| Neilr |
 Neilr Derestricted Danger
| BRUN |
 BRUN Trackday Trickster
| Neilr |
| BRUN |
| bikenut |
 bikenut World Chat Champion
| Neilr |
| BRUN |
| Nobby the Bastard |
| Neilr |
 Posted: 19:25 - 24 Feb 2021 Post subject: Yamaha fazer runs but cuts out when clutch lever operated |
have you tried to bypass the side stand switch to see if its related to that, sounds likely to me (im a bike noob but learning)[/quote]
I have had to bypass the clutch switch to start the bike, not sure if bypassing the side stand switch will make a difference but worth a go?[/quote]
In that case you've done it wrong.
What have i done wrong? Can you please tell me as id love some guidance as to what direction to go in. Tried uploading a wiring diagram for my make and model of fazer but not sure why it wont upload. |
| bikenut |
 Posted: 19:55 - 24 Feb 2021 Post subject: T |
Can you see the exact wiring diagram for your bike ?
If you can then you should be able to "see" where wires go and Thier colours, like the side stand switch, clutch switch, neutral switch etc. and determine if they are normally open for starting/running etc., Etc..
Are things like the clutch, stand and neutral switch "inhibitor" switches that prevent, for example, bike on side stand in neutral clutch out, the bike is in a condition that the starter will work and the engine will run, unlike, if on side stand and in gear with clutch out, it will not allow the starter to work or engine to run ( cos it will fall over ), or, if on stand and in gear and the clutch held in, it is allowed to start and run cos it won't fall over cos the clutch is held in ? Etc..
Yes the diagrams can be "spaghetti junction" until you know how to read them.
For your situation, ignorn the indicator circuit as that's not relevent, at the moment, etc..
Try and post the diagram again... ____________________ nuts about bikes |
| Nutty |
 Nutty Two Stroke Sniffer
| Neilr |
| bikenut |
| Neilr |
| bikenut |
The last post was made 5 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
