Compression release rubbing cylinder head cover and gasket
Ghost25
PostPosted: 00:36 - 14 Feb 2021    Post subject: Compression release rubbing cylinder head cover and gasket Reply with quote
I have a 2004 KLR650 that I bought about a year ago. I haven't ridden it much and I haven't done too much work on it besides some fluid changes and basic maintenance.
I finally got around to replacing the cylinder head gasket because it was leaking oil. I was adding quite a bit of oil and figured since I knew it was leaking there that would be the first thing to address.
When I pulled off the cover I saw the inside portion above the compression release was badly scored, the gasket groove was broken, and the gasket was chewed up. What do I do? Do I need to replace the compression release spring? Someone I talked to thought there might be a problem with the chain tensioner. My Clymer manual doesn't really go into servicing the compression release except to identify it.
Apparently some people call it the KACR (Kawasaki Automatic Compression Release) and some people remove it, but doing so may cause some issues with kickback when starting.
I obviously need a new cover.
https://i.imgur.com/QHFp9xo.jpg?1
https://i.imgur.com/zaBAiyj.jpg
https://i.imgur.com/hF8dXDI.jpg
https://i.imgur.com/0rOV81K.jpg
https://i.imgur.com/WARaM1s.jpg
PostPosted: 01:56 - 14 Feb 2021    Post subject: Reply with quote
I have no idea how it works but it looks a little like a mechanical ignition advancer like you'd get on a points bike so presumably the exhaust valve timing is slightly advanced when it's spinning slowly and when it spins faster, a little weight flys out against that small spring which causes something in the assembly to rotate and sets the timing to normal.
If that's the case, it suggests there is a stop somewhere that is damaged or defective, allowing the weight to fly out further than it should (and possibly over-retarding the valve timing in the process). On mechanical ignition advancers, there is usually an oval hole that runs on a pin. One end of the oval is the fully in position, the other end is fully out. If there is such a hole, I wonder if it's worn or if the pin is bent.
A simpler thought might be that someone has used a sub-standard or incorrect rocker cover gasket that's too thin...
Another simple thought would be a loose cam cap, but that should make a godawful racket..
PostPosted: 02:05 - 14 Feb 2021    Post subject: Reply with quote
My guess was close. Found this video. it doesn't alter the cam timing, just the position of a little steel rod that pops the valve open at low rev speeds. The bob weights flying out in a grooved hole was on the money though, very like a mechanical ignition advancer.
https://youtu.be/K-i8PvkjCT4
Interestingly, on that video, the bit that's striking seems to be sticking up higher when the weights are being pulled in by the spring (ie at low revs), it should drop down when the engine is running more quickly and the weights fly out (really anything faster than the starter motor can turn it).
I wonder if the mechanism is sticking.
MaybeGuy
PostPosted: 03:27 - 14 Feb 2021    Post subject: Reply with quote
They're a governer style decompression system.
I'd be removing it. Seems to me like the part which limits how far the inertial forces can throw the weight is worn out, allowing it to flail around in there.
jeffyjeff
PostPosted: 07:25 - 14 Feb 2021    Post subject: Reply with quote
+1 on that idea. If your mechanism is similar to that in the video, I would start by looking at the pins that locate the flyweights, and the flyweight bores that pivot 'round the pins. Remove the spring to get a good feel for the amount of wear.
jaffa90
PostPosted: 11:36 - 14 Feb 2021    Post subject: Reply with quote
https://www.klrforum.com/threads/acr-failed-and-broke-the-valve-cover.46369/
https://www.youtube.com/watch?v=K-i8PvkjCT4
I had a KLR 650, my problem was short legs.
Easy-X
PostPosted: 14:27 - 14 Feb 2021    Post subject: Reply with quote
With regards to the cam cover this might be one of those times where "dab it with some JB Weld" will do, once you sort out / delete the compression weight issue obviously. Specifically I'd go with the "metal putty" type of epoxy. It shouldn't be a pressured area so the putty won't need to really do much.
Cleaning up & filling the top gouge should be straightforward but that gasket valley Thinking Push in or file the edges of the hole so they don't impinge the gasket rubber and drop in a little flat piece of tin foil to cover the hole and as wall reinforcement. If you can find something like a drill bit the same diameter as the width of the valley to hold it in place so much the better, then slap on the putty. Bit of patience in the clean-up / reshaping but you might never know there was any damage Wink
Robby
Dirty Old Man
PostPosted: 22:58 - 14 Feb 2021    Post subject: Reply with quote
So when the decompressor is working, it puts a bit less strain on the starter motor. When it isn't working, it chews up your rocker cover and throws slivers of metal at the camshaft.
Starter motor brushes are cheaper, and easier to change, than camshafts.
jaffa90
PostPosted: 01:49 - 15 Feb 2021    Post subject: Reply with quote
Very true but who knows if the starter motor would handle the extra pressure?
Also what would happen if the engine backfired or went backwards? Shocked
jeffyjeff
PostPosted: 06:53 - 15 Feb 2021    Post subject: Reply with quote
Judging from the exploded view, it appears the compression release only comes as a complete assembly. That should simplify the repair, if not the diagnosis. One would expect that the flyweight's arc of travel would be limited mechanically. Something is either worn beyond tolerance or broken, allowing the rotating weights to contact the valve cover.
That mechanism also appears to be among the last components to receive lubrication on cold start. Upon completion of repair, might be worthwhile to investigate oil flow to the top end. The knackered compression release could be the symptom of an underlying problem. Run the engine briefly sans valve covers. You'll probably get oil slinging off the cam chain, but you should see oil flow out from between the cam journals and cam caps. You'll make a mess, but if you start with a cold engine, you'll gain an appreciation for how long it takes the oil to migrate to the far reaches of the lube system.
PostPosted: 10:09 - 15 Feb 2021    Post subject: Reply with quote
This is why kickstarts were a good idea. On a cold start, you could turn it over compression with the kickstart before engaging the starter motor.
Enfield came up with a novel solution to this problem when their bikes kept killing sprag clutches. They fitted a "black box" that dumps the first spark so it won't fire until the second revolution, thereby almost totally eliminating the chances of a kickback.
Tankie
PostPosted: 10:54 - 15 Feb 2021    Post subject: Reply with quote
I think i would be looking for the cause, like maybe the cam bearings have failed on that end of the camshafts!
Easy-X
PostPosted: 11:58 - 15 Feb 2021    Post subject: Reply with quote
Isn't kickback more a 2-stroke thing? Does it / can it happen much on a 4-stroke?
wr6133
PostPosted: 12:16 - 15 Feb 2021    Post subject: Reply with quote
A series of half arsed kicks on my 350 (without using the decomp inbetween) can do it. Though "kick" back would be a bit of a strong word, more like "Slight Pushback". I'd imagine on an engine altered to make higher compression the kick back would be a bit more Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 12:27 - 15 Feb 2021    Post subject: Reply with quote
Its not really a thing for 2 strokes.
Triumph Sprint ST 1050
redeem ouzzer
PostPosted: 14:20 - 15 Feb 2021    Post subject: Reply with quote
Two strokes only tend to kick back if the timing is out, and it's a minor annoyance, not like a big four stroke single where you can get a purple shin (or worse) for your troubles.
Be a REAL MAN!
Robby
Dirty Old Man
PostPosted: 15:51 - 15 Feb 2021    Post subject: Reply with quote
You don't really understand how engines work, do you.
jeffyjeff
PostPosted: 16:14 - 15 Feb 2021    Post subject: Reply with quote
The BSA 441 Victor was legendary for its kickback. Seem to recall that Paul Newman (Steve McQueen?) broke his leg trying to start one back in the early 1970's, but an internet search could not confirm. The key to starting these high compression thumpers was to bump it up on the compression stroke before kicking it over. If you failed to do this, you would kick the engine through the intake stroke and the piston would be coming up on compression just as the kickstart lever was near the bottom of it's arc. The spark plug would fire a few degrees BTDC, forcing the piston down with the crank turning backwards. With the mechanism still engaged, the kickstart lever would launch the unsuspecting rider over the handlebars.
For some of the old timers, this short video will take you back.
https://www.youtube.com/watch?v=_qOh7P380YU
Nobby the Bastard
Harley Gaydar
PostPosted: 17:49 - 15 Feb 2021    Post subject: Reply with quote
We've tried to tell him many times that he has no idea about anything mechanical but he just won't have it.
jaffa90
PostPosted: 18:30 - 15 Feb 2021    Post subject: Reply with quote
I`ve had a few kick backs starting with a 750 Norton Commando and a Enfield 550.
PostPosted: 19:50 - 15 Feb 2021    Post subject: Reply with quote
My 612 enfield can and will hurt you if you prod half hartedly at the kickstart and don't hold it at the bottom of the swing with each kick untl it had decided to start or not to start.
Two bikes legendary for kicking back violently and frequently were the slope-engine Panther 650 and the Yamaha XT500. Panthers are reputed to have broken peoples legs if they forgot to retard the ignition for a cold start.
Easy-X
PostPosted: 20:35 - 15 Feb 2021    Post subject: Reply with quote
Oh really? Kickback on the DT175 was... disconcerting but thankfully an infrequent event. A DT400 could snap your ankle Shocked
I was thinking along the lines of the reversibility of 2-stroke, if the timing was really bad. Actually exploited as a "feature" to fake reverse gear on something like a snowmobile IIRC.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:52 - 15 Feb 2021    Post subject: Reply with quote
I've only heard of engines running backwards as something that could happen and its usually people who fucked Jordan that reckoned it happened to them.
A 500 or 650 single 2t will kick back to a extent but not compared to a Vincent.....
jeffyjeff
PostPosted: 21:23 - 15 Feb 2021    Post subject: Reply with quote
It is quite easy for a two stroke engine to run backwards. Since it is the vertical movement of the piston that causes aspiration and exhaust, direction of crank rotation is irrelevant.
A 4T engine, not possible since engine breathing and exhaust are a function of camshaft-valve action. The camshaft must be turning in the correct rotation for intake to be drawn in through the throttle body or carburetor. Turning backwards would draw air in through the muffler and exhaust it through the throttle body and out the air filter. Where's the fun in that?.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:15 - 15 Feb 2021    Post subject: Reply with quote
It seems quite simple for a 2t to run backwards up until when you take into account ignition retard and advance.
If you do manage to start it running in reverse, as soon as you try to rev it, it'll stall.because the advance will retard it and then more.gas.and speed, then more retard.
The last post was made 5 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 133.56 Kb
