Sanding Machine
Cookiemonster...
PostPosted: 13:28 - 24 Jan 2021    Post subject: Sanding Machine Reply with quote
Hi, I have four pieces of securing plastic strips which have holes for a nut and bolt to go through to secure a top box onto a motorcycle frame.
My problem is they are all too thick by 2-3mm and I need to sand them all down evenly and exactly together so need a sanding machine
It's such a small 2 minute job for such small items that I don't want to hire heavy machinery to come to my place. Definitely not gonna buy one for a one off- is there somewhere/someone/ a business type with a sanding machine that I can pay to get this job completed for me please?
I'm in West London
steve the grease
PostPosted: 13:38 - 24 Jan 2021    Post subject: Reply with quote
Can't you buy a cheap 4.5" angle grinder for twenty quid on ebay and do it yourself.
Or stick your head in an ' under the arches' type garage ( not a main dealer obviously) and ask , it wouldn't take them 5 minutes...
Nobby the Bastard
Harley Gaydar
PostPosted: 13:41 - 24 Jan 2021    Post subject: Reply with quote
Hand held belt sander, £20.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 13:56 - 24 Jan 2021    Post subject: Re: Sanding Machine Reply with quote
Please add photographs of your strips.
Hong Kong Phooey
PostPosted: 14:57 - 24 Jan 2021    Post subject: Reply with quote
Too big to rasp or hand file away? Plastic is easy to wear down with plain old hand tools.
oilyrag
PostPosted: 15:49 - 24 Jan 2021    Post subject: Reply with quote
You could put a piece of rough sand paper on a flat surface and rub the plastic over it in a figure of 8 pattern.
Cookiemonster...
PostPosted: 16:07 - 24 Jan 2021    Post subject: Reply with quote
Thanks everyone, positive rating given. Ill try a cheap second hand, light one or an angle grinder. I just thought the industrial one would make it perfect or more even so the box would be perfectly aligned since im not the most mechanically inclined person.
What grade sandpaper please?
Riejufixing
PostPosted: 17:14 - 24 Jan 2021    Post subject: Reply with quote
I give up. BCF is being trolled, again. I can't think of any other nice explanation.
A100man
PostPosted: 17:49 - 24 Jan 2021    Post subject: Reply with quote
I tend to agree - there must be a simpler solution to this fixing problem.
WD Forte
PostPosted: 17:52 - 24 Jan 2021    Post subject: Reply with quote
hows about a
https://external-content.duckduckgo.com/iu/?u=http%3A%2F%2Flrd.kangan.edu.au%2Felectrotech%2Ftoolbox1204%2Fresources%2F03workshop%2F05hand_tools%2Fimages%2Fflat_file.jpg&f=1&nofb=1
bikers smell of wee
Riejufixing
PostPosted: 18:56 - 24 Jan 2021    Post subject: Reply with quote
That is a flat file, rough or middle by the look, double cut. It might or might not be a good quality file. I tend to doubt it is. Would it do the job? The OP has only said he's got "plastic strips which have holes for a nut and bolt to go through" and says "they are all too thick by 2-3mm and I need to sand them all down evenly and exactly together". There is no indication of what the "plastic" is, but it might be quite resistent to sanding or filing. Perhaps they coulld be planed. There isn't even a picture. Might be best off to attack the strips with an old decorator's paraffin blowtorch, then get some large person to sit on them. Who knows. I don't.
WD Forte
PostPosted: 20:24 - 24 Jan 2021    Post subject: Reply with quote
How about this bastard then
https://sep.yimg.com/ay/yhst-69084522897638/nicholson-12-flat-bastard-cut-metal-file-03764ct-3.gif
bikers smell of wee
Riejufixing
PostPosted: 21:47 - 24 Jan 2021    Post subject: Reply with quote
WD Forte wrote:
I don't know. It shows promise (edit: of quality), because it may be that there's a makers' name on it, and the tang seems to have been softened. It looks like a single cut file, but it's hard to say what it is from the image. Are you sure it's a bastard? Anyway, I bet it's well 'ard.
Perhaps the OP could use a planer & thicknesser?
A100man
PostPosted: 12:19 - 25 Jan 2021    Post subject: Reply with quote
'I have four pieces of securing plastic strips'
I was thinking just buy or forage materials and make thinner strips. Rolling Eyes
bugeye_bob
PostPosted: 13:56 - 26 Jan 2021    Post subject: Reply with quote
Sand paper stuck down to a flat surface, costs a quid ish if you have no sandpaper/glasspaper.
Hong Kong Phooey
PostPosted: 17:20 - 26 Jan 2021    Post subject: Reply with quote
Eh? Thinking
MCN
PostPosted: 18:04 - 27 Jan 2021    Post subject: Reply with quote
Tangs are soft.
The last post was made 5 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 93.65 Kb
