| MaxineDuncan |
 MaxineDuncan L Plate Warrior
 Posted: 08:41 - 01 Mar 2021 Post subject: NOT STARTING after cleaning clutch cable - HELP |
Hey legends, hope you're well.
Need a little help over here with troubleshooting this issue if anyone has any wisdom they would like to share.
Im a little bit of a rook, but got my second bike not long ago and have been trying my best to work on it myself. Another day, another drama haha but enjoying the lessons of trying to work throught it.
Anyway, current issue: took the clutch cable cover off to give it a little clean up, also wanted to check out the neutral switch in there (hadnt had that light working since i got this bike)
So took case off, cleaned it up a bit, put it back on, as far as i know thats all i did and then for some reason bike wont start again .
Getting that click when i push the starter, but its not really turning over.
Cant work out what would of changed in me doing so, to make it not want to start again
Anyway, if anyone has any ideas or wisdom to share, would be much apparcieted
Thanks in advance
Maxine |
| doggone |
 doggone World Chat Champion
| MaxineDuncan |
 Posted: 12:57 - 01 Mar 2021 Post subject: |
If you can find the starter solenoid, shorting between the two high current posts on that should make the starter motor spin over regardless of what's happening with any safety interlocks.
Also make sure you didn't pinch any wires under the cover when you put it back on.
As an aside, there is a giant circlip holding the front sprocket on? I've never seen that before. On that type of sprocket/final drive system, I'd expect to have a splined washer that bolts into the sprocket itself with two short bolts. Like this:
https://photos.smugmug.com/Adventure/Motorcycles-1/XR650L/i-7SkVZpL/0/ca441103/L/P4080005-L.jpg
While it's probably doing a reasonable job of holding the sprocket on, I'm a bit cagey about it, it won't be holding the sprocket in place like a splined washer would.
What bike is it? Then you can check the parts fisches and see what's supposed to be there. I could be wrong and it's suppossed to have a circlip, never seen it though and centrepetal force will tend to cause that type of clip to undo itself. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Evil Hans |
 Evil Hans World Chat Champion
| redeem ouzzer |
| WD Forte |
 WD Forte World Chat Champion
| doggone |
| WD Forte |
| MaxineDuncan |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Robby |
 Robby Dirty Old Man
The last post was made 5 years, 227 days ago. Instead of replying here, would creating a new thread be more useful? |
