Laptop and monitor compatibility
ThunderGuts
PostPosted: 10:58 - 11 Feb 2021    Post subject: Laptop and monitor compatibility Reply with quote
Morning y'all,
Does anyone know if there are any inherent compatibility issues with a relatively high res laptop screen (in this case, a 14.5" screen with a resolution of 2560 x 1600) connected to a relatively low res external monitor as a second screen (24" 1920 x 1080)? I seem to keep hitting an issue where the second screen image is distorted quite badly (fuzzy), not the monitor as turning it off and on doesn't resolve it, but if I disable the second screen output from the laptop and re-enable it the image is OK.
Cheers Thumbs Up
TG.
PostPosted: 11:07 - 11 Feb 2021    Post subject: Reply with quote
It shouldn't matter, as long as your laptop detects the monitor properly. It should realise that your main display is a higher resolution than your secondary display.
ThunderGuts
PostPosted: 11:37 - 11 Feb 2021    Post subject: Reply with quote
Cheers Thumbs Up
TG.
PostPosted: 11:43 - 11 Feb 2021    Post subject: Reply with quote
ThunderGuts wrote:
Cheers Thumbs Up
Connect the monitor, and then try updating the monitor driver. It might find a better/more appropriate one for the monitor.
ThunderGuts
PostPosted: 12:25 - 11 Feb 2021    Post subject: Reply with quote
Good idea, just done that. Will have to see. It's an erratic issue which is always all the harder to address as it can appear ok for days, then suddenly wobble.
TG.
xX-Alex-Xx
PostPosted: 21:14 - 11 Feb 2021    Post subject: Reply with quote
Try a different cable. If it’s HDMI, it doesn’t need to be an expensive cable, but make sure it’s at least minimum spec for the port.
DILLIGAF
t121anf
PostPosted: 22:53 - 11 Feb 2021    Post subject: Reply with quote
Are you mirroring the screen or extending it or only using one of the 2 displays connected?
PostPosted: 18:24 - 12 Feb 2021    Post subject: Reply with quote
It matters on some laptops. My workshop one (Elitebook) requires a monitor of it's native resolution in order to not distort the screen. It's a known driver issue that they never addressed.
Henny This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 5 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 61.21 Kb
