| Ghost25 |
 Ghost25 L Plate Warrior
 Posted: 23:36 - 13 Feb 2021 Post subject: Compression release rubbing cylinder head cover and gasket |
I have a 2004 KLR650 that I bought about a year ago. I haven't ridden it much and I haven't done too much work on it besides some fluid changes and basic maintenance.
I finally got around to replacing the cylinder head gasket because it was leaking oil. I was adding quite a bit of oil and figured since I knew it was leaking there that would be the first thing to address.
When I pulled off the cover I saw the inside portion above the compression release was badly scored, the gasket groove was broken, and the gasket was chewed up. What do I do? Do I need to replace the compression release spring? Someone I talked to thought there might be a problem with the chain tensioner. My Clymer manual doesn't really go into servicing the compression release except to identify it.
Apparently some people call it the KACR (Kawasaki Automatic Compression Release) and some people remove it, but doing so may cause some issues with kickback when starting.
I obviously need a new cover.
https://i.imgur.com/QHFp9xo.jpg?1
https://i.imgur.com/zaBAiyj.jpg
https://i.imgur.com/hF8dXDI.jpg
https://i.imgur.com/0rOV81K.jpg
https://i.imgur.com/WARaM1s.jpg |
| stinkwheel |
 Posted: 00:56 - 14 Feb 2021 Post subject: |
I have no idea how it works but it looks a little like a mechanical ignition advancer like you'd get on a points bike so presumably the exhaust valve timing is slightly advanced when it's spinning slowly and when it spins faster, a little weight flys out against that small spring which causes something in the assembly to rotate and sets the timing to normal.
If that's the case, it suggests there is a stop somewhere that is damaged or defective, allowing the weight to fly out further than it should (and possibly over-retarding the valve timing in the process). On mechanical ignition advancers, there is usually an oval hole that runs on a pin. One end of the oval is the fully in position, the other end is fully out. If there is such a hole, I wonder if it's worn or if the pin is bent.
A simpler thought might be that someone has used a sub-standard or incorrect rocker cover gasket that's too thin...
Another simple thought would be a loose cam cap, but that should make a godawful racket.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
 Posted: 01:05 - 14 Feb 2021 Post subject: |
My guess was close. Found this video. it doesn't alter the cam timing, just the position of a little steel rod that pops the valve open at low rev speeds. The bob weights flying out in a grooved hole was on the money though, very like a mechanical ignition advancer.
https://youtu.be/K-i8PvkjCT4
Interestingly, on that video, the bit that's striking seems to be sticking up higher when the weights are being pulled in by the spring (ie at low revs), it should drop down when the engine is running more quickly and the weights fly out (really anything faster than the starter motor can turn it).
I wonder if the mechanism is sticking. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 02:27 - 14 Feb 2021 Post subject: |
They're a governer style decompression system.
I'd be removing it. Seems to me like the part which limits how far the inertial forces can throw the weight is worn out, allowing it to flail around in there. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| jeffyjeff |
 jeffyjeff World Chat Champion
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 10:36 - 14 Feb 2021 Post subject: |
| Easy-X |
 Easy-X Super Spammer
 Posted: 13:27 - 14 Feb 2021 Post subject: |
With regards to the cam cover this might be one of those times where "dab it with some JB Weld" will do, once you sort out / delete the compression weight issue obviously. Specifically I'd go with the "metal putty" type of epoxy. It shouldn't be a pressured area so the putty won't need to really do much.
Cleaning up & filling the top gouge should be straightforward but that gasket valley Push in or file the edges of the hole so they don't impinge the gasket rubber and drop in a little flat piece of tin foil to cover the hole and as wall reinforcement. If you can find something like a drill bit the same diameter as the width of the valley to hold it in place so much the better, then slap on the putty. Bit of patience in the clean-up / reshaping but you might never know there was any damage  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Robby |
 Robby Dirty Old Man
| jaffa90 |
| jeffyjeff |
| stinkwheel |
 Posted: 09:09 - 15 Feb 2021 Post subject: |
This is why kickstarts were a good idea. On a cold start, you could turn it over compression with the kickstart before engaging the starter motor.
Enfield came up with a novel solution to this problem when their bikes kept killing sprag clutches. They fitted a "black box" that dumps the first spark so it won't fire until the second revolution, thereby almost totally eliminating the chances of a kickback. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Tankie |
 Tankie Crazy Courier
| Easy-X |
| wr6133 |
 wr6133 World Chat Champion
| Nobby the Bastard |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| Nobby the Bastard |
| jaffa90 |
| stinkwheel |
 Posted: 18:50 - 15 Feb 2021 Post subject: |
My 612 enfield can and will hurt you if you prod half hartedly at the kickstart and don't hold it at the bottom of the swing with each kick untl it had decided to start or not to start.
Two bikes legendary for kicking back violently and frequently were the slope-engine Panther 650 and the Yamaha XT500. Panthers are reputed to have broken peoples legs if they forgot to retard the ignition for a cold start. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
| Nobby the Bastard |
| jeffyjeff |
| Nobby the Bastard |
The last post was made 5 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
