Side stand longevity?
ThunderGuts
PostPosted: 15:25 - 19 Jan 2021    Post subject: Side stand longevity? Reply with quote
I'm being led to believe it's "normal" for a side stand pivot to wear out every few years and with sub 5 figure mileages (don't want to mention the marque or the dealer) - is this a load of rubbish, or reasonable? Replacement parts are well into three figures and only available OEM. Modern bike by the way, although that's probably given for this sort of issue.
Cheers. Thumbs Up
TG.
Freddyfruitba...
PostPosted: 16:59 - 19 Jan 2021    Post subject: Reply with quote
Sounds a bit shit to me... are you by any chance doing that thing where you turn the bike round by balancing/spinning it on the sidestand?
Bloggsy
PostPosted: 17:03 - 19 Jan 2021    Post subject: Reply with quote
As long as the side stand pivot get's a bit of lube, it should last for ever I have a 12 year old Yamaha MT-03 and the side stand is still going strong Thumbs Up
If It Aint broke Don't Fix It
reavsie
PostPosted: 17:24 - 19 Jan 2021    Post subject: Reply with quote
In nearly 40 years and over 350,000 miles on bikes I've never had a side stand or pivot issue. A couple of those bikes were close on 100k and pretty much all of them passed the 10k mark.
Or have I just been lucky?
Previously: GP100U, GP100U, RD200, GT380, GSX400, CX500, VT500, VT500, GS500, R80/RT, ER5, CB500, ER5, CB500, ER5, CB500X
Now: RE Himalayan
PostPosted: 17:26 - 19 Jan 2021    Post subject: Reply with quote
I have... but on a Buell, and it had a recall for it.
ThunderGuts
PostPosted: 17:59 - 19 Jan 2021    Post subject: Reply with quote
Nope, have never even performed that manoeuvre!
TG.
PostPosted: 18:07 - 19 Jan 2021    Post subject: Reply with quote
Seems excessive.
Sure there isn't an engineering solution to fix the existing one? Like fitting a sleeve/busing etc?
ThunderGuts
PostPosted: 18:16 - 19 Jan 2021    Post subject: Reply with quote
stinkwheel wrote:
Seems excessive.
I'm going to pull it apart shortly and have a proper look; bit wary of butchering it if I've got any chance of a warranty claim, but on the other hand if there's an easy fix I'll just do that instead. Chances are any work will require opening up the hole in the bracket, taking metal away . . . I'll see how substantial it looks. The bike in question isn't light . . .
TG.
Riejufixing
PostPosted: 18:20 - 19 Jan 2021    Post subject: Re: Side stand longevity? Reply with quote
I have not heard of that. I have had some prop stands wear at the pivot, but over a loong time.
ThunderGuts wrote:
(don't want to mention the marque ...)
Why not? Surely it's not *that* embarrassing!
PostPosted: 18:20 - 19 Jan 2021    Post subject: Reply with quote
If it's under warranty then yes, go for it. If it's not, post pics. There's probably a design fault so simply replacing it is just asking for a repeat performance.
boundy
PostPosted: 19:27 - 19 Jan 2021    Post subject: Re: Side stand longevity? Reply with quote
Cheers. Thumbs Up
I'm pretty sure the manufacturer won't try and sue you for slander, you gonna share or is it a secret?
xX-Alex-Xx
PostPosted: 19:49 - 19 Jan 2021    Post subject: Reply with quote
Never had an issue, and I use mine to do zero point turns all the time.
DILLIGAF
Weisse Schlange
PostPosted: 20:15 - 19 Jan 2021    Post subject: Reply with quote
35 yrs riding and never had an issue. Crappy side stand switches yes, but stand failure, nah ! not buying that dealers crap at all.
Hing Oan
ThunderGuts
PostPosted: 20:23 - 19 Jan 2021    Post subject: Reply with quote
It's a Honda. Told you it was embarrassing. Laughing It's literally a few days out of warranty but the issue was raised a little while ago.
Update anyway, took it apart and cleaned it up (lube is definitely not an issue as excess chain lube dribbles over it). So few things; the bolt isn't a perfect fit into the bracket on the frame, but to compound matters neither are the lugs on the side stand arm itself a good fit to the bracket. The hole in the bracket wasn't visibly ovalled and nor was there any other apparent wear signs. Maybe it's supposed to have play in it but other owners suggest not, or at least not much. Managed to work out an "engineering" solution (quotes because it's a tad Heath Robinson); fabricated a washer out of a PET bottle and popped this on one side of the bracket. Slathered it in grease and put back together. The stand is a tiny tiny bit stiff (but will doubtless loosen up in use) but all play has gone and the stand is solid. PET is usually pretty resistant to compression, so hopefully it'll have some life, but even if it fails it'll be sacrificial and cheap/easy to replace.
Time will tell, but looking at the bracket etc. I'm not convinced a replacement will be much different as it didn't look worn/mis-shapen.
Cheers for the input everyone. Thumbs Up
TG.
NJD
PostPosted: 20:25 - 19 Jan 2021    Post subject: Reply with quote
Maybe I've not been around long enough but the only trouble I'd expect from a side-stand would be corrosion around where the stand is welded to the foot plate, or on the foot-plate itself; therefore meaning it needed to be repaired via welding or replaced. Or, as above, with the side-stand switch due to corrosion again.
I don't think anyone buys a bike thinking they'd have to pay £100 or more every "few" years for it be repaired.
steve the grease
PostPosted: 22:58 - 19 Jan 2021    Post subject: Reply with quote
Sounds like a good repair to me. Tolerance issue , a bit to much clearance on the fork, bolt , the hole , the lug on the frame. Most stands are a bit loose after a few years , but not so much that it affects the performance - pet washer sounds like a bit of a brainwave. .
SirFallalot
PostPosted: 00:12 - 21 Jan 2021    Post subject: Reply with quote
Have the same with a 93 CB400 but it's got about 50k miles,it just causes the bike to lean too much but it's liveable, haven't gotten around to fix it.
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS
hellkat
PostPosted: 00:32 - 21 Jan 2021    Post subject: Reply with quote
ThunderGuts wrote:
It's a Honda.
At least its not a Harley, right?
Mine is proper dodge. Shocked
And that's only done about 25K, but its 30 years old.
People have stopped at traffic lights and told me its dragging on the ground (its not but its quite loose) although if I go round too low on a left turn, I can sometimes hear it actually drag, eeeek.
So if I turn left now, I am more conscious of it and have to go round the corner very straight up. None of this louche "leaning deeply to the left" stuff that I like to do.
I consulted PiltdownAmesbury Man about it last summer, and he kindly explained exactly what was wrong with it, drew me an understandable diagram about how years of wear causes it to have an oval shaped hole so the sidestand slips a bit and eventually the bike will start falling over.
So we have discussed how it should be possible to make an oval shaped [something something] so that the stand is more upright and firmly in place and its on the "must do very soon" list Rolling Eyes
Although he did mention he wasn't sure whether it might compromise the frame if we do that, so we have to look at it again once the weather is more clement. Which, of course, necessitates a pleasant weekend down in the countryside, yay. And possibly a few, uhhhh, bacon sandwiches Laughing
Islander
PostPosted: 01:00 - 21 Jan 2021    Post subject: Reply with quote
I can't say I've ever seen a side stand wear out in any of the bikes we've owned over the years.
PostPosted: 09:51 - 21 Jan 2021    Post subject: Reply with quote
I will say some sidestands seem a bit wobbly side-to-side until they have weight on them.
A plastic shim would seem a reasonable solution if it bothers you. A nylon washer would probably be best.
jeffyjeff
PostPosted: 07:46 - 22 Jan 2021    Post subject: Reply with quote
This has been my experience, too. Are you sure that your side stand is defective? Some lateral movement is normal.
ThunderGuts
PostPosted: 09:08 - 22 Jan 2021    Post subject: Reply with quote
Well I shared a video of the movement with some other owners of the same bike and they said they don't get that movement, so I guess not. Yeah I know a bit of movement is OK, but this was moving quite a bit, enough to increase the tilt of the bike when on the stand by about 5 degrees ish. I'm happy now though. Thumbs Up
TG.
The last post was made 5 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 118.98 Kb
