| Kister |
 Kister Derestricted Danger
 Posted: 16:15 - 07 Jan 2021 Post subject: |
Assuming this is the post-2000 hipster retro special?
I'd throw a battery into it.
The fact the headlamp comes on when the engine is run suggests the charging system is properly functional.
Sounds like the battery is utterly knackered. A more modern bike will need a certain amount of charge to power up the ignition.
A 2.5Ah battery costs next to nothing anyway.
Of course the best thing would be to do some actual testing with a voltmeter and see if it's holding a charge.
One caveat. The way this used to work in the 70's and 80's is the bike would have a seperate coil to produce the spark when kicked and the lighting ran directly from the engine (and went out when it was turned off) but I'm not aware of any post 2000 road bikes that work that way. It's possible Honda may have used the seperate charging coil thing in which case the battery is nothing to do with the engine running.
I can't find a wiring diagram for one (if you had one, I could tell you for sure) but they do appear to have a standard 5-wire regulator rectifier which suggests a conventional, battery-powered lighting system. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| Kister |
| oilyrag |
 oilyrag Nova Slayer
 Posted: 19:40 - 07 Jan 2021 Post subject: |
Tell him to buy a trickle charger too or he will be buying a lot of batteries. Seems it has an immobiliser so a dead battery could cause issues there. He could buy the service manual from Japan. If the bike was only made for Japan there won't be an English version of the manual. https://page.auctions.yahoo.co.jp/jp/auction/u404619532 |
| Kister |
| oilyrag |
 oilyrag Nova Slayer
 Posted: 00:56 - 08 Jan 2021 Post subject: |
Agreed. Standard 3-phase DC setup with pulse coil. All alternator output goes to the battery. Battery voltage is required for correct functioning of the CDI.
If the lights go dim, it's impressive it's starting at all. I'd imagine he has to kick it over several times in rapid succession or bump start it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:03 - 08 Jan 2021 Post subject: |
BCF: making dads seem more knowledgeable than they really are since wheneverthefuck ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Kister |
The last post was made 5 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
