Honda CB400SS Kick start and battery
Kister
PostPosted: 15:00 - 07 Jan 2021    Post subject: Honda CB400SS Kick start and battery Reply with quote
Hi. my Son has bought himself a nice Honda 400SS. I am remotely trying to help him with a starting issue but I'm a bit out of my depth as I have a nice big battery and an electric start!
He has the age of bike that has a 2.5AH battery and to me it always seems flat ie the headlamp will fade to nothing once the bike stops.
I figure that this means that the Battery is holding little to no charge.
I'm also ASSuming that if he had a battery that held a charge. the bike would be easier to start as the volts wouldn't all be disappearing into an empty battery and a headlight that you can't turn off!
Can anyone enlighten me as to whether this age of bike is simply like this or whether the battery does need replacing once the normal charge and discharge tests are carried out?
Thanks
C
PostPosted: 16:15 - 07 Jan 2021    Post subject: Reply with quote
Assuming this is the post-2000 hipster retro special?
I'd throw a battery into it.
The fact the headlamp comes on when the engine is run suggests the charging system is properly functional.
Sounds like the battery is utterly knackered. A more modern bike will need a certain amount of charge to power up the ignition.
A 2.5Ah battery costs next to nothing anyway.
Of course the best thing would be to do some actual testing with a voltmeter and see if it's holding a charge.
One caveat. The way this used to work in the 70's and 80's is the bike would have a seperate coil to produce the spark when kicked and the lighting ran directly from the engine (and went out when it was turned off) but I'm not aware of any post 2000 road bikes that work that way. It's possible Honda may have used the seperate charging coil thing in which case the battery is nothing to do with the engine running.
I can't find a wiring diagram for one (if you had one, I could tell you for sure) but they do appear to have a standard 5-wire regulator rectifier which suggests a conventional, battery-powered lighting system.
Robby
Dirty Old Man
PostPosted: 16:38 - 07 Jan 2021    Post subject: Reply with quote
Is it meant to have a battery that small? I only usually see 2.5Ah batteries on scooters.
I would replace the battery, but I would also make sure that the replacement is the correct battery. I would expect standard fit on that to be more like 8 or 10 Ah.
PostPosted: 16:57 - 07 Jan 2021    Post subject: Reply with quote
According to Tanya.co.uk 2.3Ah.
https://www.tayna.co.uk/motorcycle-batteries/f/honda/cb400-ss-03/
Even a motobatt is under £20.
Kister
PostPosted: 17:16 - 07 Jan 2021    Post subject: Thanks! Reply with quote
Yes. Def the right size! Tiny little thing. New battery ordered. Thanks for the info on the possible separate charging coil.
Cheers!
oilyrag
PostPosted: 19:40 - 07 Jan 2021    Post subject: Reply with quote
Tell him to buy a trickle charger too or he will be buying a lot of batteries. Seems it has an immobiliser so a dead battery could cause issues there. He could buy the service manual from Japan. If the bike was only made for Japan there won't be an English version of the manual. https://page.auctions.yahoo.co.jp/jp/auction/u404619532
Kister
PostPosted: 20:04 - 07 Jan 2021    Post subject: Reply with quote
Wow! an immobiliser. That is pretty advanced stuff! I will pass the message on. Cheers
oilyrag
PostPosted: 21:53 - 07 Jan 2021    Post subject: Reply with quote
There's a wiring diagram https://imp.webike.net/diary/171390/
It has DC CDI so the battery is part of spark
PostPosted: 00:56 - 08 Jan 2021    Post subject: Reply with quote
Agreed. Standard 3-phase DC setup with pulse coil. All alternator output goes to the battery. Battery voltage is required for correct functioning of the CDI.
If the lights go dim, it's impressive it's starting at all. I'd imagine he has to kick it over several times in rapid succession or bump start it.
MaybeGuy
PostPosted: 01:03 - 08 Jan 2021    Post subject: Reply with quote
BCF: making dads seem more knowledgeable than they really are since wheneverthefuck
Kister
PostPosted: 09:42 - 08 Jan 2021    Post subject: Reply with quote
Thank you so much. I guarantee that I shall take all the credit!
Cool
The last post was made 5 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 70.56 Kb
