| Kister |
 Kister Derestricted Danger
| Nobby the Bastard |
 Posted: 00:50 - 02 Feb 2021 Post subject: |
So did the battery charge up enough on your way home to use the electric start?
Do you have a voltmeter you can use to check the charging voltage at the battery?
If the battery is too flat to run the electric start, it doesn't have enough charge in it to properly power up the fuel injection system. This was the rationale for the early models not having a kick start until they realised a) The electric start sprag clutches commonly shit themselves and b) People like the option to kick-start an enfield bullet.
Worth checking, or simply replacing, the sparkplug. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| davebike |
 davebike World Chat Champion
 Posted: 08:15 - 02 Feb 2021 Post subject: |
Usual issue
Get a multimeter and see where there is power and where no power !
I have seen a bullet have intermitent power to the coil SHIT enfield wireing had partly come appart White wire red trace I recall being the issue three way joint twisetd and taped no solder or crimp ! appeared oridgional ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| wr6133 |
 wr6133 World Chat Champion
| Kister |
| wr6133 |
| bikenut |
 bikenut World Chat Champion
 Posted: 10:14 - 02 Feb 2021 Post subject: Enfield |
All of the above...
Get an exact wiring diagram for your bike.
Make a copy, a working copy for your "shed".
You could copy the diagram, and using your computer, remove all unrelated wiring for say the ignition system, and print it off.
Do the same for the charging system, and print it off.
Ditto for the edit system etc and build a library of diagrams for your bike so you end up with a full wiring diagram and specific diagrams for the specific systems diagrams for your bike.
This may make things easier for you, and eventually you will have the info in the best mobile computer you will ever get, the one inside your head.
Get a multimeter and check charging rate, at least voltage across battery when engine running, under load, and at idle and revs, say 4k revs.
Usual voltage regulation about 14.7 volts max.
A real low tech charge rate check, bike front by wall, engine idleing and headlights on, increase revs and see lights "grow" in brightness, yes then good, no, then problem.
Remember this is a low tech check only.
With the edit, has tank hot water, rust, muck in it? And is the breather ok ?
With fuel systems, start cleaning process at the filler cap.
A good ignition test tool are those red neon plug caps that flash when they pass HT, but you may have to make an adapter to fit them for testing.
They can give an indication as to HT strength and can be seen flashing at night under load.
Get these basic tools/aides to help you.they do not cost a little t and will pay for themselves the first time used, an investment.
How do you find your bike ? Good or just ok ? ____________________ nuts about bikes |
| Kister |
| bikenut |
| Kister |
| bikenut |
 Posted: 17:21 - 02 Feb 2021 Post subject: Enfield |
Can you post the wiring diagram for a look-see please.
You read the instruction for the dmm, don't forget to select voltage range, say 20 volts DC !
Don't forget DC not ac.
Dmm set to DC 20volt, place red lead to battery positive, black lead to battery negative, every think off.
Note voltage across battery. 12.5 volts ish ?
Turn ignition on, leads same, note voltage 12volts ish now?
You may need an assistant now, unless you have 4 hands....
Leads same, kill ignition ( handle bar kill switch need diagram to know ) , press electric starter, abd hold for say 4 seconds, no more, dmm will hunt for reading now but t when stable, note reading. Reading not below 10 volts ? Good.
Next, leads the same, start engine and allow to idle. Note reading after say 5 seconds,. Volts now
Over 13volts ish, good.
Increase revs to say 3 to 4 k revs, volts across battery now more than 13, say 14.5 ish ?
With more revs voltage should not go over 14.7 ish, regulated voltage.
Now with leads the same, load system by turning headlights on, at idle, voltage across battery is more than 12 volt ? Good.
Next increase revs, voltage across battery increased and lights grow brighter, voltage does not go over 14.7 volts ? Good.
This is a basic test and voltages are ball park, but regulated voltage should not go over 14.7 volts, usually. Check in your well read manual for recommended values.
This test does not take into account amps !
That's a different bag of sweets for a different day, it's more involved and needs great care when being tested.
Wiring diagram please, feedback on voltages achieved with clear test conditions, like engine running at 4k revs with lights off etc..
Are any bulbs going black, look at headlamp side lamp, the dim one, and headlamp bulb.
It may be an idea to take the back lens off and check the stop and tail bulb for being black, or blackish.
Wiring diagram please. ____________________ nuts about bikes
| Kister |
| Weisse Schlange |
 Weisse Schlange Spanner Monkey
| bikenut |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| stevo123 |
 stevo123 Nitrous Nuisance
 Posted: 22:19 - 02 Feb 2021 Post subject: |
| Easy-X |
 Easy-X Super Spammer
| bikenut |
| Kister |
| Kister |
| wr6133 |
| Robby |
 Robby Dirty Old Man
| bikenut |
 Posted: 15:50 - 05 Feb 2021 Post subject: Cdi |
I have had a similar problem with a bike with a non battery dependant CDI ignition system.
After about 18 miles it spluttered and died. I pushed it from the roundabout to a safe space. I checked the fuel, even fuel flow from the tank to the carbs, good flow and tank 3/4 full.
By that time the engine had cooled and started straight away, so headed for home.
Two miles down the road, she did it again.
The battery was fine.
Allowed to cool and off we go again getting closer to home.
I eventually made it home.
Next day, get the red neons out and check.
Started engine, flashes a bit weakish but she started straight away, with neons growing brighter with revs.
Left it at idle to warm up properly. All good so far, so neons in my pocket, ride around the village and yes, she died again.
Fitted neons, no flash, no spark, no HT.
Turns out the ignition system generator died when hot.
Red neons really handy bits of kit and prevent hair loss 😁
A similar, battery seemed to be dieing, difficult to start with reduced cranking speed.
Removed battery and charged, refitted and started well again. Did basic volts output, voltage across battery at cranking, idleing at at ,4 k revs.
Low Genny output, found badly corroded alternator wire to reg/rec, a loss of one phase from the alternator.
Fixed that and fine eversince.
That bikes ignition system was a battery dependant CDI system. Slow cranking speed due to phase loss, CDI system starved so didn't work well enough, if at all, hence poor/non starting. ____________________ nuts about bikes |
| Kister |
The last post was made 5 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
