Yamaha fazer runs but cuts out when clutch lever operated
Neilr
PostPosted: 15:05 - 24 Feb 2021    Post subject: Yamaha fazer runs but cuts out when clutch lever operated Reply with quote
I have a yamaha fazer fzs 600 on a 03 plate, seems to have developed an electrical fault. The bike will only start when the clutch lever is pulled in and when released it cuts out straight away.
Second when running if put in gear it instantly cuts out, i suspect both fault are related. Any help would save me a major headache.
Thanks in advance.
BRUN
PostPosted: 15:29 - 24 Feb 2021    Post subject: Reply with quote
have you tried to bypass the side stand switch to see if its related to that, sounds likely to me (im a bike noob but learning)
Neilr
PostPosted: 15:53 - 24 Feb 2021    Post subject: Reply with quote
I have had to bypass the clutch switch to start the bike, not sure if bypassing the side stand switch will make a difference but worth a go?
BRUN
PostPosted: 15:58 - 24 Feb 2021    Post subject: Reply with quote
as i said im very new to this, but as i understand it, the clutch switch, side stand switch, and neutral switch all affect a bikes ability to start and run
from what you have said about it cutting out as soon as you put it into gear, it sounds like the bike is cutting out as it thinks the side stand is out
its only 2 wires so fairly easy to do, cheap to replace too
your first point about the clutch lever, is the gear selection/neutral showing up correctly ?
"The bike will only start when the clutch lever is pulled in" this would suggest the bike thinks your in gear so wont start because of this
bikenut
PostPosted: 16:09 - 24 Feb 2021    Post subject: T Reply with quote
Get a correct wiring diagram and post on here...
nuts about bikes
Neilr
PostPosted: 16:19 - 24 Feb 2021    Post subject: Reply with quote
[quote="Neilr"]
I have had to bypass the clutch switch to start the bike, not sure if bypassing the side stand switch will make a difference but worth a go?[/quote
Well just tried by passing both clutch and side stand switch and still cuts out when gear is selected?
1.Bike will not start without either the clutch lever pulled in our switch bypassed.
2. When bypassed bike will run but when clutch lever is pulled in and gear engaged bike cuts out.
Neutral light is working when disconnected from plug light goes out and comes on when plug is reconnected.
not sure what to try next?
BRUN
PostPosted: 16:28 - 24 Feb 2021    Post subject: Reply with quote
do you have a engine warning light on, does it flash ?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:39 - 24 Feb 2021    Post subject: Reply with quote
In that case you've done it wrong.
Triumph Sprint ST 1050
Neilr
PostPosted: 19:25 - 24 Feb 2021    Post subject: Yamaha fazer runs but cuts out when clutch lever operated Reply with quote
have you tried to bypass the side stand switch to see if its related to that, sounds likely to me (im a bike noob but learning)[/quote]
I have had to bypass the clutch switch to start the bike, not sure if bypassing the side stand switch will make a difference but worth a go?[/quote]
What have i done wrong? Can you please tell me as id love some guidance as to what direction to go in. Tried uploading a wiring diagram for my make and model of fazer but not sure why it wont upload.
bikenut
PostPosted: 19:55 - 24 Feb 2021    Post subject: T Reply with quote
Can you see the exact wiring diagram for your bike ?
If you can then you should be able to "see" where wires go and Thier colours, like the side stand switch, clutch switch, neutral switch etc. and determine if they are normally open for starting/running etc., Etc..
Are things like the clutch, stand and neutral switch "inhibitor" switches that prevent, for example, bike on side stand in neutral clutch out, the bike is in a condition that the starter will work and the engine will run, unlike, if on side stand and in gear with clutch out, it will not allow the starter to work or engine to run ( cos it will fall over ), or, if on stand and in gear and the clutch held in, it is allowed to start and run cos it won't fall over cos the clutch is held in ? Etc..
Yes the diagrams can be "spaghetti junction" until you know how to read them.
For your situation, ignorn the indicator circuit as that's not relevent, at the moment, etc..
Try and post the diagram again...
nuts about bikes
Nutty
PostPosted: 05:54 - 25 Feb 2021    Post subject: Reply with quote
Will this help
Neilr
PostPosted: 09:14 - 25 Feb 2021    Post subject: Reply with quote
Nutty wrote:
Will this help
Thanks for the info, ill trace all the wires back and check for open closed circuits(Ohms, continuity) Hopefully it will be something obvious.
Not sure what's happening when i try to upload a wiring diagram it just disapears? ill keep trying.
bikenut
PostPosted: 10:15 - 25 Feb 2021    Post subject: T Reply with quote
If that is the correct wiring diagram, print it off to A3 size, difficult to see on a small phone screen.
Also put bike on centre stand for safety.
nuts about bikes
Neilr
PostPosted: 11:33 - 25 Feb 2021    Post subject: Reply with quote
Neilr wrote:
Nutty wrote:
Will this help
Quick update, finally nailed the fault it was an intermittent connection on the pick up coil plug. As the side stand plug and neutral plug are located in the same place as the pick up plug i must have pulled one of the wire and so it became intermittent when trying to run. Still unsure as to why it caused me to have to pull the clutch lever in to start but it RUNS!!
Thanks again everyone for all your help.
bikenut
PostPosted: 16:18 - 25 Feb 2021    Post subject: T Reply with quote
Hurrah ! You found it, great, give yourself a pat on the back, you also now have a wiring diagram as well, result !
nuts about bikes
The last post was made 5 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 85.42 Kb
