Sinnis apache 125cc not starting
justpoc
PostPosted: 23:24 - 02 Feb 2021    Post subject: Sinnis apache 125cc not starting Reply with quote
Hi all, decided to turn for help to forum, probably missing something obvious and hopeing i can be pushed towards right direction.
Sooo, tried to help out a fellow rider with jump starting the bike with no luck. Only to notice a day later that my bike is not starting.
Tried jump starting from a car with no luck. Bump start seemed to work only once (did not think of it much and was happy it started once). Decided to change battery as it was already quite old and thought I probably killed it. Bike started seemed to run nicely, after a mile or so and few misfires at the end it just died on the road. Managed to start a few more times, each time just for a few meters of ride until it completely switched off.
As I was about to start looking for issues, decided to fix few small issues and do a part of service as it was about time anyway.
New spark plug, generates healthy spark.
New carburettor (changed it as old one had an issue affecting throttle and was just in a queue for a repair anyway). Checked the fuel and it comes clear, even drained and replaced with a new as bike stood for few weeks without moving. Carburettor should be operating as it is supposed to I guess.
New starter motor (accidentally damaged it when disconnected to clean it. Located in front of engine and was covered in thick dirt.. please do not ask why did I bother at all... )
Checked compression and according to manual all fine.[/list]
That leaves timing, I guess. As it happened after jump starting, my best guess is of course electrical part... The only part I can think off is CDI unit malfunctioning. Now don't want to start changing components when no idea what is wrong nor digging deeper into potential mechanical faults as it just does not make sense.
The question I have is whether it is somehow possible to check if CDI unit is performing as it is supposed to or potentially I should be investigating something else too?
Sorry for the very long text but wanted to paint the situation how I experienced and understand it. Silly thing to play with jump starting when not fully aware of correct procedures... A lesson to learn.
Easy-X
PostPosted: 00:55 - 03 Feb 2021    Post subject: Reply with quote
You say the battery is old. Why not start there and replace it?
justpoc
PostPosted: 18:35 - 03 Feb 2021    Post subject: Reply with quote
I did. After I replaced, bike started for a 1 mile journey. This was the 1st thing I replaced and it does not seem to work even when recharged. New battery works fine
Easy-X
PostPosted: 19:16 - 03 Feb 2021    Post subject: Reply with quote
Whoops! Sorry, I read that as charged the battery for some reason Doh! Alcohol induced dyslexia Wink
Anyhoo, it might be worth checking the battery voltage with a multimeter: before starting, while idling and if/when it dies. The battery and charging/regulation system is the base for the rest of the electrics. If it's anything like other Chinese 125s then the magneto charges the battery and the battery in turn powers the ignition system.
Also worth having a look at the side stand switch and kill switch just to discount them from the equation. After that: loose connections / bad earths, CDI unit and the ignition coil.
tl;dr get a multimeter + wiring diagram, e.g. something like:
https://dealers.lexmoto.com/downloads/125_motorcycle_ac_wiring_diagram.pdf
bikenut
PostPosted: 21:02 - 03 Feb 2021    Post subject: Sinnis Reply with quote
As above, also research red neon plug caps that flash as they pass thru HT, the spark.
Cheap effective hassle free but you may have to make an adaptor so it fits hassle free between plug in engine and existing plug cap.
When it dies does it stop flashing ?
If/when it misfires does it stop flashing in time with the misfire.
With a good clean correctly gapped plug and neon fitted and engine idling, does the flashing go brighter with revs ?
It's a bit of cheap test kit, not a real cool flashing but of bling for your bike.
You should be able to see the flashes if you are riding bike, particularly at night.
An other low tech test, with front of bike by a wall, engine idling and headlights on, do the headlight grow brighter if you rev engine to say 4 to 5 k revs ? Yes ? Good. No, bad. !
What year your Sinnis ? Post wiring diagram so we can see...
Is it edit or carb version, and goto sinnismotorcycles.co.uk or what ever it is, for the parts diagrams, exact model,vso we know what's on it...etc.
nuts about bikes
justpoc
PostPosted: 22:37 - 04 Feb 2021    Post subject: Reply with quote
It is 2015 Sinnis Apache 125 Non EFI (QM125GY-2B).
Problem is that it does not start now so cannot make any tests on running engine.
I will try to get on testing the electrical parts this weekend. Wiring diagram attached (uploading from mobile, if quality is bad I'll update on PC when have a chance), from repair manual.
WD Forte
PostPosted: 23:06 - 04 Feb 2021    Post subject: Reply with quote
that diagram suggests the side stand switch dumps the pulse signals to ground to stop the motor
( as does the stop and ignition switch, test those too)
try disconnecting it as they been known to play up
https://www.bikechatforums.com/download.php?id=104375
bikers smell of wee
bikenut
PostPosted: 11:43 - 05 Feb 2021    Post subject: Diagram Reply with quote
The power of a few lines in a bit of paper eh !
Now you have your "road map" for the exact wiring on your bike, you can use your dmm to good effect confident that you now have info to act on.
You have a dmm and red neon plug cap now, to relatively cheap, effective and sensible bits of kit that will pay for them selves the first time you use them.
These bits of kit will come in handy for years to come, so look after them.
Study your diagram and learn certain circuits, the first being the ignition and starter motor circuits.
Take you time, be methodical, one thing at a time and don't flit here and there. Record what you have checked and results.
Remember the battery should be fully charged and is your reference and starting point.
Don't forget the earth circuit.
Enjoy, give feedback.
Others can also learn from your experience.
nuts about bikes
bikenut
PostPosted: 12:13 - 05 Feb 2021    Post subject: Note Reply with quote
Note
I saw a box in the wiring diagram marked ECU.
Like you, an ECU will not like a spike up its bum !
So avouid electrical spikes which can be caused by hot-wiring, using jump leads.
This you have already done.
Always make sure the main ignition switch is OFF when disconnecting your battery and OFF when connecting your battery.
The wires in the diagram are connected with a Dot, just like a roundabout, and wires which cross but not connected have a hump back bridge, or leap over the unconnected wire. 😎
Hands up those of you that did not realise that.
nuts about bikes
wr6133
PostPosted: 13:14 - 05 Feb 2021    Post subject: Re: Sinnis Reply with quote
I don't get what's so good about these. If the coil is proper fucked you can see the resistance values out of spec. If it only breaks down when warmed up and under load (which accounts for most of the coil fails I can recall having), what are you meant to do, try and eyeball the thing while the bike is misfiring and in motion? Even on my bikes with exposed motors that would involve having my head in a location that would probably qualify as dangerous driving and on a faired bike it would require my decapitated head to be squashed flat and placed under the airbox.
Also thinking about it more, if that cap lights up everytime the plug fires then even on a single cylinder bike potentially we are talking thousands of sparks per minute, hundreds per second. At something like 4k RPM I doubt you could even notice it missing 100 sparks in row It seems to me it's use is only really to show a dead HT lead or a dead coil and is more hassle to do so than a meter.
If I'm being thick here please correct me.
bikenut
PostPosted: 13:49 - 05 Feb 2021    Post subject: Neons Reply with quote
They are not the be all and end all, and could be a problem in a deeply recessed plug, and on a bike with a fairing, but they work for me.
An adapter would have to be made for a deeply recessed plug, L shaped possibly, and an adapter made so it fits inline and easily using the bikes original plug cap, but that's down to the application ( cx500, kwak gpz750, the one that the engine will run with the cam cover off ).
They work for me and have done for years and years.
Wasted spark ?
When the misfire happens and no flash, then no HT.
Yes, is it fuel, is it a coil breaking down under load, going up hill ?
A visual indication would help, unless you have lots of hair.
You could always stick your finger in the plug cap, bit difficult when riding I think.
Do you check your mirror and is your fairing welded on ?
You will not know of there usefullness untill you try them, they dont Cost a fortune.
Dim flash at cranking, brighter flash with revs...dim flash when at idle, intermittent flash when intermitant misfire starts at 4 to 5 k revs, is it fuel ?
Of course there may be a fuel problem as well....
But you need one really long lead for a scope, unless you have one of those battery powered ones, or one in a laptop....there's always your finger up the plug cap 🤩🤩
nuts about bikes
bikenut
PostPosted: 14:16 - 05 Feb 2021    Post subject: Neons Reply with quote
Alternatively a neon timing light light with leads could be utilised..... 😁
Or even the 12v power timing lights, tape the trigger, clip on sensor lead, but the light is quite bright so don't have it shining in your eyes whilst riding your bike, particularly at night.
Of course the plug may need a shave, those dam cats again.
nuts about bikes
The last post was made 5 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 7.97 - MySQL Queries: 13 - Page Size: 78.27 Kb
