Honda PCX 125 Engine light on and Speedo not moving
LeeW
PostPosted: 15:24 - 02 Feb 2021    Post subject: Honda PCX 125 Engine light on and Speedo not moving Reply with quote
Hi all,
Got the engine light on and the speedo is not working but the bike rides ok, any ideas what's going on?
It is a 2016 model without digital dash.
Copycat73
PostPosted: 18:25 - 02 Feb 2021    Post subject: Reply with quote
fitted wit ABS. ?
caveat emptor
LeeW
PostPosted: 18:42 - 02 Feb 2021    Post subject: Reply with quote
Copycat73 wrote:
fitted wit ABS. ?
Nope, no abs.
Copycat73
PostPosted: 11:05 - 03 Feb 2021    Post subject: Reply with quote
try the speed sensor.
caveat emptor
LeeW
PostPosted: 07:15 - 04 Feb 2021    Post subject: Reply with quote
I noticed it was a little wet, is that likely to be the issue? I cleaned it but still same.
Copycat73
PostPosted: 10:44 - 04 Feb 2021    Post subject: Reply with quote
possibly .. but given you dried it maybe not .. afraid its a multi meter job to check the resistance readings .. or maybe the magnet or ring has dropped off .. you`ll need a service manual for the reading values and exactly how to do it .. failing that .. take to dealer... you could take a punt and just buy a new unit to replace the sender .. maybe work .. maybe not..
caveat emptor
oilrag
PostPosted: 13:36 - 07 Feb 2021    Post subject: Reply with quote
When you turn the key on does the speedo needle move from 0 to max then back to 0?
It has three wires going to the speed sensor so it looks like it has a hall effect sensor. In that case you should have 12V between Black/White and Green/Black. If not you probably have a broken black/white or green/black wire.
If you have 12V between Black/White and Green/Black check between Pink/Green and Green/Black. You should see the meter switching as you turn the wheel slowly. The voltages could switch between 12V and 0V or 12V to 1V, or 5V to 1V etc but whatever the voltages are they should switch from one to the other as you turn the wheel slowly.
If you have all that at the sensor you would have to check on the Pink/Green at the back of the instrument panel you should see the voltage switching as you slowly turn the wheel.
LeeW
PostPosted: 23:51 - 07 Feb 2021    Post subject: Reply with quote
Yeah the needle 'sweeps' up then back again.
I'll be taking a look tomorrow with my multimeter in hand, just got to take a few panels off and hope for the best! hoping i don't have to go near the instrument panel as ive heard it's a pita to gain access to.
Will update as and when.
Thanks all for the help so far.
The last post was made 5 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 55.96 Kb
