need all in one box and top quality with a lifetime guarantee.
https://www.halfords.com/tools/hand-tools/socket-sets/halfords-advanced-150-pc-socket-and-spanner-set-735906.html
I am one happy bunny  |
| oilyrag |
 oilyrag Nova Slayer
| Islander |
 Islander World Chat Champion
| oilyrag |
 oilyrag Nova Slayer
| WD Forte |
| oilyrag |
 oilyrag Nova Slayer
The last post was made 5 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
