Laptop battery refurbishment companies?
PostPosted: 11:12 - 12 Jan 2021    Post subject: Laptop battery refurbishment companies? Reply with quote
Drawing a surprisingly fruitless google search.
I have an ultrasound scanner at work, it's portable but the battery pack is totally shot, to the point it can only be used plugged in and if you want to move it from one room to another, you have to shut it down and restart it again.
To all intents and purposes it's a glorified laptop with some very specialised inputs. The things are very expensive but I doubt the battery pack will be anything particularly special. May even be straight nickel hydride AAs in there.
Thing is, due to the £££££ aspect, I'm not poking abut in there. Can anyone recommend a company who can re-cell/refurbish a battery pack?
to v or not to v
PostPosted: 12:06 - 12 Jan 2021    Post subject: Reply with quote
we live in a throw away society. youll get a new battery i imagine. any pc repair shop should be able to do it. google is your friend.
xX-Alex-Xx
PostPosted: 12:22 - 12 Jan 2021    Post subject: Reply with quote
Just an additional option - you thought of hooking it up to a small UPS to keep it running when you move it around?
DILLIGAF
panrider_uk
PostPosted: 12:24 - 12 Jan 2021    Post subject: Reply with quote
I've used this company to replace the cells in a shot fluke network tester.
https://toolbatteriesrepair.co.uk/
The tester was no longer supported by Fluke and a replacement pack was £300 when they did support it.
The refurb cost was £60 or thereabouts.
Riejufixing
PostPosted: 13:02 - 12 Jan 2021    Post subject: Re: Laptop battery refurbishment companies? Reply with quote
Why not ask the maker (or post the machine's name and model so that the serried mass of BCFers can look it up and get into competition)?
Easy-X
PostPosted: 17:00 - 12 Jan 2021    Post subject: Reply with quote
Any battery pack that's removable should somewhere have a mark for Ni-Cad/Ni-MH/Li-Ion/Li-Poly/etc. for the purposes of recycling/disposal.
If it's lithium ion it's most likely a collection of 18650 batteries which are dead easy to get hold of. The tricky part is taking the casing to bits in such a way as to make reassembly possible and then the replacement cells would need spot welding in.
I've had about 50/50 success personally on repairing laptop batteries and it's always the dismantling part that cocks it all up.
PostPosted: 17:48 - 12 Jan 2021    Post subject: Reply with quote
I'm going to have a closer look tomorrow to see what tyoe it is. I do know a replacement battery was unobtainable from the maufacturer because others of my colleagues have tried before now.
The UPS idea is a neat one. Thinking outside the box. While the scanner is portable, it's kept on a trolley so a UPS would be no problem to attach.
WD Forte
PostPosted: 18:49 - 12 Jan 2021    Post subject: Reply with quote
Take pics, get any part numbers, find its rating re Volts and Amps and show us.
Knowing how it was assembled and what's inside will give clues
on how best to renovate it.
It may well be an array of 18650s but for all we know it may be Nimh or NiCads
so best to rebuild like for like due the charging characteristics otherwise
you'd have to mod the circuitry to suit as well.
If the original battery is NLA and repair is horribly expensive I'd be musing
over whether patching in an off the shelf rechargeable power pack would be
a viable option.
bikers smell of wee
PostPosted: 19:12 - 12 Jan 2021    Post subject: Reply with quote
Unless the battery is really obscure, it will be available elsewhere.
WD Forte
PostPosted: 20:01 - 12 Jan 2021    Post subject: Reply with quote
We have a solution.
Just needs a few straps to leave your hands free to
stick up coos bums and yer sorted
https://thingstheyshouldknow.files.wordpress.com/2015/01/3.jpg?w=600&h=600
bikers smell of wee
RhynoCZ
PostPosted: 20:58 - 12 Jan 2021    Post subject: Reply with quote
There definitely is a local lad who will take your device/battery pack apart and replace the battery cells. Those cells are widely available. Ali-china-express has tons of those for next to nothing.
WD Forte
Looks like this place has the ability to rebuild
a battery pack.
https://www.countybattery.co.uk/battery-pack-rebuilding/battery-pack-repair-rebuilding/
The pic shows them spot welding tags on batteries which is the trickiest bit
if you haven't got the kit.
They probably do power tool packs mostly but not exclusively.
Just seen the prices......
they go from around £50 to bend over
No idea what you have but larger pack repair can get pretty eye watering
bikers smell of wee
WD Forte
PostPosted: 21:13 - 12 Jan 2021    Post subject: Reply with quote
Mind you I'd be inclined to buy one of these and have a go at it
myself.
https://www.ebay.co.uk/itm/Mini-Welder-Pen-Display-Spot-Welder-Machine-Equipment-18650-Battery-Power-Supply/303825174944?hash=item46bd6441a0:g:KtUAAOSwz7Jf5uH9
Edit:
Been doing some research and fancy getting one for myself
but would do this mod before using it
https://www.youtube.com/watch?v=fdnO0Z-scjA
moar edits:
just ordered this one for £19.99 inc P&P
I reckon it will be handy and have a couple of iffy power packs
I can experimend on
https://www.ebay.co.uk/itm/Mini-Spot-Welder-Portable-Machine-Battery-Various-Welding-Power-Supply-Equipment/143911843061?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
bikers smell of wee
Easy-X
PostPosted: 22:50 - 12 Jan 2021    Post subject: Reply with quote
Depends on what you want to weld but those ghetto spot welders are probably only good for very thin nickel. This is what they use in the factories...
https://www.ebay.co.uk/itm/SUNKCO-1-5KW-737G-Spot-Welder-Battery-Spot-Welding-LED-Light-for-18650-Battery/123750214835
But to be fair it depends on your needs. Welding up 10S3P or bigger ebike batteries you really want to chew through the work.
PostPosted: 23:03 - 12 Jan 2021    Post subject: Reply with quote
There is no danger I'm doing it myself. I used five pound signs for a reason (It didn't cost that because we got it second hand but it would cost that to replace).
The last post was made 5 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 87.01 Kb
