| Dom_ |
 Dom_ Points Mean Prizes
| Kickstart |
 Kickstart The Oracle
| ash t |
 ash t World Chat Champion
| Dom_ |
| Kickstart |
 Posted: 22:02 - 03 Apr 2005 Post subject: |
Those bearings should be easy to source. Most bike shops probably have them in stock.
I would take the old bearings out and double check the sizes. You also want to ensure that there is only 2 bearings in there (some Yamahas have 2 bearings on the chain side and one on the brake side, plus another in the sprocker carrier).
Once you have made sure the codes are right then just pick some new ones up. Get the bearings with 2RS at the end of the code (2 rubber seals).
| Dr Nick |
 Dr Nick World Chat Champion
| Dom_ |
| R4nger |
 R4nger World Chat Champion
| Dr Nick |
| Dr Nick |
 Posted: 13:23 - 04 Apr 2005 Post subject: |
Oh yer, do them both at the same time, i found that out the hardway . ____________________ is that it |
| Kickstart |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Dom_ |
 Posted: 19:40 - 04 Apr 2005 Post subject: |
Oh dear It's worse than i thought, the bearings ate the thing that goes in my wheel (not the spindle) and ate the innards of my wheel.
Any advise as to what to do ??
Thanks. |
| BFG |
 BFG Brolly Dolly
| Kickstart |
 Posted: 20:13 - 04 Apr 2005 Post subject: |
If I am looking at those pictures correctly it has wrecked the spacer that goes between the bearings (probably not too bad on its own) but also looks like it has chewed up the inside of the wheel. That spacer is fairly tough metal normally, and the ball bearings are likely to do far more damage to the soft alloy of the wheel.
It the bearing outer had not spun then the wheel might be OK, but you cannot see the damage on the inside of the wheel which worries me a bit.
I would be inclined to try and find a good 2nd hand wheel. Rear wheels should be easy to find and cheaper.
| Dom_ |
| Kickstart |
| Dom_ |
| Kickstart |
| Dom_ |
| BFG |
 BFG Brolly Dolly
 Posted: 21:34 - 04 Apr 2005 Post subject: |
Agree with Kickstart.
It's a 50?? The wheels tend to be over-engineered. Look at the photos. The hub part is connected to the rest of the wheel by thin ribs. The thickness of the hub is not always done for performance strength - it is often done to prevent distortion during machining in the factory. Point being - there might be more than enough strength left even with the wear. If the thickness of the remaining material is at least twice the thickness of the ribs - this would make the decision for me if it were my bike.
But we all agree - this is the risk. It's impossible to say via photos on the net.
Don't forget the risks with second hand wheels are also quite significant. Given what can happen to alloy with impact / heat damage - invisible hairline cracks etc. Will you replace one visible risk with another invisible one? But - as said they are over-engineered though.
I would strongly recommend - Have an engineer look your existing wheel. Also - the bearing seats must be perfect!! |
| Dom_ |
| Dom_ |
| Kickstart |
| BFG |
 BFG Brolly Dolly
The last post was made 21 years, 177 days ago. Instead of replying here, would creating a new thread be more useful? |
