Peugeot kisbee 100 snapped exhaust stud
AshBik
PostPosted: 20:05 - 23 Feb 2021    Post subject: Peugeot kisbee 100 snapped exhaust stud Reply with quote
How would i remove a snapped stud, the stud is slightly sticking out but I lack space in where the head of the engine is[img]
AE
Nobby the Bastard
Harley Gaydar
PostPosted: 20:07 - 23 Feb 2021    Post subject: Reply with quote
Find someone with a welder and weld a nut to it.
Triumph Sprint ST 1050
sickpup
Old Timer
PostPosted: 09:12 - 24 Feb 2021    Post subject: Reply with quote
Preferably mig Thumbs Up
bikenut
PostPosted: 11:54 - 24 Feb 2021    Post subject: T Reply with quote
Beware of murdering any fragile electronics !
Perhaps gas for this application but much more of fire risk !
Just don't set it on fire or murder any electronic stuff.
Post a picture of engine and broken stud for clarity
nuts about bikes
droog
PostPosted: 12:38 - 24 Feb 2021    Post subject: Reply with quote
I had exactly that situation:
Suggestions above are very good - but If you can't get the mig sorted out try this - it's not as professional as the mig but it will get the job done:
Soak the stud (where it enters the block) in penetrating oil (e.g. plus-gas etc).
Give the end of the stud some light taps with a hammer - this will help to break up rust/crud in the threads that is keeping it seized and will also help to work the penetrating oil into the threads.
Get a manual impact driver that comes with slotted bits (Halfords do one for 15 quid)
Cut a notch in the end of the stud with a metal hack saw - wide enough to take one of the slotted bits that came with your impact driver.
Fit slotted bit into impact driver and set impact driver to anti-clockwise.
Put the impact driver and it's slotted bit into the slot you cut in the end of the stud - hit the end of the impact driver with a hammer - it should start turning the stud out.
If this doesn't work heat the the stud up immediately before you use the impact driver - you can get a cheap propane/butane mix torch to do this.
The exhaust port is side-on on this machines isn't it? So you should have the space to position the impact driver and swing the hammer.
The last post was made 5 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.15 - MySQL Queries: 15 - Page Size: 43.44 Kb
