| ThunderGuts |
 ThunderGuts World Chat Champion
 Posted: 15:25 - 19 Jan 2021 Post subject: Side stand longevity? |
I'm being led to believe it's "normal" for a side stand pivot to wear out every few years and with sub 5 figure mileages (don't want to mention the marque or the dealer) - is this a load of rubbish, or reasonable? Replacement parts are well into three figures and only available OEM. Modern bike by the way, although that's probably given for this sort of issue.
Cheers.  ____________________ TG. |
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| Bloggsy |
 Bloggsy Spanner Monkey
 Posted: 17:03 - 19 Jan 2021 Post subject: |
As long as the side stand pivot get's a bit of lube, it should last for ever I have a 12 year old Yamaha MT-03 and the side stand is still going strong  ____________________ If It Aint broke Don't Fix It |
| reavsie |
 reavsie Two Stroke Sniffer
 Posted: 17:24 - 19 Jan 2021 Post subject: |
In nearly 40 years and over 350,000 miles on bikes I've never had a side stand or pivot issue. A couple of those bikes were close on 100k and pretty much all of them passed the 10k mark.
Or have I just been lucky? ____________________ Previously: GP100U, GP100U, RD200, GT380, GSX400, CX500, VT500, VT500, GS500, R80/RT, ER5, CB500, ER5, CB500, ER5, CB500X
Now: RE Himalayan |
| MarJay |
 MarJay But it's British!
| ThunderGuts |
| stinkwheel |
| ThunderGuts |
| Riejufixing |
 Riejufixing World Chat Champion
| stinkwheel |
 Posted: 18:20 - 19 Jan 2021 Post subject: |
If it's under warranty then yes, go for it. If it's not, post pics. There's probably a design fault so simply replacing it is just asking for a repeat performance. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| boundy |
 boundy Nearly there...
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Weisse Schlange |
 Weisse Schlange Spanner Monkey
| ThunderGuts |
 Posted: 20:23 - 19 Jan 2021 Post subject: |
It's a Honda. Told you it was embarrassing. It's literally a few days out of warranty but the issue was raised a little while ago.
Update anyway, took it apart and cleaned it up (lube is definitely not an issue as excess chain lube dribbles over it). So few things; the bolt isn't a perfect fit into the bracket on the frame, but to compound matters neither are the lugs on the side stand arm itself a good fit to the bracket. The hole in the bracket wasn't visibly ovalled and nor was there any other apparent wear signs. Maybe it's supposed to have play in it but other owners suggest not, or at least not much. Managed to work out an "engineering" solution (quotes because it's a tad Heath Robinson); fabricated a washer out of a PET bottle and popped this on one side of the bracket. Slathered it in grease and put back together. The stand is a tiny tiny bit stiff (but will doubtless loosen up in use) but all play has gone and the stand is solid. PET is usually pretty resistant to compression, so hopefully it'll have some life, but even if it fails it'll be sacrificial and cheap/easy to replace.
Time will tell, but looking at the bracket etc. I'm not convinced a replacement will be much different as it didn't look worn/mis-shapen.
Cheers for the input everyone.  ____________________ TG. |
| NJD |
 NJD World Chat Champion
| steve the grease |
 steve the grease Crazy Courier
 Posted: 22:58 - 19 Jan 2021 Post subject: |
| ThunderGuts wrote: | It's a Honda. Told you it was embarrassing.  It's literally a few days out of warranty but the issue was raised a little while ago.
Sounds like a good repair to me. Tolerance issue , a bit to much clearance on the fork, bolt , the hole , the lug on the frame. Most stands are a bit loose after a few years , but not so much that it affects the performance - pet washer sounds like a bit of a brainwave. . ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| SirFallalot |
 SirFallalot Trackday Trickster
| hellkat |
 hellkat Super Spammer
 Posted: 00:32 - 21 Jan 2021 Post subject: |
| ThunderGuts wrote: | It's a Honda. |
At least its not a Harley, right?
Mine is proper dodge.
And that's only done about 25K, but its 30 years old.
People have stopped at traffic lights and told me its dragging on the ground (its not but its quite loose) although if I go round too low on a left turn, I can sometimes hear it actually drag, eeeek.
So if I turn left now, I am more conscious of it and have to go round the corner very straight up. None of this louche "leaning deeply to the left" stuff that I like to do.
I consulted PiltdownAmesbury Man about it last summer, and he kindly explained exactly what was wrong with it, drew me an understandable diagram about how years of wear causes it to have an oval shaped hole so the sidestand slips a bit and eventually the bike will start falling over.
So we have discussed how it should be possible to make an oval shaped [something something] so that the stand is more upright and firmly in place and its on the "must do very soon" list
Although he did mention he wasn't sure whether it might compromise the frame if we do that, so we have to look at it again once the weather is more clement. Which, of course, necessitates a pleasant weekend down in the countryside, yay. And possibly a few, uhhhh, bacon sandwiches  ____________________ Not nearly as interesting in real life. |
| Islander |
 Islander World Chat Champion
| stinkwheel |
 Posted: 09:51 - 21 Jan 2021 Post subject: |
I will say some sidestands seem a bit wobbly side-to-side until they have weight on them.
A plastic shim would seem a reasonable solution if it bothers you. A nylon washer would probably be best. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| ThunderGuts |
The last post was made 5 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
