Yamaha ybr 125 2009
Sockface
PostPosted: 17:13 - 18 Jan 2021    Post subject: Yamaha ybr 125 2009 Reply with quote
Does anyone know how to gain access to the battery compartment on left side of yamaha ybr 125 where I think battery is located as ignition key won't work! Sad
m.keo
NJD
PostPosted: 17:32 - 18 Jan 2021    Post subject: Reply with quote
It's the wrong key, or the lock is seized and turning it makes it feel like the key will snap (ie: you'd rather not put too much pressure on it and try)?
edit: I did mean to ask "is it the wrong key" rather than to forcefully suggest, my bad.
Riejufixing
PostPosted: 17:39 - 18 Jan 2021    Post subject: Reply with quote
I agree with this post.
If the ignition key won't work, it could also be wear of the key, or the lock itself. If you live in a cold place, it could also be that the lock has some water in it, which has frozen.
WD Forte
PostPosted: 18:17 - 18 Jan 2021    Post subject: Reply with quote
Did it ever work?
If it did previously, try pushing the cover in with one hand as you wiggle the key with the other.
bikers smell of wee
Sockface
PostPosted: 18:57 - 18 Jan 2021    Post subject: Reply with quote
Might break key if I force it will try some wd40 if doesn't work will use screwdriver thanks guys
m.keo
The last post was made 5 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 42.34 Kb
