1998 Suzuki Katana Scooter AY50W starting help
wineprovider
PostPosted: 11:35 - 27 Jan 2021    Post subject: 1998 Suzuki Katana Scooter AY50W starting help Reply with quote
I`m trying to restore a barn find and have removed the panels drained and renewed the old fuel and 2 stroke running oil.
Put a brand new spark plug in which produces a good spark.
Charged the battery but when it turns over it doesn`t sound as if its gonna start at all.
I now want to check if fuel is getting to the carb but can`t find from reading everything how to do that.
At 74 I thought I had all the patience needed but I now have my doubts.
PLEASE HELP IF YOU CAN
STAY SAFE
wineprovider
A DAY WITHOUT WINE IS A DAY WITHOUT SUNSHINE
Easy-X
PostPosted: 13:12 - 27 Jan 2021    Post subject: Reply with quote
For a bike that's not starting and been left a while first thing to do would be clean the carb out.
wineprovider
PostPosted: 13:24 - 27 Jan 2021    Post subject: Reply with quote
Thank you for replying so promptly.
I shall try to strip the carb and fuel lines and get back when its done and tested.
Stay safe
oilyrag
PostPosted: 18:40 - 27 Jan 2021    Post subject: Reply with quote
You could take the spark plug out and put your finger over the hole and crank the engine. Feel for compression. If you have compression, dribble a bit of fuel into the cylinder, put the spark plug back in and turn it over and see if it fires.
jeffyjeff
PostPosted: 20:28 - 27 Jan 2021    Post subject: Reply with quote
Make sure the carburetor is getting fuel. I think your AY50 has a vacuum controlled fuel cock. Years in the barn could have caused it to freeze in the closed position. When you remove the carburetor, check for fuel in the line. If none, crank the engine over with the fuel line removed from the carburetor; fuel should dribble out of the line. If not, the fuel cock is suspect.
wineprovider
PostPosted: 04:34 - 28 Jan 2021    Post subject: 1998 Suzuki Katana Scooter AY50W starting help Reply with quote
Thank you for your help. I shall clean removed carb today and get back with the result..
Stay safe
WD Forte
PostPosted: 07:11 - 29 Jan 2021    Post subject: Reply with quote
you could just like, burn it y'know?
set fire to it and get a proper bike and all that
bikers smell of wee
wineprovider
PostPosted: 07:33 - 29 Jan 2021    Post subject: Reply with quote
Great help from most members.
However I will just ask for constructive help. Morons can keep their advice like a recent post to themselves.
Stay safe.....even to morons
jeffyjeff
PostPosted: 07:44 - 29 Jan 2021    Post subject: Reply with quote
Dude! Chill. Have a glass of wine. Don't flame WD, you might need his help one day.
A100man
PostPosted: 12:02 - 29 Jan 2021    Post subject: Reply with quote
Quite - this isn't like other forums. You have to earn your spurs. Using normal font and omit the 'stay safe' bit will help. Respect for tearing down a bike at 74 even if it is a 'ped.
Easy-X
PostPosted: 12:21 - 29 Jan 2021    Post subject: Reply with quote
Must be lockdown fever, I smell sock Sad
jeffyjeff
PostPosted: 06:38 - 30 Jan 2021    Post subject: Reply with quote
Stay safe
An alternate fuel source might facilitate testing, bypassing the tank and fuel cock altogether. You can attach a barbed fitting to a can or bottle. Use RTV silicone or the like, and attach a fuel hose from your makeshift container to the carburetor inlet. Add fuel. If the engine starts on the alternate source, problem in tank or fuel cock. If engine does not start, problem likely in the carburetor or ignition system (assuming good compression).
WD Forte
PostPosted: 08:14 - 01 Feb 2021    Post subject: Reply with quote
morons are people too y'know
I aint no animal, i got feelins an stuff just like what normal people got
https://external-content.duckduckgo.com/iu/?u=http%3A%2F%2Fmedia2.giphy.com%2Fmedia%2FBcF7P2fOYyKJO%2F200.gif&f=1&nofb=1
bikers smell of wee
The last post was made 5 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 77.39 Kb
