1986 honda shadow v700 no spark
lzamora78gs55...
PostPosted: 00:33 - 03 Mar 2021    Post subject: 1986 honda shadow v700 no spark Reply with quote
No spark
Checked magnetic coils per manual and where below resistance values. Replaced with used coils that were within specs but came from a Pacifica that had similar specs. No spark. Need to check if ecm is working or not, looking but one found shop in Australia that can test and sell you a replacement or repair yours if it fails.
Is it possible to convert coils and ecm to different models since ecm for this 86 is almost impossible to find??
Thanks
sickpup
Old Timer
PostPosted: 09:07 - 03 Mar 2021    Post subject: Reply with quote
Is it a V or a VT?
If it's a VT engine there is a high probablility you could get away with using an ecu off a VT500, BROS650, BROS400, XLV750R, NTV600, NTV650, Africa twin etc. but although they may work after a little modification to the wiring looms they won't be perfect.
I think there is a variation in these bikes in that some used a dual pick up and some a single pick up so it will require some investigation but they are all pretty much the same engine.
lzamora78gs55...
PostPosted: 18:14 - 03 Mar 2021    Post subject: 1986 honda shadow v700 no spark Reply with quote
correction, feel dumb, but here it goes, did a vin check on it and it is a 1988 Vt600
IN: JH2PC2115JM0*****
Year: 1988
Make: Honda
Model: Vt600
Trim: C
So then, I should be able to locate some parts from another honda 600 and with some mods be able to fit the pickups and ECM//??
Thanks,
sickpup
Old Timer
PostPosted: 08:52 - 04 Mar 2021    Post subject: Reply with quote
Various on ebay for VT600c Shadow.
The last post was made 5 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 39 Kb
