Flashing headlight!
andyrint
PostPosted: 11:22 - 14 Mar 2021    Post subject: Flashing headlight! Reply with quote
Hi guys,
Keeway RKS Sport 125 EFI Euro 4
My bike's recently developed a weird electrical problem. When I start it up the headlight flashes! This usually stops after a few minutes but not always. When I rev the engine the rate of the flashing increases and slows down again when the revs go down. Flashing happens of high and low beam. All the other electricals work correctly including the side light.
I thought I might be something to do with the battery as I remove it every night after work (using spade connectors) as I've had 2 stolen. But that wouldn't explain why it worked fine for over 9 mths since I started removing it.
Any help greatly appreciated!
Tia Andy
Nobby the Bastard
Harley Gaydar
PostPosted: 11:28 - 14 Mar 2021    Post subject: Reply with quote
Whatever is causing it it won't be the battery. With the engine running the charging system will provide as much as the battery anyway.
Does anything else flash. Try pressing the horn when it's flashing
Triumph Sprint ST 1050
yen_powell
PostPosted: 11:48 - 14 Mar 2021    Post subject: Re: Flashing headlight! Reply with quote
andyrint wrote:
Hi guys,
Tia Andy
Do your indicators now have a high and low beam?
The only time I have had a headlight that went on and off it was a dodgy electrical connection in the wiring loom and it started halfway down some icy rock steps at night on an Exmoor green lane.
XT1200Z and a DR350 in bits
PostPosted: 13:36 - 14 Mar 2021    Post subject: Reply with quote
Is it a conventional filament bulb or an LED?
andyrint
PostPosted: 16:41 - 14 Mar 2021    Post subject: Reply with quote
Thanks for the replies
Haven't tried the horn but the indicators and brake lights are fine.
It's a normal halogen bulb
jeffyjeff
PostPosted: 17:14 - 14 Mar 2021    Post subject: Reply with quote
Sounds like the phenomenon is related to either engine rpm or charging system voltage. I would try bypassing the headlight relay (assuming the Keeway has one) and see if that changes anything. At least then you would know which circuit is affected. Does it flash at regular intervals like a headlight modulator?
PostPosted: 17:57 - 14 Mar 2021    Post subject: Reply with quote
Just check the terminals are a good fit on the bulb and are free from corrosion. Might be worth squirting some WD40 in the light switch and wiggling it back and forth a few times too.
WD Forte
PostPosted: 18:37 - 14 Mar 2021    Post subject: Re: Flashing headlight! Reply with quote
andyrint wrote:
Hi guys,
Tia Andy
It may just be down to bad connections grounding etc
but if its a fast flashing, a diode in the rectifer may have failed short
and be injecting some half wave AC in the circuit
I'd do a diode test on the RR just to be sure
bikers smell of wee
jeffyjeff
PostPosted: 21:23 - 14 Mar 2021    Post subject: Re: Flashing headlight! Reply with quote
Good call. I'll bet you could also verify that by switching your multimeter to AC volts and placing the test leads across the battery. A reading over 0 volts AC would indicate a failed diode.
Edit: A diode failed open might cause the rectifier bridge to supply a pulsed-DC output that could conceivably cause the headlight to pulse accordingly. If so, I imagine that the tail light and brake lights would also pulse when illuminated.
andyrint
PostPosted: 02:09 - 15 Mar 2021    Post subject: Reply with quote
I don't know either - can't find a wiring diagram for it Sad
Not sure what you mean by 'headlight modulator' but the flashing is regular and increasing frequency with engine rpm
Headlight terminals look ok - there is no light switch. Lights come on when engine starts up. only high/low beam switch.
This is worth a shot although - to my mind - doesn't explain why the flashing usually stops after a few minutes. I'll try it tomorrow and update you all.
Big thanks to everyone that's contributed - this has been driving me nuts lately!
Easy-X
PostPosted: 03:17 - 15 Mar 2021    Post subject: Reply with quote
If I were to guess I'd say it's some sort of weird earthing issue where the headlights are somehow finding ground via the ignition system. Once warmed up some other path is found by the magic electricity piskies Smile
MCN
PostPosted: 06:33 - 15 Mar 2021    Post subject: Reply with quote
Broken Bulb. Change the bulb.
andyrint
PostPosted: 12:21 - 15 Mar 2021    Post subject: Reply with quote
First thing I did!
Just put my (very old and very cheap) multimeter across the battery terminals while the light was flashing and it's reading about 30v AC. So looks like the diode is faulty, however... That's something the bike shop said they had replaced last time I took it to them - unless they replaced a different diode??? Or the root problem is something that is making the diode fail.
Robby
Dirty Old Man
PostPosted: 15:51 - 15 Mar 2021    Post subject: Reply with quote
30V AC would suggest a very unusual failure mode for a reg/rec, where it's neither regulating nor rectifying. It's just passing the alternator output right into the battery.
jaffa90
PostPosted: 18:20 - 15 Mar 2021    Post subject: Reply with quote
""""Just put my (very old and very cheap) multimeter across the battery terminals while the light was flashing and it's reading about 30v AC."""
What is the reading in DC volts??? 15?
MCN
andyrint wrote:
First thing I did!
If your alternator is running direct to the battery then the bulb could be flashing due to an over-current causing a diode to break down.
Fix the charging issue.
Can't be arsed scrolling up.
Doe the light flash with the engine off?
Scrolled up.
The alternator regulation is causing the flashing.
WD Forte
PostPosted: 19:24 - 15 Mar 2021    Post subject: Reply with quote
andyrint wrote:
First thing I did!
I just stuck a meter across a spare battery and got
12.45V DC
Doing the same test on the AC range I got nothing, nada, sfa.
just some 0.1V AC ish noise value.
You might get some small noise/interference value on a running bike
but 30VAC is bad...... very bad.
bikers smell of wee
WD Forte
PostPosted: 19:34 - 15 Mar 2021    Post subject: Reply with quote
andyrint wrote:
First thing I did!
The diodes (6 on a 3 phase stator) are buried inside the regulator and not 'user serviceable'
Changing it doesnt mean they fitted a good one.
Some of the cheap chinese made ones can be pretty poor quality
As on any bike/scoot they also need good grounding and ground continuity throughout the bike or all sorts of odd symptoms can happen.
bikers smell of wee
andyrint
PostPosted: 11:15 - 16 Mar 2021    Post subject: Reply with quote
Yeah, about that.
However, I just measured the voltage across a battery that was being recharged (on a home charger) and that shows 30v Ac / 15v Dc - Is something wrong with my multimeter??
jeffyjeff
PostPosted: 14:58 - 16 Mar 2021    Post subject: Reply with quote
Make sure that your meter is not displaying millivolts -=(mV). Often times, the lower case "m" that indicates millivolts is displayed in fine print, and easily overlooked. If that be the case, the meter is actually displaying 30 mV, or 0.030 volts. That would be a reasonable expectation.
andyrint
PostPosted: 23:34 - 16 Mar 2021    Post subject: Reply with quote
It doesn't have millivolts - it's not that good a multimeter!
jaffa90
PostPosted: 01:19 - 17 Mar 2021    Post subject: Reply with quote
Yeah, about that.
Hold on a minute, this bike is coming in at a 2019 model with a 2 year warranty,
""""I thought I might be something to do with the battery as I remove it every night after work (using spade connectors) as I've had 2 stolen. """"
Are you talking 2 bikes or 2 batteries?
Spade connectors that i know of are for light duty currents.
Also why are you charging the battery?
andyrint
PostPosted: 10:57 - 17 Mar 2021    Post subject: Reply with quote
Purchased in August 2018
2 batteries - ripped out from under the seat
I was charging a spare
jaffa90
PostPosted: 01:52 - 19 Mar 2021    Post subject: Reply with quote
From what you say/state and the electric start works then did you try stinkwheel advice?
The last post was made 5 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 128.45 Kb
